[Tiện ích] Green Power Premium 8.6.2 -ứng dụng hỗ trợ tiết kiệm pin
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 11 Tháng bảy 2011.
  1. Khỉ Con interista
    Green Power battery saver ​
    Yêu cầu: Android 2.1+
    Tính năng: Khác với các phần mềm tiết kiệm pin khác, Green Power Battery Saver chạy hoàn toàn tự động: tự động ngắt kết nối wifi khi bạn không dùng và ngược lại, tự động bật wifi khi có ứng dụng nào cần truy cập mạng.
    [​IMG][​IMG]
    Get the Best Battery Saver!"Charge less by extending your battery life with this amazing app!! (Sprint newsletter April 2012)
    Unlike other battery savers that require regular user manual actions, GreenPower is fully automatic: Once configured, it runs and saves your battery by itself. It does so by smartly managing Wifi, Mobile data & Bluetooth: Turning them off when you don't need them, but ensure minimum disturbance: Automatic turned ON when needed by you or by other apps (e.g retrieving mails).
    Similar but easier cleaner and faster than JuiceDefender!
    "GreenPower is a simple and easy to use power and network management software" (Engadget Chinese edition)
    HIGHLIGHTS
    - Handles WIFI, Mobile Data (2G, 3G, some 4G) & BLUETOOTH
    - Supports most phone types (both GSM & CDMA) and most carriers
    - Supports Android ICE CREAM SANDWICH, HONEYCOMB, GINGERBREAD & FROYO
    - Mobile Data toggling using clean Internal API or APN renaming (you can chose)
    - Most features below available in Free version unless marked with (*)
    "GreenPower mainly does one thing, but does it so well and so flexibly that the benefits reaped are considerable." (InfoWorld)
    INSTALL AND FORGET
    Or take time to configure to get the most out of it!
    SATISFIED OR MONEY BACK GUARANTEE (premium)
    Try Premium for 24H and get a refund if you didn't like it by just sending us a mail.
    "GreenPower premium is a remarkable tool. Battery saver, time saver, top notch!" (AndroidPit)
    FEATURES
    - Wifi mgmt: Based on schedule, screen state, power connected, signal level...
    - Mobile data mgmt: Based on schedule, screen state, power connected...
    - Mobile data mgmt: Either Internal API or APN renaming
    - BLUETOOTH (premium) mgmt: Based on devices connected or in range, screen state, power etc
    - Traffic check: Configurable to prevent disturbing other apps
    - Apps Whitelist (premium): To keep data on when using specific apps (like music streaming)
    - Simple WIDGET (premium): To quickly pause or resume
    - NIGHT (premium) mode fully configurable, Airplane mode...
    - Tasker & Locale Plug-in (premium)
    - Compatible with Cerberus 2.0
    - Very lightweight and fast app
    - Easy and clean interface
    - Fully configurable settings
    - Settings backup / restore
    - 20 Languages (changeable at run time)
    - And more coming all the time...
    SUPPORT
    - Dedicated Forum for support issues
    - Support from the developer. I'm answering each issue.
    - Regular updates with bug fixes and new features
    PREMIUM version specific features:
    - Bluetooth support
    - Widget
    - Night mode
    - Apps whitelist
    - No ads
    - The good feeling to support an independent developer
    Thông tin chi tiết:
    https://market.android.com/details?id=org.gpo.greenpower2&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/4398
  2. mr-google
    mr-google Thành viên
    Toàn tiếng anh nhỉ, chẳng có tiếng việt :d
  3. Khỉ Con
    Đọc vài dòng này là được rồi, còn lại tự test thôi.
  4. Khỉ Con
    Cập nhật 4.2 ở bài đầu !
  5. Khỉ Con
    4.5
    What's in this version:
    1. Norwegian translation
  6. Khỉ Con
    1. Version 4.7
    2. New features
    3. Adding Wireless durations: "Stay ON" and "Stay OFF", both at Day and Night.
    4. Adding setting "Bluetooth ON when call made" (premium only).
    5. Adding menus to the new online User Guide and Forum.
    6. Bugs fixed
    7. Bug of status "paused" not refreshed when pausing from menu (premium only).
    8. Website
    9. Brand new website.
    10. Translations
    11. Improved Spanish translation.
    12. Improved Japanese translation.
  7. Khỉ Con
    4.9
    1. Version 4.9
    2. Bug fixes
    3. Fixing some cases of 3G not coming back when screen turned ON.
    4. Fixing troubles with "Ripple Lock" screen-locking app.
    5. New features
    6. Adding a setting to turn OFF Bluetooth at the end of a call if it was turned ON automatically at the start of the call.
    7. Languages
    8. Catalan translation added.
    9. Portuguese translation added.
    10. Hungarian translation added.
  8. Khỉ Con
    8.5.11
    Various bugfixes and improvements.
    See release note inside app for details.
  9. Khỉ Con
    cập nhật 8.6
  10. Khỉ Con
    Cập nhật 8.6.2
