Melon Mobile Advanced Battery Saver - Kéo dài tuổi thọ của pin.
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi tichau, 21 Tháng mười hai 2009.
  1. tichau Guest
    Melon Mobile Advanced Battery Saver v1.00.25 S60v3 SymbianOS9 Unsigned -GksPDA
    Extend the life of your phone battery up to 30%!
    Do you have days when your battery runs low too quickly? Do you sometimes forget your charger and wonder if your phone will last until the end of the day? Advanced Battery Saver will help you get the most out of your battery and stay connected longer!
    With Advanced Battery Saver you can adjust the power-consumption of your phone functions, services and application depending on your needs. Use Advanced Battery Saver to get up to 30% more uptime for your phone by cutting down "battery eaters" you don’'t use all the time such as Bluetooth, vibration, lights, etc. You can also create and save your own power-saving modes to customize the power-saving according to your personal preferences.
    Battery-optimizing modes
    Advanced Battery saver adjusts the power-consumption of the following phone functions: lights, vibration, network, Bluetooth, Internet connection, sounds and applications.
    • Three predefined power-saving modes, Saver off, Basic saver and Max saver, help you quickly switch your power-saving configuration
    • Option to define your own power-saving modes to extend the life of your battery by selecting which phone functions and applications to shut down according to your needs
    • The power-savings chart allows you to compare the remaining battery life for the currently selected power-saving mode with that of the predefined modes
    Auto-Saver Mode
    With the Auto-saver feature you can set your phone to automatically switch to your preferred power-saving mode. Specify the battery level (in bars) at which you want to start saving power, and let Advanced Battery Saver do the rest. Supported languages
    Advanced Conference Call is available in English, French, Italian, German, Spanish and Bulgarian.
    Supported Devices
    Nokia: 3250, 5230, 5320, 5500, 5530, 5630, 5700, 5730, 5800 XpressMusic, 6110, 6120, 6121, 6122c, 6124, 6210, 6220, 6290, 6650, 6710, 6710, 6720, 6730, 6760, 6790, 6788, E50, E51, E52, E55, E60, E61, E61i, E62, E63, E65, E66, E70, E71, E72, E75, E90, N71, N73, N75, N76, N77, N78, N79, N80, N81, N81 8GB, N82, N85, N86, N86 8GB, N91, N92, N93, N93i, N95, N95 8GB, N96, N97, Nokia X6
    Samsung: SGH-G810, SGH-L870, SGH-i400, SGH-i408, SGH-i450, SGH-i520, SGH-i550, SGH-i560, SGH-i570, SGH-i7110, SGH-i8510, SGH-i8910
    Sony Ericsson: Sony Ericsson Satio
    sc311, iifaces, namnghinruoi and 4 others like this.
  2. md07
    md07 Thành viên
    chương trình này điều chỉnh những gì trong máy để tiết kiệm pin nhỉ?
  3. tichau
    tichau Guest
    MelonMobile Advanced Battery Saver v1.00.25 S60v3 S60v5 SymbianOS9.x Unsigned Proper -FoXPDA
    Do you have days when your battery runs low too quickly? Do you sometimes forget your charger and wonder if your phone will last until the end of the day? Advanced Battery Saver will help you get the most out of your battery and stay connected longer!​
    With Advanced Battery Saver you can adjust the power-consumption of your phone functions, services and application depending on your needs. Use Advanced Battery Saver to get up to 30% more uptime for your phone by cutting down "battery eaters" you don’'t use all the time such as Bluetooth, vibration, lights, etc. You can also create and save your own power-saving modes to customize the power-saving according to your personal preferences.​
    * Advanced Battery saver adjusts the power-consumption of the following phone functions: lights, vibration, network, Bluetooth, Internet connection, sounds and applications.
    * Three predefined power-saving modes, Saver off, Basic saver and Max saver, help you quickly switch your power-saving configuration
    * Option to define your own power-saving modes to extend the life of your battery by selecting which phone functions and applications to shut down according to your needs
    * The power-savings chart allows you to compare the remaining battery life for the currently selected power-saving mode with that of the predefined modes​
    Auto-Saver Mode
    Advanced Conference Call is available in English, French, Italian, German, Spanish and Bulgarian.​
    thhai.mobile and vanvu like this.
  4. tichau
    tichau Guest
    Melon Mobile Advanced Battery Saver v1.00.24.S60v3 SymbianOS9.1 Unsigned-ErESPDA
    linhstpaul and vanvu like this.
  5. takeda
    takeda PC Top Contributor
    Melon.Mobile.Advanced.Battery.Saver.v1.00.25.S60v3 - Tiện ích về Pin
    Melon.Mobile.Advanced.Battery.Saver.v1.00.25.S60v3 SymbianOS9.x.Unsigned.*******-GksPDA
    Auto-Saver Mode
    Supported Devices
    vanvu thích bài này.
  6. Khỉ Con
    Melon Advanced Battery Saver v1.01.39 S60v3 SymbianOS9.x Unsigned .......-Fo XPDA
    Do you have days when your battery runs low too quickly? Do you sometimes forget your charger and wonder if your mobile phone will last until the end of the day? Advanced Battery Saver will help you get the most out of your battery and stay connected longer!
    With Advanced Battery Saver you can adjust the power-consumption of your phone functions, services and application depending on your needs. Use Advanced Battery Saver to get up to 30% more uptime for your phone by cutting down “battery eaters” you don’t use all the time such as Bluetooth, lights, Internet connection, applications, etc. You can also create and save your own power-saving modes to customize the power-saving according to your personal preferences.
    Features
    Advanced Battery saver adjusts the power-consumption of the following phone functions: lights, vibration, Bluetooth, Internet connection, sounds and applications.
    Three predefined power-saving modes, Saver off, Basic saver and Max saver , help you quickly switch your power-saving configuration
    Auto-Saver Mode
    Supported languages
    Advanced Battery Saver is available in English, French, Italian, German, Spanish and Bulgarian.
    What's New
    Full support for Symbian^3 devices.
    [URL="http://adf.ly/BH34"]click here[/URL]
  7. hoangsanhqn
    hoangsanhqn Thành viên
    toàn tiếng Tây làm sao mà sử dụng.có port bài thì việt hoá giùm cái đi8-x
  8. vanvu
    vanvu Thành viên
    Bác chủ xài qua nó rồi cũng nên giới thiệu vài câu bằng tiếng việt thi hay hơn.
  9. Khỉ Con
    cái nào khó sử dụng thôi, cái này đơn giản với dễ mà :|
  10. Khỉ Con
    Melon Advanced Battery Saver v1.01.40 S60v3 S60v5 S^3 SymbianOS9.x Signed Cr@cKeD-By-R@me$h
    Advanced Battery Saver (ABS) to get up to 30% more uptime for your phone! With this excellent saver, you can adjust how much power is consumed by your phone. Easily identify and cut down non-critical ?battery eaters.? Create and save your own power-saving modes to achieve the smoothest optimization.
    ABS can control the power-consumption of the following phone functions: applications, Bluetooth, Internet connection, lights, sounds, and vibration.
    Battery-Optimizing Modes
    Three predefined power-saving modes help you quickly switch to your preferred configuration
    Option to define saving modes of your own
    Power-savings chart shows the precise remaining battery life for the currently selected power-saving mode and compares it with those of the predefined modes
    Auto-Saver Mode
    With the Auto-saver feature you can set your phone to automatically switch to your preferred power-saving mode. Specify the battery level that, when reached, will trigger the activation of a mode chosen by you and let Advanced Battery Saver do the rest.
    Supported Languages
    New in version 1.01
    Full support for Symbian^3 devices (Nokia N8, E7, C7, etc)
    Some Minor Bugs Fixed..!
    Registration Information
    No Need To Register..!
    A detailed user manual is available in Rar file.
    [URL="http://adf.ly/Bmtj"]http://adf.ly/Bmtj[/URL]
