PhoneTorch v2.0.4: biến flash thành đèn pin
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi manbk401, 22 Tháng tư 2010.
  1. manbk401 Thành viên
    PhoneTorch v2.0.4 S60v3 SymbianOS9.x Unsigned Retail-drAdeLante
    Retail by drAdeLante
    PhoneTorch provides functionality to use your smartphone as a torch/flashlight and for Morse signaling. It supports both, the phone's LCD screenlight, and the phone's flash LEDs (video light) as light sources.
    Features :
    * Light sources: flash LED and LCD screen, can be independently controlled
    * Improved speed *NEW*
    * Light intensity control of LCD screen *NEW*
    * Emitted color selection of LCD screen *NEW*
    * Autostart when phone is turned on *NEW*
    * Run PhoneTorch in background *NEW*
    * Switch light on/off with special keys (e.g. camera button) even if keys are locked *NEW*
    * Optional sound when light is turned on/off *NEW*
    * Restore PhoneTorch state when restarted
    * Improved user interface
    * Morse code (e.g. SOS)
    Change Log :
    * Fixed camera shortcut key activation problem from other programs (e.g. TrackBuddy)
    * Fixed "light remains on on power down" bug on N86 and E75
    * Fixed light bulb icon animation
    * Now middle key changes main states instead of calling options menu
    * Red/blue light is turned off now
    * Fixed sound
    * Performance improvements
    * Enable/disable camera key when keyboard is locked
    * Fixed settings dialog
    Installation Instructions for Unsigned SIS :
    1. Download PhoneTorch unsigned
    2. Goto www.SymbianSigned.com website
    3. Enter your phone's IMEI (you get it by typing "*#06#" into your phone), your email address and then select the downloaded PhoneTorch file
    4. You will receive an email with an activation link. Click on the activation link. After some minutes you receive another email containing the download link to the signed PhoneTorch installation file.
    5. Install this signed file on your phone
    6. Sometimes you get an certificate error after signing. Then first check that your phone's date and time are correct and wait some minutes. Then try to install it again.​
  2. duc2012
    duc2012 Thành viên
    cái pm này dùng ntn thế hả bác??em có thấy bật đc đèn pin đâu nhỉ?chả thấy lên gì cả..bật nó xong thì hide sau đó vào camera thì báo là đang sử dụng ct camera r???bro giải thích hộ e cái pm này với.em dùng E71
  3. h2love4ever
    h2love4ever Thành viên
    mình cũng k dùng đc
  4. verylove
    verylove Staff Member
    hình minh hoạ là giống của V5 rồi chắc mấy bạn V3 ko xài đc , V3 xài bản này là ok nè
    Trunghuy90, votudi, thanh4 and 16 others like this.
  5. dinhnguyenbmt
    dinhnguyenbmt Thành viên
    brightlight v2.0 cài vào máy n95 không xài được pro ơi
  6. acatoan
    acatoan Thành viên
    Chạy tốt trên N86. Thank chủ topic nhiều nhiều
  7. kimdungvu
    kimdungvu Thành viên
    hok biết chạy đc trên N81 hok nhi? bro nào thử chưa?
  8. manhthang_599gtb
    manhthang_599gtb Thành viên
    không biết con C5 cài cái này được không vậy bác nhỉ ? cái này em thấy không những hay mà là quá hay luôn đó
  9. khongan
    khongan Thành viên
    Cái này có cài cho N95 được không vậy ?
  10. Trunghuy90
    Trunghuy90 Staff Member
    dùng cái của bác verylove trên là ok
