Ravensoft Battery Extender - Kéo dài tuổi thọ của pin.
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi tichau, 1 Tháng ba 2010.
  1. tichau Guest
    Ravensoft Battery Extender v1.14 S60v3 SymbianOS9.x Signed Incl-key gen zAWS!@FoXPDA
    Today's feature rich smartphones are fantastic but their battery performances can be somewhat limiting. This is where Battery Extender can help by fine tuning the settings on your device. As your battery drains, less critical power draining features can be disabled to extend the life.
    Profiles
    A profile is a list of features you wish to change. The application comes configured with some recommended profiles but you can customise them to your needs.
    Going away for a long weekend?
    Enable Battery Extender's Max Battery profile. This turns on all the power saving features to their highest levelto give you the maximum battery performance.
    Going walking/running and want to be geo tagging your photos or mapping your route?
    Enable Battery Extender's Outdoor sports profile. This will enable the maximum battery performance, saving energy on unneeded features, to stop the power hungry GPS receiver from completely draining your battery.
    Want to be using Google Latitude but not at the expense of a flat battery?
    Add Google Maps to the list of applications to close down when you battery level drops below 3 bars.
    Just want your phone to last longer?
    Use the Improved Battery profile to start only changing settings when the battery runs low
    Features :
    Currently Battery Extender will manage the following features:
    • Backlight brightness
    • Backlight timeout
    • Screensaver timeout
    GPS
    Bluetooth
    Autorotate
    • Applications
    [​IMG] Attached Files
    kuteo, hungau, natan1 người khác thích bài này.
  2. trankien2212
    trankien2212 Thành viên
    không down được bạn ơi
  3. hungau
    hungau Thành viên
    Trên diễn đàn có bạn nào thử chưa? Cho mình ý kiến với. Thấy cũng hay hay .......Thanks
  4. MrSeries
    MrSeries Thành viên
    không biết cách dùng thế nào vậy bác ơi :(
  5. BinhDa
    Đơn giản mà bạn! Nó hoạt động theo nguyên tắc thiệp lập sẵn giống các Profiles điện thoại như : Bình thường; Ngoài trời; OFFLINE; Yên lặng; .....
    Bạn xẽm hình bài #1 là bạn đã có thể hình dung ra rồi. Khi cài xong thì bạn mởb nó lên. Sau đó vào thiếp lập 1 chút là OK th ôi. Khi máy đầy PIn thì tất cả tính năng hoạt động. Khi pin yếu 1 chút sẽ tắt vài tính năng ít sử dụng. Khi pin gần hết sẽ tự động giảm độ sáng tối đa.....
    Mình ghi sơ sơ như như vậy. Bạn tùy chỉnh cấu hình theo nhu cầu sử dụng phù họp của bạn nữa là Ok
    MrSeries thích bài này.
  6. MrSeries
    MrSeries Thành viên
    tức là nó tự xem xét lượng pin rồi tùy chỉnh các cấu hình phù hợp hả bác :)
    trên Ovi cũng có mà bác :D
  7. haocrazy
    haocrazy Thành viên
    cái này có đc như nó nói ko ta
  8. MrSeries
    MrSeries Thành viên
    file gửi lên kh thấy đâu bác tichau ơi :(
  9. Còm.
    Còm. Giả Vờ Hết Staff Member
    Ravensoft Battery Extender v1.14.2 S60v3/v5 SymbianOS9.x Unsigned Cr @ cked-FoXPDA
    Profiles
    Features :
    * Backlight brightness
    * Backlight timeout
    * Screensaver timeout
    * GPS
    * Bluetooth
    * Autorotate
    * Applications
    toi_tay and tdquan987654 like this.
