[Công cụ-Hệ thống] System Control Pro v1.3.0 - quản lý hệ thống Pro
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 18 Tháng chín 2012.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.1
    Ảnh chụp màn hình:
    [​IMG][​IMG]
    [​IMG] [​IMG]
    ROOT IS REQUIRED!!!
    EACH ROOT USER MUST HAVE THIS APPLICATION!
    This application contains all important root applications. You can control your system and improve the performance of your device. The application contains all root features with which you can maximize your performance. If you want have all in one application to save your space and money, it is the best choice for you. Each feature contains help and give you recommended settings, which is also great for users who don't have lots of experiences.
    ADVANTAGES OF PRO:
    ★No ads
    ★Widget
    ★More features
    ★UI is faster
    ★Faster support
    ★More frequent updates
    ★You can support development
    FEATURES:
    ★CPU
    -Governor
    -MIN/MAX Frequencies
    ★Memory
    -Lowmemorykiller settings
    -Preset options
    ★SD Card
    -App2SD
    -I/O Scheduler
    -Read Cache
    ★Virtual Machine
    -Swappiness
    -VFS Cache Pressure
    -Drop Caches
    -Swap File
    ★GPS.conf
    -NTP Server settings
    ★Build.prop
    -LCD Density
    -VM Heapsize
    ★Apps Manager
    -Backup your apps
    -Restore your apps
    -Manage your apps
    ★Informations of your system
    -CPU Info
    -Memory Info
    -Battery Info (including timeleft)
    ★Tools
    -Wipe battery stats
    -Wipe dalvik cache
    ★Reboot options
    -Reboot
    -Recovery
    -Download
    -Bootloader
    -Shutdown
    ★Widget
    ★Beautiful and simple UI
    ★Set on boot
    ★Help
    -You can find there a help which explains you everything what you do not understand
    ★And many more
    I AM ALSO WORKING ON NEW FEATURES!!!
    Xem thêm trên Play Store:
    [url]https://play.google.com/store/apps/details?id=com.smartprojects.SystemControl [/url]
    Tải về:
    [url]http://appstore.vn/android/home/app/9943 [/url]
