Yêu cầu phiên bản Android từ: 1.6 Ảnh chụp màn hình: Thông tin chi tiết: Volume Control+ Pro is improved version of Volume Control+ with additional features and Ad-free Volume Control+ is a volume control app that support changing control types and colors. Features Three kinds of control types - Volume dial : Feeling of analog device Buttons : Precise control Seek bars(sliders) : Quick and easy ※ If you want to know the total volume in dial control mode, turn your device into horizontal Volume control - Media, Ring, Notifications, In-call, alarm, system Mute and unmute Vibratemode setting(ring and notification) Change ringermodes - Normal, Vibrate, Silent Change colors - Red, Blue, Green, Violet, Vanilla, Ice blue, Strawberry System settings - Change ringtone - Use incoming call volume for notifications Preset(Profile) - You can make a volume preset(profile) for frequently used settings, and by using app for preset(It is available with the Pro version) can be applied quickly Homescreen widget Lock volume - 'Lock volume' prevent unwanted changing volume and ringermode (The volume will be fixed in locked state, but this application can control the volume in lock state) ※ Screen is optimized for smartphones. In tablet pc, screen may not be correct. Xem thêm trên Android Market: Mã: [URL]https://market.android.com/details?id=com.cb.volumePlusPro&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5jYi52b2x1bWVQbHVzUHJvIl0.[/URL] Tải về: Mã: [URL]http://appstore.vn/a/index.php/home/app/2949[/URL]
