2G,3G,4G Network Monitor (F) v1.15.03
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 17 Tháng chín 2012.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.2
    Ảnh chụp màn hình:
    [​IMG][​IMG]
    [​IMG] [​IMG]
    2G,3G,4G Network Monitor (FULL)
    2G,3G,4G,CDMA Network MonitorWidget (1x1) for:
    - fast network mode change
    - enable/disable mobile data
    - showing current status with statistics
    - network monitor/counter traffic for mobile data and Wi-Fi
    - notification when signal is lost
    - no advertisement
    !!! READ CAREFULLY DESCRIPTION TO AVOID ANY COMMENTS WHICH ARE SAYING THAT APPLICATION DOES EXACTLY WHAT IS DESCRIBED HERE !!!
    This application does (check screenshots to get picture, how it looks):
    - shows current network status on widget and/or on notification icon
    - shows current mobile data status on widget and/or on notification icon
    - enable/disable mobile data by one tap on widget (2G-3G Mobile Data)
    - opens network setting for switching by one tap on widget (2G-3G Shortcut)
    - shows statistic how many bytes applications transferred (network traffic counter)
    - shows statistic how many bytes device transferred over mobile network and over Wi-Fi (network traffic counter)
    - shows statistic how long device is in some network (GPRS, UMTS, LTE, CDMA, etc.)
    Application shows following statuses:
    2G (GPRS), 2G (EDGE), 3G (UMTS), 3G (HSDPA), 3G (HSPA), 3G (HSUPA), 3G(EHRPD), CDMA (RTT), CDMA, CDMA (EVDO 0), CDMA (EVDO A), CDMA (EVDO B), IDEN, 4G (LTE), 4G (HSPAP)
    You must run once after installation the application, otherwise Widgets will not work! Also if you use Task Killer, put this app to ignore list! If you don´t need any statistic, you can disable it in Preferences.
    For more information visit my website:
    https://sites.google.com/site/androidapplicationsmichals/2g-3g-4g-network-monitor
    This application doesn´t drain battery. Don´t say it, if you can´t prove it. If you wish to check it by yourself, use applications for it, like PowerTutor (free).
    If you have suggestion, comment or bug report, please use first "Feedback" in Menu – Preferences. It is very hard to help you, if you only criticize application without additional information on the Market.
    Always test Lite version before you buy Full version to avoid any misunderstanding! Full version has unlimited statistics, that is only difference. I am trying to give you best tool I can, but it is very time consuming and more I get, more I can do for you : )
    Please always keep application updated to avoid any problems
    Xem thêm trên Play Store:
    [url]https://play.google.com/store/apps/details?id=msd.n2g.n3g.sell [/url]
    Tải về:
    [url] http://appstore.vn/android/home/app/9079[/url]
