Yêu cầu phiên bản Android từ: 1.5 Ảnh chụp màn hình: Guarding you against costly internet overages. Pro version of 3G Watchdog mobile data (4G/3G/Edge/GPRS...) counter / monitoring app, featuring: * Advanced data usage prediction * Billing rules (counts in blocks, ignores uploads, exclude apps, exclude time periods) * Usage history with graph & CSV export * Usage by application (Android 2.2+, unavailable on Dell Streak) * 5 widget styles * Backup/restore * Redesigned UI * Account/SIM with auto switch (requires a phone with a SIM) * Import settings & data from 3GW free (don't uninstall 3GW free before importing!) * ... and more! Translated in Chinese (simplified), Danish, Dutch, English, French, German, Greek, Hungarian, Italian, Japanese, Lituanian, Polish, Portuguese (Brazil), Portuguese (Portugal), Russian, Slovak, Spanish, more on the way. KNOWN PROBLEMS: * Doesn't count properly global usage on Samsung Galaxy Tab 10.1 and 8.9 - this problem affects other data counting applications as well and is caused by a bug on the tablet itself. You may try to check the "Calculate global usage from usage by app" advanced option as a possible workaround (feedback welcome). * Doesn't count properly global mobile usage on Samsung Galaxy R / Z (i9103) and possibly Galaxy Y. Problems were also reported with the Captivate Glide. Same workaround as for the Galaxy Tab (see above). * Early versions of 3GW Pro reported as not working on ZTE Blade/Orange San Francisco (black screen). OTHER PROBLEMS: * If you run into problems and wish to help to solve the problem while giving the community a chance to get a better 3GW Pro, please send a mail to contact-pro@3gwatchdog.fr with details. 3GW Pro can't possibly work perfectly on all possible phone models (more than 700 target devices) with all Android stock or custom versions + all manufacturers' custom layers (such as HTC Sense) + all carriers' custom layers + all combinations of installed applications, so please be understanding and collaborative rather than just angry if everything is not immediately perfect. Thank you. -> See the FAQ at http://3gwatchdog.fr/faqs Xem thêm trên Play Store: Mã: [url]https://play.google.com/store/apps/details?id=net.rgruet.android.g3watchdogpro [/url] Tải về: Mã: [url]http://appstore.vn/android/home/app/484 [/url]
1.6.0 What's in this version: New billing rule for excluding usage of selected apps. Select backup file to restore. Brazilian Portuguese, Greek, Italian (partial), Polish and Slovak translations. Bug fixes.
1.15.0 * Usage graph and text report for roaming usage (if has a quota). * Widgets can show roaming left and predicted usages. * New billing rule to not count local 2G traffic. * Keep the TWO last auto-backups instead of only one. * Device support: Samsung Galaxy S3 variants. * Fixed incorrect start of plan date calculation when plan period just reset today. * Other minor bug fixes.
