4EXT Recovery Control v1.1.8- sao lưu, phục hồi dữ liệu
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 26 Tháng chín 2011.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.1
    Ảnh chụp màn hình:
    Thông tin chi tiết:
    This is the must-have application for everyone using or planning to use 4EXT Recovery.By buying this app, you not only get a feature rich application that lets you control, configure and handle the advanced features of 4EXT Recovery with comfort, you also contribute to the future of 4EXT Recovery itself!
    Thanks to the great community the project will continually improve and stay as active as possible!
    For a trial version, please try the free "Recovery Updater" which includes a 3 day trial of 4EXT Recovery Control.
    It's available at www.4ext.net.
    Please don't rate the Recovery here, but the App only :) Thank you!
    !NOTE!
    Your device MUST BE ROOTED and currently you need to be S-OFF to use all the features!
    Some more devices will be added very soon!
    At the moment the following are supported:
    Incredible S / 2, Desire Z / G2, Desire S, Desire, Desire HD, Inspire 4G
    Please be patient regarding translations of the app. I will do my best to do that :)
    Most important features:
    *) Start Backups, Advanced Backups, Restore, Advanced Restore directly from inside the app
    *) Verify if a given backup is healthy by checking its md5sums. Better safe than sorry ;)
    *) Want to know which partitions a certain backup contains?
    -> Was it an "Advanced Backup, where you didn't select all partitions? ->
    -> This and more information is automatically displayed in the list of your backups.
    *) Install multiple zip files at once ->
    *) Optionally display the md5sums of all the files you are going to flash in one go!
    -> So you can make sure all are ok before you flash them.
    *) Want to format all partitions with a file system of your choice before you flash a new rom?
    -> Just use one of the Superwipe options
    *) Prefer to stay inside recovery after all your selected operations are done? No problem.
    *) Change the look and feel of your Recovery with a nice colour picker!
    *) Try out as many themes you like with a live preview.
    -> it will look the same as if you rebooted into recovery to check it out.
    *) Preview, modify, install, uninstall 4EXT Themes without the need to reboot into recovery
    *) View data about all your partitions directly from inside the app, without rebooting into recovery
    *) Had a bad Recovery session and didn't have the time to save the log file? No problem, let the app save it to your sdcard!
    *) Hate editing config files? Control all options of 4EXT Recovery from inside the app!
    *) Safely online install and upgrade 4EXT Recovery (md5sums are automatically verified)
    -> if in rare cases this doesn't work, let the app download a zip file including the recovery version you selected to your sdcard.
    ->The integrity of this downloaded recovery zip is automatically verified for you so you don't need to check md5sums!
    *) View all changelogs or known issues of any version available to your device.
    *) Encountered a problem? Use the report issue button to tell me about your problem and optionally attach valuable info such as your last recovery log to help me help you much better.
    *) .. and much more! For a complete feature list see www.4ext.net
    Xem thêm trên Android Market:
     [URL]https://market.android.com/details?id=ext.recovery.control&feature=search_result[/URL]
    Tải về:
     [URL]http://appstore.vn/a/index.php/home/app/2537[/URL]
    dongdo_mobile thích bài này.
  2. dongdo_mobile
    dongdo_mobile Thành viên
    cảm ơn bạn đang tim cái này
