ActiveFile v1.30.86 S60v3.SymbianOS9.3 [UpdatE 13 Sept'08] ActiveFile for S60 Platform (formerly Series 60 User Interface) is FREE! program to browse all folders and files in your S60 v7, v8 and v9 mobile phones with wide range of functions on phone’s file system… Key Features Here are some key features of ActiveFile: File management with 2 panels(File manager similar to Total Commander). so, you can view one folder in the first tab and browse to another folder in the second tab View all drives/folders/files on phone * File sorting by name, extention, uid, size, date, and ascending, descending Full file management with copy, move, rename, delete, make directory, make file, file properties, and set attributes Search files & directories Send files thru MMS, SMS, bluetooth, infrared View file/folder details Multi-selection Allows to add open with every file type Compress and decompress file using gzip format Modify the attributes of files and folder Quick check of available storage on your drives Allow multiple instances. So, you can launch ActiveFile more than 1 instances Hardware device & network info View running processes, tasks, kernel objects SMS creator tool to create SMS(fake SMS) and save it to a destination folder(Inbox, Drafts, Outbox, Sent folder) without used your sim card credit Capture screenshot and save it to a file in JPEG, GIF, BMP, PNG, and MBM format ** Memory & battery monitor tool Have an option to access inbox files Messaging explorer Folder shortcut or hotkeys Command/menu shortcuts or hotkeys Toggle to full screen and the best of all, its FREE! *) Protected folders on S60 3rd edition are accessible only for ActiveFile with manufacturer capabilities **) Available only for S60 1st edition, 2nd edition & 3rd edition with extended capabilities or manufacurer capabilities Only for Nokia 6210 Navigator, 6220 Classic, N78, N96 DOWNLOAD
ActiveFile v1.30.86 s60v3 OS9.x Signed and unsigned (14/09/08) ActiveFile 1.30.86 is Out! (14/09/2008) Symbian, Symbian S60 09.09.2008 No Comments Symbian s60v3 file manager Here are some key features of ActiveFile: - File management with 2 panels(File manager similar to Total Commander). so, you can view one folder in the first tab and browse to another folder in the second tab - View all drives/folders/files on phone * - File sorting by name, extention, uid, size, date, and ascending, descending - Full file management with copy, move, rename, delete, make directory, make file, file properties, and set attributes - Search files & directories - Send files thru MMS, SMS, bluetooth, infrared - View file/folder details - Multi-selection - Allows to add open with every file type - Compress and decompress file using gzip format - Modify the attributes of files and folder - Quick check of available storage on your drives - Allow multiple instances. So, you can launch ActiveFile more than 1 instances - Hardware device & network info - View running processes, tasks, kernel objects - SMS creator tool to create SMS(fake SMS) and save it to a destination folder(Inbox, Drafts, Outbox, Sent folder) without used your sim card credit - Capture screenshot and save it to a file in JPEG, GIF, BMP, PNG, and MBM format ** - Memory & battery monitor tool - Have an option to access inbox files - Messaging explorer - Folder shortcut or hotkeys - Command/menu shortcuts or hotkeys - Toggle to full screen - and the best of all, its FREE! (*) Protected folders on S60 3rd edition are accessible only for ActiveFile with manufacturer capabilities (**) Available only for S60 1st edition, 2nd edition & 3rd edition with extended capabilities or manufacurer capabilities Because this page doesn’t send the right MIME type, you shouldn’t click on the download link. Right-click and select “save link as” or “save target as” and save the file to your hard disk. Nokia 3250, 5500 Sport, 6290, 6650 T-Mobile, N71, N73, N75, N80, N91, N92, N93, N93i, E50, E51, E60, E61, E61i, E62, E65, E70 Download - [SIGNED] Symbian OS 9.1, S60 rel. 3.0 with basic capabilities Download - [UNSIGNED] Symbian OS 9.1, S60 rel. 3.0 with extended capabilities Download - [UNSIGNED] Symbian OS 9.1, S60 rel. 3.0 with manufacturer capabilities Nokia 5700, 6110 Navigator, 6120 Classic, 6121 Classic, 6124 Classic, N77, N78, N81, N82, N92, E90 Download - [SIGNED] Symbian OS 9.2, S60 rel. 3.1 with basic capabilities Download - [UNSIGNED] Symbian OS 9.2, S60 rel. 3.1 with extended capabilities Download - [UNSIGNED] Symbian OS 9.2, S60 rel. 3.1 with manufacturer capabilities Nokia 6210 Navigator, 6220 Classic, N78, N96 Download - [SIGNED] Symbian OS 9.3, S60 rel. 3.2 with basic capabilities Download - [UNSIGNED] Symbian OS 9.3, S60 rel. 3.2 with extended capabilities Download - [UNSIGNED] Symbian OS 9.3, S60 rel. 3.2 with manufacturer capabilities Note: Only os9.1 and os9.2 14/09/2008 release...
ActiveFile v1.40.186 Beta ActiveFile for S60 Platform (formerly Series 60 User Interface) is FREE! program to browse all folders and files in your S60 v7, v8 and v9 mobile phones with wide range of functions on phone’s file system… Key Features Here are some key features of ActiveFile:File management with 2 panels(File manager similar to Total Commander). so, you can view one folder in the first tab and browse to another folder in the second tab View all drives/folders/files on phone * File sorting by name, extention, uid, size, date, and ascending, descending Full file management with copy, move, rename, delete, make directory, make file, file properties, and set attributes Search files & directories Send files thru MMS, SMS, bluetooth, infrared View file/folder details Multi-selection Allows to add open with every file type Compress and decompress file using gzip format Modify the attributes of files and folder Quick check of available storage on your drives Allow multiple instances. So, you can launch ActiveFile more than 1 instances Hardware device & network info View running processes, tasks, kernel objects SMS creator tool to create SMS(fake SMS) and save it to a destination folder(Inbox, Drafts, Outbox, Sent folder) without used your sim card credit Capture screenshot and save it to a file in JPEG, GIF, BMP, PNG, and MBM format ** Memory & battery monitor tool Have an option to access inbox files Messaging explorer Folder shortcut or hotkeys Command/menu shortcuts or hotkeys Toggle to full screen and the best of all, its FREE!
ActiveFile v1.40.186 What’s new: - SMS Backup - New UI and speed improvement - Several bug fixes If you have problems upgrading ActiveFile, you need to uninstall existing ActiveFile. Nokia 3250, 5500 Sport, 6290, 6650 T-Mobile, N71, N73, N75, N80, N91, N92, N93, N93i, E50, E51, E60, E61, E61i, E62, E65, E70 Download - [SIGNED] Symbian OS 9.1, S60 rel. 3.0 with basic capabilities Download - [UNSIGNED] Symbian OS 9.1, S60 rel. 3.0 with extended capabilities Download - [UNSIGNED] Symbian OS 9.1, S60 rel. 3.0 with manufacturer capabilities Nokia 5700, 6110 Navigator, 6120 Classic, 6121 Classic, 6124 Classic, N77, N78, N81, N82, N92, N95, E90 Download - [SIGNED] Symbian OS 9.2, S60 rel. 3.1 with basic capabilities Download - [UNSIGNED] Symbian OS 9.2, S60 rel. 3.1 with extended capabilities Download - [UNSIGNED] Symbian OS 9.2, S60 rel. 3.1 with manufacturer capabilities Nokia 6210 Navigator, 6220 Classic, N78, N79, N85, N96 Download - [SIGNED] Symbian OS 9.3, S60 rel. 3.2 with basic capabilities Download - [UNSIGNED] Symbian OS 9.3, S60 rel. 3.2 with extended capabilities Download - [UNSIGNED] Symbian OS 9.3, S60 rel. 3.2 with manufacturer capabilities
Active File v1.40.186 Symbian OS9.1, OS9.2 and OS9.3 ActiveFile for S60 Platform (formerly Series 60 User Interface) is FREE! program to browse all folders and files in your S60 v7, v8 and v9 mobile phones with wide range of functions on phone’s file system… Key Features: File management with 2 panels(File manager similar to Total Commander). so, you can view one folder in the first tab and browse to another folder in the second tab View all drives/folders/files on phone * File sorting by name, extention, uid, size, date, and ascending, descending Full file management with copy, move, rename, delete, make directory, make file, file properties, and set attributes Search files & directories Send files thru MMS, SMS, bluetooth, infrared View file/folder details Multi-selection Allows to add open with every file type Compress and decompress file using gzip format Modify the attributes of files and folder Quick check of available storage on your drives Allow multiple instances. So, you can launch ActiveFile more than 1 instances Hardware device & network info View running processes, tasks, kernel objects SMS creator tool to create SMS(fake SMS) and save it to a destination folder(Inbox, Drafts, Outbox, Sent folder) without used your sim card credit Capture screenshot and save it to a file in JPEG, GIF, BMP, PNG, and MBM format Memory & battery monitor tool Have an option to access inbox files Folder shortcut or hotkeys ** Command/menu shortcuts or hotkeys Toggle to full screen Messaging explorer < SMS Backup/Restorer and the best of all, its FREE! * Protected folders on Symbian 9.x are not accessible ** Available only on devices that have pen key
ActiveFile v1.42.1 S60v3 SymbianOS9.x Freeware-Alie Tan ActiveFile is a FREE program to browse all folders and files in your mobile phone. Key Features: File management with 2 panels (File manager similar to Total Commander). so, you can view one folder in the first tab and browse to another folder in the second tab File sorting by name, extension, uid, size, date, and ascending, descending Full file management with copy, move, rename, delete, make directory, make file, file properties, and set attributes Compress and decompress file using gzip format Modify the attributes of files and directories Quick check of available storage on your drives Allow multiple instances. So, you can launch ActiveFile more than 1 instance. Searching thru the directories View running processes, tasks, kernel objects, and display system information (phone info and network info) SMS creator tool to create SMS (fake SMS) and save it to a destination folder (Inbox, Drafts, Outbox, Sent folder) without using your sim card credit Capture screenshot and save it to a file in JPEG, GIF, BMP, PNG, and MBM format Memory monitor tool Have an option to access inbox files Add shortcut What's New: Fixed SMS Backup bug Fixed Fake SMS bug Fixed numerous other bug reports from previous version Nokia 3250, 5500 Sport, 6290, 6650 T-Mobile, N71, N73, N75, N80, N91, N92, N93, N93i, E50, E51, E60, E61, E61i, E62, E65, E70 - [SIGNED] Symbian OS 9.1, S60 rel. 3.0 with basic capabilities - [UNSIGNED] Symbian OS 9.1, S60 rel. 3.0 with extended capabilities - [UNSIGNED] Symbian OS 9.1, S60 rel. 3.0 with manufacturer capabilities Nokia 5700, 6110 Navigator, 6120 Classic, 6121 Classic, 6124 Classic, N77, N78, N81, N82, N92, N95, E90 - [SIGNED] Symbian OS 9.2, S60 rel. 3.1 with basic capabilities - [UNSIGNED] Symbian OS 9.2, S60 rel. 3.1 with extended capabilities - [UNSIGNED] Symbian OS 9.2, S60 rel. 3.1 with manufacturer capabilities Nokia 6210 Navigator, 6220 Classic, N78, N79, N85, N96 - [SIGNED] Symbian OS 9.3, S60 rel. 3.2 with basic capabilities - [UNSIGNED] Symbian OS 9.3, S60 rel. 3.2 with extended capabilities - [UNSIGNED] Symbian OS 9.3, S60 rel. 3.2 with manufacturer capabilities
ActiveFile 1.42.1- FP2 - iPhone Style Nima79-Extended ActiveFile is a FREE program to browse all folders and files in your mobile phone. Key Features: * File management with 2 panels (File manager similar to Total Commander). so, you can view one folder in the first tab and browse to another folder in the second tab * File sorting by name, extension, uid, size, date, and ascending, descending * Full file management with copy, move, rename, delete, make directory, make file, file properties, and set attributes * Compress and decompress file using gzip format * Modify the attributes of files and directories * Quick check of available storage on your drives * Allow multiple instances. So, you can launch ActiveFile more than 1 instance. * Searching thru the directories * View running processes, tasks, kernel objects, and display system information (phone info and network info) * SMS creator tool to create SMS (fake SMS) and save it to a destination folder (Inbox, Drafts, Outbox, Sent folder) without using your sim card credit * Capture screenshot and save it to a file in JPEG, GIF, BMP, PNG, and MBM format * Memory monitor tool * Have an option to access inbox files * Add shortcut What's New: * Fixed SMS Backup bug * Fixed Fake SMS bug * Fixed numerous other bug reports from previous version FP2: Nokia 6210 Navigator, 6220 Classic, N78, N79, N85, N96 Download:
ActiveFile v1.43.1 BETA update 12 August 2009 Changelog: S60 5th Edition have wrong dependency Single SIS implementation for all S60 platforms Fixed numerous other bug reports from previous version
ActiveFile v1.43 RC1 ActiveFile is a FREE program to browse all folders and files in your mobile phone. Key Features: File management with 2 panels (File manager similar to Total Commander). so, you can view one folder in the first tab and browse to another folder in the second tab File sorting by name, extension, uid, size, date, and ascending, descending Full file management with copy, move, rename, delete, make directory, make file, file properties, and set attributes Compress and decompress file using gzip format Modify the attributes of files and directories Quick check of available storage on your drives Allow multiple instances. So, you can launch ActiveFile more than 1 instance. Searching thru the directories View running processes, tasks, kernel objects, and display system information (phone info and network info) SMS creator tool to create SMS (fake SMS) and save it to a destination folder (Inbox, Drafts, Outbox, Sent folder) without using your sim card credit Capture screenshot and save it to a file in JPEG, GIF, BMP, PNG, and MBM format Memory monitor tool Have an option to access inbox files Add shortcut What's New: S60 5th Edition have wrong dependency Single SIS implementation for all S60 platforms Support for S60 2nd Edition FP3(N70, N72, N90) Fixed numerous other bug reports from previous version Download - [SIGNED] Symbian OS 9.x, S60 rel 3.x & 5 with basic capabilities Download - [UNSIGNED] Symbian OS 9.x, S60 rel 3.x & 5 with extended capabilities Download - [UNSIGNED] Symbian OS 9.x, S60 rel 3.x & 5 with manufacturer capabilities
ActiveFile v1.43 RC2 ActiveFile is a FREE program to browse all folders and files in your mobile phone. Key Features: File management with 2 panels (File manager similar to Total Commander). so, you can view one folder in the first tab and browse to another folder in the second tab File sorting by name, extension, uid, size, date, and ascending, descending Full file management with copy, move, rename, delete, make directory, make file, file properties, and set attributes Compress and decompress file using gzip format Modify the attributes of files and directories Quick check of available storage on your drives Allow multiple instances. So, you can launch ActiveFile more than 1 instance. Searching thru the directories View running processes, tasks, kernel objects, and display system information (phone info and network info) SMS creator tool to create SMS (fake SMS) and save it to a destination folder (Inbox, Drafts, Outbox, Sent folder) without using your sim card credit Capture screenshot and save it to a file in JPEG, GIF, BMP, PNG, and MBM format Memory monitor tool Have an option to access inbox files Add shortcut What's New: S60 5th Edition have wrong dependency Single SIS implementation for all S60 3rd edition platforms (Thanks to DeltaFox for his help!) Support for S60 2nd Edition FP3(N70, N72, N90) Added Check for Updates Added Camera key as screen capture hotkey Fixed bugs switch to fullscreen leads tabs title to corrupt. Fixed bugs creating fake SMS with wrong date/time Fixed bugs restart phone on S60 5th Edition Fixed bugs can't open ZIP file with 3rd party apps Fixed numerous other bug reports from previous version
