Yêu cầu phiên bản Android từ: 2.3 Ảnh chụp màn hình: Over 1600 3D one of a kind, unique styled icons you cant find ANYWHERE else. One of the very best themes for your amazing Android device! ALERT: Jelly Bean users will end up with a broken theme. This is due to a new encryption from Google Play upon download. The launchers must change how themes are coded before this can be fixed. Please email us for a non-encrypted copy using the Gmail account you purchased with. ----- These are 3D!! Very shiny! Glass and glossy like icons, in full sized Hi-Def HD quality. They are big icons! If your launcher of choice allows changing of size, try it! ★ FEATURES ★ - We have a one of a kind "Search" function - This theme contains over 1600 icons!! - They all theme from the drawer! - Can be applied as theme with almost all launchers - 6 Custom Wallpapers - 5 Glass and Glossy Docks - 4 Drawer Backgrounds + The Apps2SD feature is enabled, but is unadvised. ★ HOW TO USE ★ All the instructions are available if you click "OPEN" after download, its very important to follow them! ★ WORKS AS ★ - Go Launcher Theme - ADW / ADW.EX Theme - Apex Theme - Nova Theme - Nemus Theme Icons work with: - TSF Shell - Rabbit Launcher - Panda Home - Atom Launcher - Holo Launcher - Launcher Pro - Crazy Home - dxTop Lite - Open Home - VTL Launcher - Circle Launcher - Desktop Visualizer DVR - Folder Organizer - MX Home - OpenHome 6 - Launcher-X ★ BETTER THAN ALL ★ Completely theme's all system icons on many devices, including: - Jellybean Android - Ice Cream Sandwich - AOSP - AOKP - Honeycomb - Gingerbread - Miui - TouchWiz - CyanogenMod - Sense 2.5 to Sense 4 - If were missing something, please email! ★ LIKE THIS? ★ Please check out our other matching apps! Search for “DCOMOBILE” in the market! We hope you enjoy!! Show us some <3 and leave comments! ★ EXTRA INFO ★ The clock in the screen shots is 'BobClockD3' (free) Pressing 'open' after downloading will only open our info screen. ★ Error with GOLauncher? ★ When you go to manually select an Icon in GO Launcher, to use our amazing organized and searchable index of icons, select the icon above the "reset" button when in the Go selection mode. If your Gallery app opens, you need to "clear defaults" for your gallery app. Using this method to select icons makes it much easier for Go Launcher to load the icons, and much easier to find the icons your looking for. Xem thêm trên Play Store: Mã: [url]https://play.google.com/store/apps/details?id=dcombl.theme.icsplatescubed [/url] Tải về: Mã: [url] http://appstore.vn/a/index.php/home/app/9976[/url]
