ALON Software Contact Guide Pro v1.12 S60v3 SymbianOS9.x Unsigned -GksPDA ALON Contact Guide PRO for S60 3rd/5th Edition is a professional contact manager with call manager included. The application offers full set of actions with contacts: dialing, sending SMS, MMS or e-mail, opening web-browser, quick contacts search, adding and editing contacts, categories support, customization of contacts list and many others. Call manager allows to manage incoming phone calls and assign different actions such as "Send busy", "Mute", "Reply by SMS", "Answer immediately", "Autoresponder", "None" to call groups and to contacts. Please, note that if you have ALON Contact Guide for S60 3rd Edition installed at your phone you need to uninstall it before installation of ALON Contact Guide PRO for S60 3rd/5th Edition. MAIN FEATURES All actions with contacts: dialing, sending SMS, MMS or e-mail, opening web-browser, contacts search, adding contacts, editing, support of categories, etc. Quick contacts search: you may quickly find the required contact even if your contacts database contains thousands of contacts. The detailed contact list contains four tabs: Main, Notes, Photo and Call settings. Support full-screen photos and thumbnails. Customize personal settings: you may make your contacts database looks like you want. Application allows to change colors, font size, sort contacts by first name, last name and company. Customize detailed contact list: you may select the personal information to be shown. OPERATIONS WITH CONTACTS Managing contacts database. You may backup your contacts database, restore contacts, delete contacts, compress your database and find information about it (the quantity of contacts, number of contacts groups, used memory). Sending any contact/categories: you can select any contact or a category to send using SMS, MMS, Bluetooth, IR connection. Set preferred number: select a number for each contact which will appear at the top of detailed contact list. An opportunity of creating a new contact in a certain category. QUICK CONTACTS SEARCH Global search: you may find the contact by any personal information: first and last names, company, job title, phone, note, e-mail, URL, etc. Just type several symbols from any word or number. Language independent search - the fastest way to find the contact entry. Main search helps to find the required contact by first/last name or by company - it uses information from the main contact list and it is the analogue of T9 search. CALL MANAGER Call manager allows to assign different actions such as "Send busy", "Mute", "Reply by SMS", "Answer immediately", "Autoresponder", "None" to call groups and to contacts and manage all incoming phone calls.
ALON Software Contact Guide v1.21 S60v3 v5 SymbianOS9.x -FoXPDA The detailed contact list supports tabs with: main personal info, notes, full-screen photos. All personal info is shown entirely on the screen. Contacts manager gives opportunity to: backup/restore your contacts compress the base of contacts completely delete the base of contacts find out the size of your contact base in the menu item "Contacts info" Contact Guide gives opportunity to send group of contacts/one contact via multimedia, Bluetooth or infrared. Tuning personal settings: Change the colors off odd/even/selected lines Sort contacts: last name, first name; first name, last name Zoom Show/hide company name Show/hide grid Main Search is the quickest way to find the required contact by first/last name or by company - it uses information from the main contact list and it is the analogue of T9 search. Global Search looks through the personal information: you can find the contact by first and last names, company, job title, phone, note, e-mail, URL etc. Language independent search. You may quickly find the contact using Language independent search panel. Features : All types of operations with contacts: Call, SMS, MMS, send e-mail, opening web browser Quick search of the required contact Language independent search Advanced Global search of the contact by any symbols from the personal information Tabs in the detailed contact list Support full-screen photos Support thumbnails Opportunity to select personal info to be shown Personal info is shown entirely Setting preffered number Backup/restore the contacts Get contacts database info Compress the base of contacts The opportunity of reading and editing notes Send the category of contacts or single contact Create a new contact in certain category Sort contacts Zoom Show/hide company name Customize colors Page/line scrolling Whats New : Support touch screen phones Search by "blank" field "Hide" option Improved "backup/restore" option "Sort by company" option Full support of Nokia E90 Improved interface
ALON Software Contact Guide Pro v1.14 S60v3 v5 SymbianOS9.x OVERVIEW ALON Contact Guide PRO for S60 3rd/5th Edition is a professional contact manager with call manager included. The application offers full set of actions with contacts: dialing, sending SMS, MMS or e-mail, opening web-browser, quick contacts search, adding and editing contacts, categories support, customization of contacts list and many others. Call manager allows to manage incoming phone calls and assign different actions such as "Send busy", "Mute", "Reply by SMS", "Answer immediately", "Autoresponder", "None" to call groups and to contacts. MAIN FEATURES * All actions with contacts: dialing, sending SMS, MMS or e-mail, opening web-browser, contacts search, adding contacts, editing, support of categories, etc. * Quick contacts search: you may quickly find the required contact even if your contacts database contains thousands of contacts. * The detailed contact list contains four tabs: Main, Notes, Photo and Call settings. * Support full-screen photos and thumbnails. * Customize personal settings: you may make your contacts database looks like you want. Application allows to change colors, font size, sort contacts by first name, last name and company. * Customize detailed contact list: you may select the personal information to be shown. OPERATIONS WITH CONTACTS * Managing contacts database. You may backup your contacts database, restore contacts, delete contacts, compress your database and find information about it (the quantity of contacts, number of contacts groups, used memory). * Sending any contact/categories: you can select any contact or a category to send using SMS, MMS,BT ,IR connection. * Set preferred number: select a number for each contact which will appear at the top of detailed contact list. * An opportunity of creating a new contact in a certain category. QUICK CONTACTS SEARCH * Global search: you may find the contact by any personal information: first and last names, company, job title, phone, note, e-mail, URL, etc. Just type several symbols from any word or number. * Language independent search - the fastest way to find the contact entry. * Main search helps to find the required contact by first/last name or by company - it uses information from the main contact list and it is the analogue of T9 search. CALL MANAGER Call manager allows to assign different actions such as "Send busy", "Mute", "Reply by SMS", "Answer immediately", "Autoresponder", "None" to call groups and to contacts and manage all incoming phone calls Whats New : * Extended search by letters * Russian virtual keyboard * Auto start option * An opportunity to assign "Mute" to incoming phone calls * An opportunity to make the application system Please, note that if you have ALON Contact Guide for S60 3rd/5th Edition installed at your phone you need to uninstall it before installation of ALON Contact Guide PRO for S60 3rd/5th Edition.
Alon Software Contact Guide Pro v1.14 S60v3 SymbianOS9.x Cr*cked-ErESPDA OVERVIEW ALON Contact Guide PRO for S60 3rd/5th Edition is a professional contact manager with call manager included. The application offers full set of actions with contacts: quick contacts search, dialing, sending SMS, MMS or e-mail, opening web-browser, adding and editing contacts, categories support, customization of contacts list and many other. Call manager allows managing incoming phone calls and choosing individual approach to different calling persons. It will mute the ringer, send busy tone, send SMS, accept the call, play personalized greeting and record message of calling person. Please, note that if you have ALON Contact Guide for S60 3rd Edition installed at your phone you need to uninstall it before installation of ALON Contact Guide PRO for S60 3rd/5th Edition. WHAT IS NEW # Extended search by letters # Russian virtual keyboard # Search by "blank" # Support touch screen phones # Auto start option added. # The option of assigning "Mute" to incoming phone calls. # The opportunity to make the application system. MAIN FEATURES # All actions with contacts: quick contacts search, dialing, sending SMS, MMS or e-mail, opening web-browser , adding and editing contacts, support of categories, etc. # Quick contacts search: you may quickly find the required contact even if your phone book contains thousands of contacts. # The detailed contact list contains four tabs: Main, Notes, Photo and Call settings. # Support full-screen photos and thumbnails. # Customize personal settings: you may make your contacts list looks like you want. Application allows changing colors, font size, sorting contacts by first name, last name and company. # Customize detailed contact list: you may select the contacts' personal information to be shown. CALL MANAGER # Call manager gives opportunity to manage your incoming phone calls and assign different actions such as "Send busy", "Mute", "Reply by SMS", "Answer immediately", "Autoresponder", "None" to call groups and to contacts. # You can create different Profiles to save special settings and activate them according to time. # For the touch screen phones the option “Mute” is not supported for the time being. CONTACTS SEARCH # Global search: find the contact by any personal information: first and last names, company, job title, phone, note, e-mail, URL, etc. Just enter several symbols from any word or number. # Language independent search - the fastest way to find the contact entry. # Main search helps to find the required contact by first/last name or by company - it uses information from the main contact list and it is the analogue of T9 search. OPERATIONS WITH CONTACTS # Managing contacts database. Backup your contacts database, restore contacts, delete contacts, compress your database and find information about the quantity of contacts, number of contacts groups and used memory. # Send any contact or category: you can select any contact or a category to be sent via SMS, MMS, Bluetooth, IR connection. # Set preferred number: select a number for each contact which will appear at the top of detailed contact list. # An opportunity of creating a new contact in a certain category. ADDITIONAL FUNCTIONS # Auto start option. # The opportunity to make the application system. # Backup/restore the contacts, you may compress you contact base to keep it small and get contacts database information. # The opportunity of reading and editing notes from the detailed contact list. # Page/line scrolling of contacts list by Joystick.
ALON Software Contact Guide Pro v1.16 S60v3 v5 S^3 SymbianOS9.x Unsigned -FoXPDA What New : · Extended search by letters, Russian virtual keyboard.
