ALON Software Contact Guide Pro v1.16 S60v3 v5 S^3 SymbianOS9.x Unsigned -FoXPDA Overview : ALON Contact Guide PRO is a professional contact manager with call manager included. The application offers full set of actions with contacts: quick contacts search, dialing, sending SMS, MMS or e-mail, opening web-browser, adding and editing contacts, categories support, customization of contacts list and many other. Call manager allows managing incoming phone calls and choosing individual approach to different calling persons. It will mute the ringer, send busy tone, send SMS, accept the call, play personalized greeting and record message of calling person. Please, note that if you have ALON Contact Guide installed at your phone you need to uninstall it before installation of ALON Contact Guide PRO. Main Features : All actions with contacts: quick contacts search, dialing, sending SMS, MMS or e-mail, opening web-browser , adding and editing contacts, support of categories, etc. Quick contacts search: you may quickly find the required contact even if your phone book contains thousands of contacts. The detailed contact list contains four tabs: Main, Notes, Photo and Call settings. Support full-screen photos and thumbnails. Customize personal settings: you may make your contacts list looks like you want. Application allows changing colors, font size, sorting contacts by first name, last name and company. [*]Customize detailed contact list: you may select the contacts' personal information to be shown. Call Manager Call manager gives opportunity to manage your incoming phone calls and assign different actions such as "Send busy", "Mute", "Reply by SMS", "Answer immediately", "Autoresponder", "None" to call groups and to contacts. [*]You can create different Profiles to save special settings and activate them according to time. Contacts Search Global search: find the contact by any personal information: first and last names, company, job title, phone, note, e-mail, URL, etc. Just enter several symbols from any word or number. Language independent search - the fastest way to find the contact entry. [*]Main search helps to find the required contact by first/last name or by company - it uses information from the main contact list and it is the analogue of T9 search. Operations With Contacts Managing contacts database. Backup your contacts database, restore contacts, delete contacts, compress your database and find information about the quantity of contacts, number of contacts groups and used memory. Send any contact or category: you can select any contact or a category to be sent via SMS, MMS, Bluetooth, IR connection. Set preferred number: select a number for each contact which will appear at the top of detailed contact list. [*]An opportunity of creating a new contact in a certain category. Additional Options Auto start option. The opportunity to make the application system. Backup/restore the contacts, you may compress you contact base to keep it small and get contacts database information. [*]The opportunity of reading and editing notes from the detailed contact list. What New : · Extended search by letters, Russian virtual keyboard.
