ALON Software MP3 Dictaphone -Chương trình nghe nhạc MP3
Thảo luận trong 'ỨNG DỤNG MULTIMEDIA' bắt đầu bởi Be Yeu, 27 Tháng mười 2009.
  1. Be Yeu Super Moderator
    ALON Software MP3 Dictaphone v2.95.2 S60v3 S60v5 SymbianOS9.x *******-Symbian
    [​IMG] [​IMG]
    OVERVIEW
    ALON MP3 Dictaphone supports S60 3rd and 5th Edition phones and consists of four components:
    # Audio player supports MP3, OGG, AAC/MP4/M4A, WMA, AMR, WAV music formats, 3-Band Parametric Equalizer, hot buttons, M3U playlists, bookmarks, sleep timer and many other.
    # Voice dictaphone - the first high-quality MP3 dictaphone which supports AMR and WAV audio formats also. You may easily turn your smartphone into advanced digital dictaphone and start to record lectures, conversations, interviews and then send the records to your PC.
    # Phone calls recorder records phone calls without beeps in MP3, AMR and WAV formats. You'll to save lots of memory space by keeping your records in MP3 - the most popular audio format.
    # Internet radio is free even after expiration of trial period.
    WHAT IS NEW
    # Improved recording for N95 8GB
    # Support new phones
    # Improved Internet Radio
    # Improved 5800 and N97 usability
    # Support reading WAV format from PC
    # 5800 XPressMusic support.
    # Fixed call recording bugs.
    # Auto archive of recorded phone calls.
    # Expanded support of sample rates for recording (from 8kHz to 48kHz depending on phone model).
    # Now you may record phone calls without beeps!
    # Append option for recorded files.
    # An opportunity of recording phone calls in MP3 format.
    # Bookmarks. Now you may add/edit/delete bookmarks.
    # Sleeping time option for playback.
    # Free Internet Radio! You may use Internet Radio for free even after expiration of trial period!
  2. Còm.
    Còm. Giả Vờ Hết Staff Member
    Alon Software MP3 Dictaphone v2.98 S60v5 SymbianOS9.4 Unsigned Cr.acked-ErESPDA
    ALON MP3 Dictaphone (S60 5th and 3rd Edition)
    Overview :
    The application consists of four components:
    Voice dictaphone - the first high-quality MP3 dictaphone which supports AMR and WAV audio formats also. Turn your smartphone into advanced digital dictaphone and start to record lectures, conversations, interviews and then send the records to your PC.
    Phone calls recorder records phone calls without beeps in MP3, AMR and WAV formats. It saves lots of memory space by keeping your records in MP3 - the most popular audio format.
    Internet radio.
    Audio Player
    MP3, OGG, AAC/MP4/M4A, AMR and WAV music formats.
    M3U playlists support. Use Winamp playlists and use playlists created at your phone at Winamp player.
    Manage your playlists - add or remove tracks, save, load and delete playlists.
    Pause and resume playback during/after incoming calls. Keep listening to music.
    Choose any folder and all its subfolders for playback.
    Manage the colors at playlist.
    Voice Dictaphone
    Dictaphone saves lots of memory space by keeping you records in MP3 format.
    Supports AMR and WAV formats also.
    Choose the type of gain control: automatic, manual or select one of four positions of microphone gain before recording.
    Move, rename, delete and send your recordings.
    Append a record to the end of track.
    Choose important parts from your records and cut all the rest.
    Phone Calls Recorder
    Supports MP3, AMR and WAV formats.
    No beeps recording.
    Automatic and manual gain control.
    Internet Radio
    Manage your favorite Internet radio stations.
    Enjoy Internet radio without any limitation.
    Additional Options
    Hot keys.
    Advanced 3-Band Parametric Equalizer.
    Sleep timer.
    Bookmarks.
    What New :
    Improved user interface for touch screen phones.
    Added Farsi languag​
  3. Khỉ Con
    ALON Software ALON MP3 Player v1.00 S60v3/v5 SymbianOS9.x Signed Retail by Alireza
    Overview:
    ALON MP3 Player is an audio player which supports MP3, OGG, AAC/MP4, AMR and WAV formats, 3-Band Parametric Equalizer, M3U Playlists and hot buttons.
    Audio Player:
    -High-quality stereo playback.
    -Pause and resume playback during/after incoming calls. You can keep listening to music.
    -You may choose any folder and all subfolders from any location on your phone for playback.
    -Organize your own music library by creating the folders with your favourite tracks.
    -Choose the way of playing the list: play track, loop track, loop playlist, randomize.
    -An opportunity of interrupt/not interrupt playback by incoming messages.
    M3U Playlists:
    -Support M3U playlists. You may both use Winamp playlists on your phone and use playlists created at your phone at Winamp.
    Hot Buttons:
    -You may sign all actions such as play, stop, pause, forward rewind, back rewind, on/off equalizers, switching between playlist and equalizer to hardware buttons.
    Internet Radio:
    - Easy to use interface.
    - Internet radio is free.
    Equalizer:
    -With 3-Band Parametric Equalizer you may easily adjust playback as you like.
    -Player saves your presettings for equalizer. You may adjust playback as you want and don't use equalizer at the next time.
    [URL="http://www.box.net/shared/4dchtj5odc"]http://www.box.net/shared/4dchtj5odc[/URL]
