Yêu cầu phiên bản Android từ: 2.1 Ảnh chụp màn hình: Andmade Share Pro is the advanced share application. It replaces the system share menu with the new one with many usable features. Just share and enjoy! Basic features: - Share to multiple applications at a time. - Reorder the share list with drag&drop. - Hide unused elements from the list. - Fast share to Evernote. - Set the default address to which your e-mails will be sent. Pro version features: - Group several apps to share in one click. - Fast share to e-mail, Twitter, Facebook. - Use fast share even without internet - all messages will be sent when you connect to network. - Fast share via Wi-Fi only option. - Copy text to clipboard option (You can use this for apps which do not support sharing) Don't forget to set Andmade Share as default on the first use. WARNING: Some apps don't use standard share feature but instead make their own share list. This makes impossible to set Andmade Share as default. But you can still use Andmade Share by clicking on it in the list of such apps. We hope it doesn't affect user experience much. If you are not sure to buy please try the free version of Andmade Share first. If you already use the free version of Andmade Share please note Pro version doesn't replace it automatically. Xem thêm trên Play Store: Mã: [url]https://play.google.com/store/apps/details?id=com.andmadesoft.share.pro [/url] Tải về: Mã: [url] http://appstore.vn/android/home/app/8556[/url]
