Yêu cầu phiên bản Android từ: 2.0 Ứng dụng bao gồm rất nhiều công cụ quản lý hệ thống như quản lý bộ nhớ ram,CPU, quản lý tác vụ... Ảnh chụp màn hình: Thông tin chi tiết: Top 17 features to help you easily and efficiently manage your android phone.Android Assistant is one of the most powerful and comprehensive management tools to improve your android phone's performance. It speeds up your phone's running speed and saves battery. 【Top17 features】 1. Monitor status (cpu, memory, battery) 2. Process Manager (Auto Boost and Quick Boost can distinguish different types of processes thus will not kill fatal system processes and apps in Ignore List.) 3. Cache Cleaner 4. System Clean(Browser History, Clipboard, Market History, Gmail History, Google Earth History, Google Map History) 5. Save Battery Settings(bluetooth, wifi, gps, auto-sync, orientation, haptic feedback, screen brightness, timeout) 6. File Manager 7. Startup Manager 8. Batch Uninstall 9. Battery use 10. Volume Control 11. Ringer 12. Startup Time 13. Startup Silent(Menu->Settings->Startup Silent) 14. System Info 15. Widget(Quick Booster[1,4], Shortcuts[4]) 16. App 2 SD(Support android2.2 and later):Get more free internal phone storage space 17. Batch Installation 【Common Problems】 Q: Why not support move to sdcard? A: Because the system bug moved to sdcard will not be able to use widgets. Q: Why "App 2 sd" not working? A: "App 2 sd" feature is only supports android2.2 and later. For any other questions or suggestions please email to crazymobile.wind @ gmail.com. KW: task kill taskkill ATK app killer tool tools taskmanager task manager system panel systempanel process manager processmanager memory taskpanel task panel Advanced Process android 2.3 Android Assistant Xem thêm trên Android Market: Mã: [URL]https://market.android.com/details?id=com.advancedprocessmanager&feature=search_result[/URL] Tải về: Mã: [URL]http://appstore.vn/a/index.php/home/app/900[/URL]
