[ROM] [AOSP][4.1.1] ★★★ BlackCNA v2.1 ★★★ [AROMA][OTA][27-09-12]
Thảo luận trong 'SAMSUNG' bắt đầu bởi hbs2tkr, 23 Tháng chín 2012.
  1. hbs2tkr Thành viên
    Video về rom
    Changelog :
    BlackCNA v2.1
    updated with latest CM10 sources
    added force tablet mode UI and dpi change (Settings -> Interface -> Gerneral UI)
    added alternate signal layout (Settings -> Interface -> Status bar)
    add alow mock sms to developer settings
    increased themeability of the statusbar
    added the advanced calulator features from cm
    updated Gapps (hope google search is fixed)
    BlackCNA v2.0 "AROMA birth"
    Complete clean compiled build for n7000 !!!
    no port anymore
    added AROMA installer (to much you will see)
    added OTA update in apps
    updated AOSP base to 4.1.1_r6 (JRO03R)
    seperated the ability to center the lock screen widgets and the lock screen targets widget
    better performing wifi connection
    wifi will no longer avoid poor connections if not connected to a mobile network
    HTML 5 video user experience and stability fixes and network optimizations
    better text rendering
    enabled fdatasync for SQLite
    added theme, smiley, emoji, strip unicode and date support for Mms Quick Message
    added sms over bluetooth (i.e. ability to read sms via car stereo)
    added feature to configure wifi idle timeout (Entropy512)
    added the ability to have up to 5 customizable ring targets (Steve Spear)
    lockscreen widgets can now be on the right, centered, or on the left (FaultException)
    added timer snapshot support to the camera (Jonathan Steadman)
    added burst mode to the camera (Jared Caliendo - up to 20 pictures at a time)
    added jpeg quality settings to the camera (Jared Caliendo)
    added settings for enabling and disabling WebGL in the browser
    added AOKP lockscreen weather icons
    added option for preloading media in the browser
    better multilanguage support
    moved ring targets feature into the navigation bar settings
    re-organized all phone settings
    power widget no longer shows data options if they arent supported
    added landscape layout for the color picker
    fixed weird black line about Mms text feild
    fixed small down arrow when keyboard is up and phone is in landscape
    fixed wi-max power widget toggle
    fixed export-to-storage function in contacts
    bluetooth audio streaming should be fixed across all music apps and hardware
    fixed tethering issue that was occurring on some devices
    reverted to previous CPU Settings while preserving the new voltage settings
    automatic lock screen weather refresh will no longer cause freezes
    and more i forget...
    BlackCNA V1.2 "DarkNess"
    Added new keyboard
    Revised systemui
    Added more Note 2 smoothness ;)
    USB Mass Storage enabled thx neobuddy89
    Bluetooth fixed (I hope so report back please)
    Added new Dialer (S3 themed) thx tunsd
    Added new BlackCNA Gapps (too much u will see) thx tunsd
    Fixed Google Now
    Added latest CM10 Camera
    Revised framework
    Added Apex Launcher
    Some cosmetic changes
    New wallpaper
    and things i forget...
    BIG THX TO THE COMMUNITY FOR SUPPORTING US!!!
    Cách up rom
    NOTE : yêu cầu máy đã root và cài cwm
    1. Vào Recovery bằng cách bấm và giữ 3 phím Home + power + volum up
    2. Full wipe nếu như bạn ở 1 rom nào khác ( wipe date/factory reset . wipe cache . wipe davik )
    3. Flash Rom BlackCNA
    4. Fláh Gapp
    5. Reboot.
    Link down Rom và Gapp
    ROM BlackCNA v2.1
    Gapp
    Tính năng ROM:
    Based off of Clean Android 4.1.1 Rev4 (JRO03L)
    File Manager Included
    T-mobile Theme Manager (tmobile, CyanogenMod, xoomdev)
    T9 Dialer/Landscape/Dialpad Settings (CyanogenMod)
    Trebuchet Custom Launcher (CyanogenMod)
    Ability to set custom ringtone delay (in phone settings - Netboy)
    Framework: added support for caller name display (kenshin)
    Framework: added HSPA+ support (shows H+ icon on status bar when connected to hspa+ - Bajee11)
    Framework: ability to set custom carrier label (Netboy)
    Browser: option open tab in incognito mode (Arham Jamal)
    Browser: option to close all other tabs (Arham Jamal)
    Browser: unhid the user agent settings
    DeskClock: added stopwatch and countdown timer (Jorge Ruesga)
    DeskClock: added settings to do nothing/snooze/dismiss and alarm by flipping the device (maurodec)
    DeskClock: you can set an alarm to switch your profile (jorge ruesga)
    Email: added meeting time to email invitation tab (erezak)
    Keyboard: ability to use the volume buttons to move the cursor (romanbb)
    Bluetooth: AVRCP 1.3 (Trey Briggs)
    Settings: ADB over Network (enable TCP/IP debugging over Network interfaces (WiFi, Usb networks)
    Settings: Added option to disable volume adjustment sound (Settings -> Sound - StevenHarper)
    Settings: Option to change the devices hostname
    Settings: Hardware info in about phone (romanbb)
    Custom Camera App: (CyanogenMod)
    - Continuos focus
    - Iso Support
    - Support for red eye reduction
    - Ability to use the power button to take pictures
    Customizable Messaging App:
    - Added the ability to display a pop-up QuickMessage when an Sms message is received (DvTonder)
    - Added call sender and quick reply notification actions (DvTonder)
    - Added Emoji patch from CM MMS app (Robert Burns)
    - SMS Templates (rciovati)
    - Custom Vibrations (mssmison)
    - Timestamp Options (aravance)
    Customizable Phone App (CM)
    - Advanced Phone settings (optional vib on outgoing or incoming call or every 45 seconds)
    Customizable Power Menu (codenamedroid)
    - Reboot Menu
    - Profile Switcher
    - Screenshot
    - Airplane Mode
    - Navigation bar toggle
    - Silent toggle
    Customizable Status Bar: (Miui, CyanogenMod, romanbb, sethyx, kejar, syaoran12 ,romanbb, Stevespear426, Kyle Teague, Whitehawkx)
    - Battery Icon style
    - Battery Icon in notification bar
    - Miui style battery bar
    - Clock style
    - Customizable Clock Color
    - Clock Am/Pm style
    - Clock Day of the Week
    - Customizable Signal Text
    - Customizable WiFi Signal Text
    - Ability to slide your finger across the status bar to control brightness
    - Notification counter
    Customizable Notification bar:
    - Notification bar Power Widget (Cvcps, DvTonder – CyanogenMod)
    - Notification bar Toogles (AOKP - romanbb)
    Customizable Navigation Bar: (Zaphod-Beeblebrox, KhasMek, romanbb, akellar)
    - Ability to enable/disable the navigation bar (enable toggle in power menu settings)
    - Customizable navigation button actions
    - Custom navigation bar ring targets (Team Eos, modified by Codenamedroid)
    - customizable navigation bar color (Team Eos, modified by Codenamedroid)
    - Customizable navigation button and button glow color
    - Menu button visibility and location
    - Number of navigation buttons
    - Order of navigation buttons
    - Navigation bar size
    - Navigation bar transparency
    Customizable Lockscreen:
    - Up to eight configurable lockscreen targets (Codenamedroid)
    - Added optional centered lockscreen layout (Codenamedroid)
    - Optional centered lockscreen clock
    - Option to disable vibration on the lockscreen (StevenHarper)
    - Customizable number of lockscreen targets (CyanogenMod)
    - Configurable lockscreen wallpaper (Danesh M)
    - Option to always show lockscreen battery (Blunden)
    - Add weather to the lockscreen (DvTonder, Danesh M, Marius Volkhart, Rick C, Aokp)
    - Add calendar reminders to the lockscreen (David Morgan)
    - Lockscreen before secure unlock (Danesh M)
    - Ability to unlock with menu (CyanogenMod)
    - Quick pin unlock (unlock with pin/password without pressing ok – CyanogenMod)
    Customizable Sound Settings:
    - Customizable volume panel (Stevespear426)
    - Configurable ascending ringtone (Danny Baumann)
    - Safe headset volume (CyanogenMod)
    - Volume rocker music controls (CyanogenMod)
    - Ability to customize action taken when connecting a headset (syaoran12)
    - Face down actions (syaoran12)
    Customizable Display Settings: (CyanogenMod)
    - Customizable Rotation Modes
    - Volume wake (tap either the up or down volume key to wake your phone from sleep)
    - Volume music controls (long press volume buttons to skip tracks)
    Custom Profiles (CyanogenMod)
    - assign different profiles to change the behavior of your phone to your liking
    Quiet Hours (CyanogenMod)
    - the ability to set when notification sounds, haptic feedback, vibration and notification light will function[/color]
    Performance Settings:
    - Start-up tweaks (kejar, Jrummy)
    - Processor Speed (xoomdev)
    - Voltage controls (xoomdev)
    - Kernel controls (kejar, Jrummy)
    Developer Options:
    - Propmodder (Jdkoreclipse)
    - Spare Parts
    - Development app
    - Testing Settings
    Theme changes:
    - It´s too much you will see it...
    Kernel:
    - Latest HydraCore STD kernel 4.3b (g.lewarne)
    Extras:
    - SuperSU
    - Busybox
    - Bash
    - Nano
