Application Folder giúp bạn thay đổi icon mặc định của thư mục trên máy, ngoài ra Application Folder còn hỗ trợ hiển thị số lượng app có trong thư mục. Make your own pretty folders! This application provides folders in your home with pretty icons. Unlike default android folder, this is very easy and pretty and you can change the folder name and icon. For the convenience, application folder shows the number of application as a badge. Just take a look at screenshots! A folder can contain applications, bookmarks, or contacts (Whenever you create a folder, the folder basically contains "setting icon" for further customization - in case of folder 2, setting icon is located on window caption) Xem thêm: Mã: https://market.android.com/details?id=personal.jhjeong.app.appfolder&feature=search_result Tải về: http://appstore.vn/a/index.php/home/app/1936
What's in this version: 2.6.2 Shortcut item bug fixed About 30 icons added Honeycomb compatible Mac folder redesigned (Limit height and changed BG pattern) Minor bug fixed.
