AutoKill Task Manager Pro v1.0.12 - quản lý tác vụ
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 1 Tháng mười 2011.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 1.6
    Ảnh chụp màn hình:
    Thông tin chi tiết:
    Auto Kill Task ManagerPlease buy "AutoKill Task Manager Pro Key" for the pro version.
    "AutoKill Task Manager" is an app manager tool which can kill running apps to speed up your device and save your device's battery life.
    It is "Auto Kill" enabled task killer which can help reduce your efforts to kill apps manually.
    We think it is the best battery saver tool for you on android market.
    !!!!! IMPORTANT !!!!!
    Add your important apps to ignore list to avoid to be killed by "AutoKill Task Manager". (MENU -> Ignore List)
    KW: Task Killer, Task Manager, Battery Saver, Save Battery, AutoKiller, App Killer, App Manager, Kill Apps, auto kill
    Xem thêm trên Android Market:
    [URL="https://market.android.com/details?id=com.droiddev.killer&feature=also_installed"]https://market.android.com/details?id=com.droiddev.killer&feature=also_installed
    [/URL][URL]https://market.android.com/details?id=com.droiddev.unlocker_killer&feature=search_result[/URL]
    Tải về:
     [URL]http://appstore.vn/a/index.php/home/app/2056[/URL]
