Avis Quick Redial. Version 0.1.2 S60v3 v5 Symbian 9.x Unsigned Freeware Description: Quick repeat of number dialing, when line is busy. Th inbuilt autoredial function increase delays between every next dial - that is not good in some cases. This program will redial as fast as it possible. And don't forget to disable the inbuilt fredial function. Program is started right after installin. To disable program and remove it from autostart list - just run it again from shortcut. And when it disabled - starting from shortcut will return its function back to work. # Features: samll size and no interface; # quick auto redial, when line is busy or no answer; # configurable autostart. (You must sign-up this file or install on unprotected phone)
Avis Quick Redial. Version 0.1.3 S60v3 v5 Symbian 9.x Unsigned Freeware Description: Quick repeat of number dialing, when line is busy. Th inbuilt autoredial function increase delays between every next dial - that is not good in some cases. This program will redial as fast as it possible. And don't forget to disable the inbuilt fredial function. Program is started right after installin. To disable program and remove it from autostart list - just run it again from shortcut. And when it disabled - starting from shortcut will return its function back to work. # Features: samll size and no interface; # quick auto redial, when line is busy or no answer; # configurable autostart. Changes in 0.1.3 fixed bug when deismiss incoming call; [*]disabled use of Red button emulation - more stable, but slower. (You must sign-up this file or install on unprotected phone)
