Battery Calibrator Donate 2.1.9 - tiện ích rất cần thiết cho pin
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 14 Tháng chín 2011.
  1. Khỉ Con interista
    Yêu cầu: Máy đã Root.
    Battery Calibrator được viết không phải với mục đích làm tăng tuổi thọ pin của bạn, Battery Calibrator có tác dụng xóa sạch mọi thông số, lịch sử sử dụng pin. Điều này giống như việc bạn vào chế độ Recovery của máy và chọn "wiping" mọi thông số về pin.
    [​IMG][​IMG]
    *NOTE* This app DOES NOT ruin your battery life! It simply deletes the battery stats so you can start fresh and get an accurate reading! It does nothing to your battery life! It is the same as going into recovery mode and wiping batterystats. It will not make your battery last longer!
    I made this app because other calibration apps would not work for me. By installing this app you will not hold me responsible if anything happens.
    Please don't rate 1 star if you are not rooted and it doesn't work.
    If you have any problems with this app please email before you rate low!
    Use this app to calibrate your battery after you flash a new rom. You can also use this if your battery level reads wrong and is not accurate. Sometimes our phones will shut off at only 15%. With this app you can calibrate your battery so you get an accurate reading on the remaining level.
    There is an about menu in this app for answers to certain questions asked about the app and also letting you see your battery history.
    Root permissions and busybox are required for this app to work. If you don't know what root is, then you probably shouldn't download this app.
    Xem thêm:
    https://market.android.com/details?id=com.liteup.calibratebattery&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/2285
