Battery Indicator Pro 4.0.3 - xem trạng thái pin
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 13 Tháng chín 2011.
  1. Khỉ Con interista
    [​IMG][​IMG]
    Battery Indicator Pro - Always know your exact battery level with one glance.
    Battery Indicator Pro shows your battery charge level (percent) as an icon in your status bar, with temperature, health, voltage, and time since plugged / unplugged in the notification area. Now has an alarm feature.
    Features:
    • Fully configurable green, amber, red, and black icons
    • Estimated charge / discharge time left
    • Battery logging. You can log the battery state (charge, status, voltage, temperature) and browse the logs on the phone or export to CSV.
    • Manually or automatically disable / reenable device lock screen / lockscreen / keyguard
    • Alarms (full, charge above X, charge below X, temperature above X, or health failure)
    • Themes for main window
    • Lots of configurability; most features are optional
    • Very lightweight (please email me if you think otherwise, and I'll help you figure out what's wrong — I promise this app will not drain your battery.)
    • Open source
    Limitations:
    • Motorola Droids and Samsung Moment only show every 10%
    • It's not possible to replace the built-in battery icon
    Xem thêm:
    https://market.android.com/details?id=com.darshancomputing.BatteryIndicatorPro&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/2270
