Yêu cầu Android: 1.5+ Tính năng chính của ứng dụng: Hiển thị dung lượng sử dụng pin Tính toán những việc bạn có thể làm với lượng pin còn lại Mọi thông số đều ở dạng biểu đồ, trực quan Thông báo khi pin còn ít Xả pin, xóa thông số pin ... http://appstore.vn/a/index.php/home/app/117
Cập nhật 1.8.1 What's in this version: 1.8.1: Fixed missing widget settings (sorry)! 1.8: New Sense 3 widget layout More phones supported 1.7.7: Fixed crash on Android 1.5 (very sorry) 1.7.6: Fixed system buttons failing after graph zoom/scrolling All system buttons are now directly on main screen 1.7.5: New languages: Czech and Swedish Improved calibration screen 1.7.4: Fixed graphics in widgets Added Portuguese language New Calibration screen New phones supported
Cập nhật 1.8.5 What's in this version: 1.8.5: EMERGENCY RELEASE - FC reported 109 times in the past 24 hours, but hidden with old reports! Sorry for the delay! Fixed FC when app has been killed (low memory conditions or task killer) and then refreshing a graphic widget! Added option for mA corrections needed on HTC Sensation > fixes mA in standby mode, can be used on other phones! > Check monitoring settings to activate option! Improved overall monitoring performance! > Please report any new issues with mA reporting <-
What's in this version: 1.8.6: Added total capacity (mAh) measures in calibration screen Replaced widget with nice battery icon in main screen Fixed scales when widget label is removed
What's in this version: 1.8.7: Improve history display Better support for Droid3 Enhanced estimates loading New use-time estimates screen
What's in this version: 1.8.9: Works again on 1.5 (very sorry) Fix widget scale not updating 1.8.8: Better support for Dronix Improve right scale drawing Fix calibration screen
Cập nhật 2.6.4 Add BLUETOOTH permission to cope with ICS bug reading battery stats on some devices. App DOES NOT actually use BLUETOOTH at all! 2.6.4: New support for new HTC One S models New support for Atrix HD reversed mA (please report if wrong) New 4x2, 5x1 and 5x2 graphic widgets (pro only) Fix possible FC in estimates screen Fix temperature decimals being lost 2.6.1: New scale themes: white, yellow, orange and auto Fix repeating full charge alarms on HTC devices Support for HTC One V and Galaxy Tab 2
cập nhật 2.6.5 2.6.5: Add mA support for Photon Q and Galaxy Note 2 Update Full mA icon packages to support upto +/-2000mA 2.6.4: New support for new HTC One S models New support for Atrix HD reversed mA (please report if wrong) New 4x2, 5x1 and 5x2 graphic widgets (pro only) Fix possible FC in estimates screen Fix temperature decimals being lost
cập nhật 2.6.6 2.6.6: Adds support for Galaxy Tab 7+, RAZR HD, Note 10.1, LG LTE2 and HTC T328W 2.6.5: Add mA support for Photon Q and Galaxy Note 2 Update Full mA icon packages to support upto +/-2000mA
