[Công cụ-Hệ thống] Battery Saver Du+Switch Widget v2.1.0 pro mới I:Tăng thời gian pin từ nửa ngày lên 4 ngày k nói ngoa
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi pretty.boy70, 5 Tháng ba 2013.
  1. pretty.boy70 Thành viên
    Battery Saver Du+Switch Widget v2.1.5 pro mới I:Tăng thời gian pin từ nửa ngày lên 4 ngày k nói ngoa
    Để tên bài như thế thật là khó tin phải không các bạn?! Nhưng đó là sự thật & mình chẳng nói xạo...nếu bạn không tin thì mời bạn vào user review trên gg play xem họ bình luận thế nào rồi download về cài trải nghiệm rồi hãy ném đá chủ topic nhé...
    Sau đây trích 1 vài user review trên gg play: (https://play.google.com/store/apps/...wsMSwxLDEsImNvbS5kaWFueGlub3MuZHhicy5wYWlkIl0)
    Donald Phillips - January 21, 2013 - Galaxy Precedent with version 2.1.0.pro
    As Avertised!!
    Great App! Is it possible to report just what apps are doing when they launch themselfs univited?? Thanks
    Spam
    Olivia Williamson - February 21, 2013 - Samsung Galaxy S2 with version 2.1.0.pro
    Brilliant
    Extending my phone's battery life from an average of one and a half days to an average of 4 days, this app does exactly what it promises, quietly and perfectly.
    Spam
    David Cruz - February 3, 2013 - LG Optimus One with version 2.1.0.pro
    Very Accurate
    I downloaded last night,woke up this morning & my battery seems to not lose life as quickly keep up the good work for further future updates KingCruz
    Spam
    Cristian Kiss - February 25, 2013 - Version 2.1.0.pro
    Error
    1. Cant find to add this app to my white list. 2. Don't auto kill applications that run in background after 5 min. Samsung Galaxy Advanced
    Spam
    Ryan Gates - February 25, 2013 - Version 2.1.0.pro
    Rooted Samsung Galaxy Note 2
    Love the app, works great but the lower cpu isn't working.
    Spam
    Abdul Aziz - February 28, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
    Nice thing
    Firstly I doubt on this product but after installing it I come to know that it is superb thing
    Spam
    Huy Truong - February 22, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
    Fantastic!
    I've always loved this app. Quite sad when they removed from the market for a while. When I saw this again, I instantly jumped on it! Does what it says, well done.
    Spam
    Yessica Lima - January 30, 2013 - Version 2.1.0.pro
    Great!!
    It's very clean and easy to use, definitely recommend.
    Spam
    Jignesh Shah - February 19, 2013 - SEMC Xperia S with version 2.1.0.pro
    Gives 10% improvement
    Good app. Gives 10% improvement. Recommended for sure. I bought paid version.
    Spam
    A Google User - March 2, 2013 - Version 2.1.0.pro
    Excellent
    Excellent
    Hầu hết đa số đều là review tốt...vậy tại sao không download về cùng cài trải nghiệm thử?
    Quay lại app, mình xin giới thiệu vài tính năng chính:
    ★ Chẩn đoán pin một cách hết sức rõ ràng & thật là không thể tin được tiết kiệm pin.
    ★ Chế độ chuyển đổi thông minh: ví dụ
    - Điều chỉnh để chờ dài trên mức pin thấp;
    - Đi vào chế độ cài đặt trước của bạn theo lịch trình của bạn;
    ★ Sạc kéo dài tuổi thọ pin. (ví dụ như gợi ý để sạc hoặc khi nào nên cắm sạc).
    - Ra mắt Du Battery Saver để bắt đầu sạc khi pin thấp hơn 20%.
    - It nhất 1 quá trình sạc đầy để kéo dài tuổi thọ pin.
    ★ Thường xuyên đóng những app chạy ngầm không cần thiết;
    - Thiết lập khoảng thời gian các nhiệm vụ nền làm sạch;
    - Cần để lại một số ứng dụng chạy nền? Thêm chúng vào danh sách bỏ qua.
    ★ Giảm xung CPU khi tắt màn hình (ROOT thiết bị);
    === Tính năng đã có ===
    ✔ 3 Widgets mạnh mẽ:
    - One-tap tối ưu hóa (task-killer)
    - Thiết kế pin hiển thị và chuyển đổi chế độ mới
    - Công tắc mở tắt cao cấp
    Đây là cách tiết kiệm pin dễ dàng bằng cách sử dụng tiện ích pin 1 tap, và kéo dài thời gian sử dụng hơn 15% bằng cách chuyển sang chế độ tiết kiệm pin, cũng đi với 1 tap widget mạnh mẽ.
    ✔ Tối ưu hóa sử dụng pin của bạn trong 3 chế độ cài đặt sẵn:
    - Mode (chức năng cơ bản, đáp ứng nhu cầu tiết kiệm pin bình thường);
    - Chế độ chờ (Đóng tất cả ngoại trừ quay số và SMS, kéo dài thời gian pin cho thời gian chờ dài nhất);
    - Sleep Mode (Đóng tất cả trừ đồng hồ, tiết kiệm pin rất nhiều trong khi ngủ);
    ✔ Tùy chỉnh chế độ của bạn, thiết lập bất cứ điều gì bạn thích và tìm hiểu một trong những phù hợp nhất!
    ✔ Pin chỉ số, pin Cấp% trong thanh trạng thái sẽ chuyển sang màu đỏ khi <20%;
    ✔ Báo cáo dự kiến thời gian còn lại;
    ✔ Ringtone nhắc nhở cho tình trạng pin khác nhau;
    ✔ Chi tiết phân tích điện năng tiêu thụ, không chỉ các ứng dụng, mà còn là phần cứng (CPU, màn hình, cảm biến, WiFi, radio), pin theo dõi chuyên nghiệp nhất (pin thông báo) cho đến nay;
    Hình ảnh về app:
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Chi tiết:
    https://play.google.com/store/apps/...wsMSwxLDEsImNvbS5kaWFueGlub3MuZHhicy5wYWlkIl0.
    Link Kleii / Mega tốc độ cao:
    Battery Saver Du+Switch Widget v2.1.5.pro apk (mới nhất trên gg play)
    Battery Saver Du+Switch Widget v2.1.0.pro apk (mới nhất trên gg play)
    ChiêuTrúc and tancuongbt like this.
  2. tancuongbt
    tancuongbt Thành viên
    Để thử xem thế nào? Thank................
    pretty.boy70 thích bài này.
  3. pretty.boy70
    tancuongbt thích bài này.
