Yêu cầu phiên bản Android từ: 2.1 Ảnh chụp màn hình: Thông tin chi tiết: Battery Spy allows you to monitor your Android device's battery level by reporting the current percentage, and providing more detailed information such as charge rate, temperature, voltage and usage times. The current battery percentage level is displayed on the notification bar. Additional statistics are shown in the notification bar pull down, and even more insight into your battery charge and usage history in the main application screen. Battery Spy works simply by gathering battery statistics that are already available in the Android OS. What you see is what the OS reports. Battery Spy gathers up the information, organizes it, then displays it in a graph and tables for you. It also uses the information to give you an estimate of time left on battery or to full charge. Statistics are gathered and saved over a settable number of days so you can review them at any time. Key features include: 1. Support for multiple battery profiles so you can differentiate between OEM or backup (after market) batteries, and different usage styles such as work, weekends and vacation. Create as many profiles as you want and quickly switch between them. This feature is available during the trial period, then only with the full license after. 2. Enable notifications for when the battery level rises above or falls below a settable percentage. This feature is available during the trial period, then only with the full license after. 3. Enable notifications for when the battery temperature rises above or falls below a settable degree. This feature is available during the trial period, then only with the full license after. 4. Quick access to settings that directly affect battery use so you don't have to hunt them down when you need them 5. Tap on the statistics table to go directly to the Android Battery Use screen. 6. Configurable graph that supports both 2D and 3D presentations. 7. Low CPU and resource consumption to not add (too much) to battery drain. 8. Run as a service when phone starts up, or manually. Try Battery Spy free for 10 days and keep using it after the trial period as a free license with reduced functionality, or purchase the full license to unlock the application to its full functionality. Even without the full license features, Battery Spy still provides a rich feature set for the casual user. Please keep the comments coming. Your input really helps to make the software better. If you have bugs or concerns, please email cmai@vertiform.com and it will be handled promptly. Thanks! Version 1.0, Revision 5 Release Notes Fixed "time counter when device is running on battery keeps on resetting" issue. Android OS was closing and restarting the Battery Spy service during resource management. The service now requests that OS does not release it unless device is very low on memory. Hope this helps those who are experiencing problems with the battery in use time. We are continuing to monitor this issue if it regresses. Xem thêm trên Android Market: Mã: [URL]https://market.android.com/details?id=com.vertiform.android.app.batteryspy&feature=search_result[/URL] Tải về: Mã: [URL]http://appstore.vn/a/index.php/home/app/1102[/URL]
