BeyBlade HD v0.8.1b
Thảo luận trong 'Android: Trò Chơi' bắt đầu bởi share59, 29 Tháng chín 2011.
  1. share59 Thành viên
    BeyBlade HD v0.8.1b
    Requirements: Android 2.0.1+
    Overview: The first BeyBlade game on android.
    [break]
    This is Beta demo of the game, full version will be released later.
    Battle against other BeyBlades. You can select many different parts and build your custom BeyBlades, and then battle with them in a quick match or maybe in a tournament.
    With realtime physics the matches will never go same way, and the BeyBlades will behave realistically when they are hit.
    Features:
    *Good performance, 60 fps even on mid-range devices
    *Quality graphics
    *Realistic physics
    *Dynamic camera in matches
    *Soundtrack with almost 20 songs
    *Many BeyBlades and parts (more coming in the full version)
    *Many BeyBlade battle stadiums
    *No ads
    Requirements:
    *Android 2.0.1 or higher
    *800x480 resolution (works best) or bigger (320x240 can be played, but more bugs)
    We are still fixing the bugs and adding more content in the game.
    If you find a bug you could tell us what happened, so we can try to fix it.
    And if the game doesn't work, instead of just giving a bad rating tell us the device you are using and does it crashed or something else.
    A short description could help us solve issues with the game.
    The game is a bit slow to load on start so be patient.
    tested on: Archos A70, Samsung Galaxy S
    If you like the game please rate =).
    More Info:
    https://market.android.com/details?id=com.CyberWere.BeyBlade&feature=search_result
    Download Instructions:
    http://depositfiles.com/files/kny50wbbx
    Mirror:
    http://hotfile.com/dl/130998252/215b7eb/BeyBlade_v0.8.1b.apk.html
  2. Khỉ Con
