Bubble Pro Live Wallpaper v1.2.7
Thảo luận trong 'Android: Giao Diện, Trang Trí' bắt đầu bởi Khỉ Con, 14 Tháng mười 2011.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.1
    Ảnh chụp màn hình:
    Thông tin chi tiết:
    A fun bubble live wallpaper let you poke your friends to improve affection:)(Note: please read FAQ below first if you have problems)
    A fun bubble live wallpaper where you can tap bubbles to burst.
    Now you can customize both background and bubble image from your gallery, choose your lucky color theme and poke your friends to improve affection:)
    You can also change different themes, bubble colors and number of bubbles floating. More features will be added in the future.
    Features
    - Custom bubble image (Up to 3 images)
    - Custom background image
    - Custom solid color background
    - Setting widget
    - 2 bubble types
    - 2 background types
    - 10 background themes
    - 10 bubble colors
    - Random bubble color
    - Bubble sound
    - Bubble droid
    - 3 droid types
    - Change bubble droid appearance percentage
    - Change bubble size
    - Change number of bubbles floating
    - Change speed of bubbles floating
    - Change direction of bubbles moving
    - Smooth the edge of bubble
    - Reverse bubble acceleration
    - Rotating right/left to accelerate bubbles
    - Bubble counter
    - FPS, to save battery usage
    - Support most resolutions including Android 3.0 tablet
    Instruction
    Home -> Menu -> Wallpapers -> Live Wallpapers
    Note: It is live wallpaper so you can't open the app, you will need to follow the instruction above in order to set the wallpaper. Also slower/older devices (shipped with Android OS below 2.1) can't run it too, currently it has been tested on Nexus S, HTC Desire and Samsung tab so any mobile devices that is equivalent to them should run fine.
    If you have put the app on SD card and restarted the phone, the wallpaper will reset to default since the system couldn't find the app first.
    Official site: http://www.xllusion.net/android/
    FAQ:
    1. App is not compatible with my device?
    Please try the free version first.
    2. Wallpaper resets to default after reboot/restart the phone?
    Please move the app to phone instead of SD card.
    3. Custom images resets after reboot/restart the phone?
    It is an Android issue, not a bug. It takes a few seconds to prepare the SD card correctly after reboot and the image is located on SD card so wallpaper couldn't find it first.
    One quick hint without re-select every images when restarting, you just need to set one setting from settings screen, e.g.- FPS -> 50fps,
    4. My app is not downloading after purchasing?
    If it is your first time buying, Google will check through the credit card detail which normally takes few hours time.
    Try troubleshooting at Google: http://market.android.com/support/bin/answer.py?answer=1067233
    5. When does 15 minutes refund period start?
    15 minutes refund period only starts when you have actually downloaded the app.
    Xem thêm trên Android Market:
    [URL]https://market.android.com/details?id=com.xllusion.livewallpaper.bubblepro&feature=search_result[/URL]
    Tải về:
    [URL]http://appstore.vn/a/index.php/home/app/234[/URL]
    apham thích bài này.
  2. apham
    apham Thành viên
    làm cách nào để trong bong bóng có hình của mình được bạn hả?
