Business Calendar v1.2.1.0 - Phần mềm lịch rất đẳng cấp doanh nhân
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi BinhDa, 22 Tháng tám 2012.
  1. BinhDa Super Moderator
    [h=2][​IMG]
    What's New[/h]What's in this version:
    Redesign event details view:
    - complete redesigned layout of the event details and additional functions
    - new buttons at the top to edit, copy, share and delete an event
    - new option to add, change and remove reminders
    - intelligent collapsing of long descriptions
    - option to directly dial a number that has been entered in the event title
    - option to specify the scoll mode of the event details (fix header or scroll complete view)
    Other changes:
    - dismiss reminder by swipe gesture
    - bug fixes
    [h=2]Description[/h]Calendar-Application with scroll- and zoomable multi-day view and much moreBusiness Calendar is a complete calendar application that is synchronising with your Google calendars!
    * smooth scroll- and zoomable multi-day view (1-14 days)
    * graphical and textual presentation
    * month, agenda, day and event view
    * quickly fade in/out calendars using the favorite bar
    * search function
    * drag&drop functionality
    * configurable widgets in different sizes for month, week, agenda and day view
    * easy switching between timeline bars and event titles in month view
    * intuitive new handling option: just move your finger over some days of interest in month view to open them in the multi-day view
    * quick day overview when adding a new event
    * many options for recurrent events (e.g. to add a recurrent event that takes place every other week on Tuesday and Thursday)
    * option to link a contact to an event
    * option to create templates for events
    * configurable font sizes for the app and the widgets
    * option to select individual calendars for each widget
    * 11 different widget design themes
    * import/export function for calendar files in the popular iCalendar format (.ics, .ical)
    * context-sensitive help system to optimize your work with Business Calendar
    There also is a free ad-supported version of Business Calendar (called Business Calendar Free), we recommend to test the free version before buying the paid one.
    Please do not move the application to the sd card if you want to use the widgets (general limitation of the Android operating system)!
    You can use our own Business Calendar reminders or the reminders of the stock calendar application to get alarm messages for your events! If you use our own reminders please remember to disable the alarm messages of the stock calendar application!
    DOWNLOAD
    http://dl.dropbox.com/u/59449626/APK/v1210.apk
