BusyBox Pro 9.5 - Tiện ích hỗ trợ hệ thống Android
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi BinhDa, 25 Tháng tám 2012.
  1. BinhDa Super Moderator
    [h=2]Description
    [​IMG][​IMG][​IMG][​IMG][/h]Root required for this application!The fastest, most trusted, and most popular BusyBox installer and uninstaller!
    Over 2.8 million installs and over 10,000 5 Star ratings!
    The only installer with a backup feature for safer installs and uninstalls!
    Mentioned in the new XDA-Developers book "XDA Developers' Android Hacker's Toolkit: The Complete Guide to Rooting, ROMs and Theming"
    Winner of best Utility Software award for Android via Handster.
    This is the only installer that is ad free and requires no internet permission!
    This installer has the smallest Busybox binaries available, right around 800kb unlike the other installers which are over a meg.
    Pro version contains no ads or nag screens, Backup feature (for safer installs), uninstall feature, Advance Smart install feature, the ability to hand pick the applets you want, safety check for missing applets on start, and better overall support. The pro version will receive more frequent updates than the free version will.
    The source for this application can be found here: https://code.google.com/p/busybox-android/
    Featured on the BusyBox website at: http://busybox.net/products.html
    The BusyBox source code can be found here: http://git.busybox.net/busybox/
    A must have for any rooted phone! Almost EVERY rooted applications needs BusyBox to perform their magic, if you have a rooted phone then you need BusyBox.
    Please note I did not write BusyBox! I wrote this installer and cross compiled BusyBox for Android. Please see the about menu option for more details or here: www.BusyBox.net
    BusyBox is a software application that provides many standard Unix tools, much like the larger (but more capable) GNU Core Utilities. BusyBox is designed to be a small executable for use with the Linux kernel, which makes it ideal for use with embedded devices. It has been self-dubbed "The Swiss Army Knife of Embedded Linux".
    Leave this installed if you always want to get the latest version of busybox!
    tags: busybox, utility, terminal, emulator, root, stericson, adb, toolbox, rom, unlock, jailbreak, root, linux, unix, shell, script, tools, android, installer, busybox installer, bb, custom, installer, pro, android, android root
    DOWNLOAD
    https://dl.dropbox.com/u/59449626/APK/BBP%20v9.5.apk
