Yêu cầu phiên bản Android từ: 1.6 Đây là ứng dụng giúp cài Busybox cho Android, chỉ dành cho những máy đã root ! Ảnh chụp màn hình: Xem thêm trên Play Store: Mã: [URL="https://play.google.com/store/apps/details?id=stericson.busybox.donate"]https://play.google.com/store/apps/details?id=stericson.busybox.donate [/URL] Tải về: Mã: [code][URL]http://appstore.vn/a/index.php/home/app/3825[/URL] [/CODE]
cập nhật 9.6.4 v9.6.4 Upgraded root library to newest version. Increased waiting time for root access to be granted to the application. v9.6.3 fixed issues with telnet, ping, wget not resolving hostnames. You need to reinstall busybox again to fix this. Fixed an issue with the loading time of smart install. v9.6.2 Fixed null pointer exception v9.6.1 Added a check before install to test integrity of Binary being installed.
Cập nhật 9.6.5 v9.6.5 Fixed some install issues for some users. v9.6.4 Upgraded root library to newest version. Increased waiting time for root access to be granted to the application. v9.6.3 fixed issues with telnet, ping, wget not resolving hostnames. You need to reinstall busybox again to fix this. Fixed an issue with the loading time of smart install. v9.6.2 Fixed null pointer exception v9.6.1 Added a check before install to test integrity of Binary being installed.
