Cách làm điện thoại start/scan nhanh!!!!
Thảo luận trong 'S60/S80/S90: KIẾN THỨC & KINH NGHIỆM' bắt đầu bởi silichick, 2 Tháng sáu 2006.
  1. silichick Thành viên
    Mình mới tìm thấy cái này, hy vọng anh em thấy hữu dụng! (chưa tét)
    The tips i would be posting here are my personal experiences.
    1. While accessing the default app manager( [FONT=verdana, geneva, lucida,][FONT=verdana, geneva, lucida,]Uninstaller[/FONT][/FONT] ). It normally takes a lot of time to [FONT=verdana, geneva, lucida,][FONT=verdana, geneva, lucida,]scan[/FONT][/FONT] though the uninstaller files if you have lots of apps already installed. It may even give you a 'memory full unable to remove' error as well. Same could be shown while installing.
    Soln. A simple [FONT=verdana, geneva, lucida,][FONT=verdana, geneva, lucida,]solution[/FONT][/FONT] to this is browse though using a [FONT=verdana, geneva, lucida,][FONT=verdana, geneva, lucida,]file [/FONT][FONT=verdana, geneva, lucida,]explorer[/FONT][/FONT] and go to
    c:\system\install and e:\system\install\ later
    You will find the uninstaller files in the above directories.
    All you have to do is to create a subdirectory probably as below
    c:\system\install\Bypass e:\system\install\Bypass\
    Normally in the install folder there would a quite a few apps which you would not be uninstalling/reinstalling frequently(non-frequent updates). All you have to do is mark these files, (These files have an *.sis extention.) cut them and paste them in the Bypass folder we created inside the install folder. You can also delete duplicate unsinstaller files( files of same app but different version-Dont delete anything if youre not sure)
    This will make sure that the app manager( Uninstaller ) does not scan through most of the files as they are in the bypass folder and saves time and memory while uninstalling.
    You may open the app manager( Uninstaller ) and check how fast it opens scans and uninstalls.
    Now in future if you have to remove any application which is in the bypass folder, then cut it from the bypass folder and get it under install and open the app manager( Uninstaller ) and remove. It takes an effort here but it will save time more often.
    2. Boot faster and save memory
    Soln. Another one, but be more careful. There is a folder called
    c:\system\recogs\ and e:\system\recogs\
    These folders contain *.mdl files which normally start on reboot by which reboot is delayed and they consume some [FONT=verdana, geneva, lucida,][FONT=verdana, geneva, lucida,]RAM [/FONT][FONT=verdana, geneva, lucida,]memory[/FONT][/FONT] as well. Now there are certain license manager files and other app files, you need to start while starting the phone, leave them as it is. But you will find other files like quicksheet.mdl etc which is not needed to start on reboot. Such files can be marked and placed into a subdirectory \Bypass under recogs and restart the phone, which will save time and memory as well.
    Do it for both c:\ and e:\ carefully.
    Later on as required you may bring files from \Bypass to recogs.
    Tips- If you get App closed **** error on startup/reboot. This is just the trick for you.
    Dont delete anything if youre not sure.
    Caution: If you're not sure of something-Dont do it, unless you are experimenting at your own risk.
  2. brianh0
    brianh0 Thành viên
    Viết tiếng angle không à , tui mà hiể được là chết liền đó .
  3. boyvuive_vuitinh
    boyvuive_vuitinh Thành viên
    Tạm dịch thế này nhé :
    1 > Khi bạn vào chương trình " Manager ( [FONT=verdana, geneva, lucida,][FONT=verdana, geneva, lucida,]Uninstaller[/FONT][/FONT] - Gỡ bỏ ứng dụng cài trên máy ) . Bình thường nó sẽ mất 1 khỏang thời gian để tìm các ứng dụng đã được install trên máy để load lên . Nó có thể sẽ báo lỗi " memory full unable to remove " khi bạn gỡ bỏ ứng dụng .
    Hướng khắc phục : Đơn giản là dùng trình quản lý file như " File Explore " vào thư mục C:\systems\install và E:\systems\install bạn sẽ thấy các file Uninstall trong đó dưới dạng file *.sis nhưng dung lượng rất nhỏ . Bạn tạo 1 thư mục Bypass ( tùy bạn muốn đặt sao cũng được ) trong thư mục install ở trên . Sau đó bạn " cut " hết tất cả các file *.sis vào thư mục Bypass , nếu thấy file nào trùng có thể xóa bớt vì khi mình update các ứng dụng đang có nó vẫn tạo thêm file *.sis trong thư mục install , mình có thể xóa file .sis của ứng dụng version cũ đi ( Hãy biết rõ những gì bạn muốn xóa ) . Sau khi mình làm xong , bạn vừa tiết kiệm thời gian và bộ nhớ cho máy mình .
    Sau này muốn uninstall ứng dụng nào bạn chỉ cần cut file *.sis trong thư mục Bypass của ứng dụng đó vào thư mục install . Vào chương trình Manager bạn sẽ thấy ứng dụng đó và có thể Remove bình thường .
    2 > Khởi động nhanh hơn và tiết kiệm thời gian :
    Hướng khắc phục : Cái này bạn ấy viết không rõ ràng mình bohand , không hiểu 1 số bước , mà đọc thấy nguy hiểm nên hổng dám dịch bậy hìhì :) .
    HAVE FUN .
  4. tanthanh2009
    tanthanh2009 Thành viên
    Có gì đâu, tao cái folder bypass (bỏ qua) ấy để khi máy boot nó bỏ qua bước load các appli đấy mà! cứ chơi đi không sao đấu! Khi nào cần thì cut về lại folder C:\systems\install củ.
  5. duaconkhonuoi
    duaconkhonuoi Thành viên
    mình xóa hết máy cái file sis trong intalls có sao ko , mình đã xóa và ko thấy ảnh hưởng gì hết. Với lại sẽ tiết kiệm bộ nhớ nữa
  6. 3230bao
    3230bao Thành viên
    Bạn xóa hết cũng không sao nhưng khi bạn gỡ cài đặt sẽ bị báo lỗi. và không thể gỡ hết chương trình được.
  7. boypluto
    boypluto Thành viên
    Sao lại không gỡ hết ? Cứ vào system\app, Trong đó nó có hết những chương trình mình mcài vào. không thích cái nào thì cứ xóa thư mục của nó đi là xong
  8. minhtue
    Đa số các chương trình khi cài đặt không phải chỉ lưu trong system\app thôi đâu bạn, nó còn ghi thông số trong nhiều thư mục khác nữa, vì vậy nếu bạn chỉ đơn thuần remove app bằng cách xóa nó trong system\app thì không thể remove hết nó đâu! Chúc vui vẻ!
  9. duaconkhonuoi
    vậy muốn xóa hết thì sao ? Như vậy sẽ tiết kiệm bộ nhớ hơn
  10. trieu94
    trieu94 Thành viên
    chi co cach la de file trong thu muc install lai va khi can remove bang manager thoi, chu ban xoa thu cong thi 1 so Apps ko het cac file rac dau....
