Cập nhật phần mềm chạy trên nền Python
Thảo luận trong 'ỨNG DỤNG CHẠY TRÊN NỀN PYTHON' bắt đầu bởi ChiêuTrúc, 24 Tháng ba 2006.
  1. tanthien
    tanthien Thành viên
    New Sleep Music v0.8 s60v3{Update 04/10/08
    This program is for the person who likes to listen to music while getting sleep, and not have to worry about the music player running all night, if he or she falls asleep. Simply open the program, enter the amount of hours you wish the program to wait until turning off, Music Player and Radio will close at the time we set .
    ******* New in this version **************
    Now the application comes with two modules
    you can choose any module ,
    keypress : this module uses the keypress module , this will simulate the keypress
    and this will close the music player as you manually closes ,
    * This module is more stable than the appswitch module , because some times you will get 'General System Error' and you may need to restart your mobile
    **Note you need to install keypress and misty module for working this application
    ** recommended module : keypress
    appswitch: sleep music v0.6 uses this module
    * this module will work without keypress and misty module
    Inactive Sensor
    * apllication can now sense the inactive use of your mobile
    * If the user does not use the phone for a specific peroid of time then the application will automatically close the music player
    * you can select various inactivity sense time
    Features
    * Timer presets available for 15 , 30 and 60 min
    * Also users can enter the time manually
    * You can close either Music Player or Radio
    Installation Instructions
    **Python must be installed in your mobile
    Download it from here
    1. Install "sleepmusicv08.sis" sis file to your phone (dont have to sign the application)
    2. Sign the attached "keypress102_unsigned_dev_certfree.SIS" sis file
    3. Sign the attached "appswitch103_unsigned_devcertfree.SIS" sis file
    4. Sign the attached "misty193_unsigned.SIS" sis file
    5. Install the signed files in your phone
  2. tichau
    tichau Guest
    pyAlertMe 2.0 : Password Protection Added{update 05/10/08}
    You know alertme is not enough protective withouth password protection.
    And in this version i added a password protection ability to alertme.
    put another alert sound instead of old one.because old one's size was so big.
    Background Changed.
    and i put all setting buttons together under settings menu.
    default password is "0"
    KIETVVY and Hp93 like this.
  3. tichau
    tichau Guest
    pySmartMath v3.3.3 - advanced and highly functional calculator (RU) [UpdatE 05 Oct'08]
    Update advanced and highly functional calculator for Smartphones on Symbian OS 9.x
    New in v3.33:
    Add:
    1. Added Chinese language (Menu / Options / Language)
    2. The ability to leave your comment or write about a bug in the program
    (Menu / Help / Leave feedback).
    3. The long-awaited all: the possibility of calculator to make over
    the last received number mathematical calculations using quick menu on the lattice. (mnogoraschetnost =)) So computing speed increases. ​
    Bugfix:
    1. A bug with calculating square roots of equations.
    Now considered a peak parabola when more discriminant zero.​
    Requires Python 1.4.4 and PythonRightPack
    danght, Pháp Sư and butchibutbi like this.
  4. tichau
    tichau Guest
    pyDontTouch v1.7 (my MOD of AlertME) by zoellner
    v1.7
    NEW Version - DontTouch v1.7 (my MOD of AlertME)
    - now u can not kill the app with *red key*
    - now u can set switch in BG ON and OFF in the settings
  5. tichau
    tichau Guest
    NEW Version - pyDontTouch v1.8 (my MOD of AlertME) by zoellner
    v1.8
    NEW Version - DontTouch v1.8 (MOD of AlertME)
    - only passw. protection if AlarmMode is active
    - two different menues (one 4 active prot. and one 2 start & settings)
    awp1323, Pháp Sư and Hp93 like this.
  6. tichau
    tichau Guest
    Python : Count Down v1.1 (Py) - Fun Graphical Countdown
    Fun graphical countdown from 9 to 0, which changes color based on number. You can press a number (0-9) at any time to reset the count and Select key to start again from 9.
    Requirements:
    · Symbian S60 3rd Edition
    · Python for S60
  7. tichau
    tichau Guest
    Python : Watch Me - Light Now v1.2 - Fill the Screen with a Single Color
    [​IMG] [​IMG]
    Description
    Uses cases:
    * You need a flashlight (use white or blue)
    * You need ambience atmosphere (use color cycle)
    * You need to alarm (use red)
    * You need to get color's RGB value
    Keyboard shortcuts:
    1 - less 2 - RED 3 - more
    4 - less 5 - GREEN 6 - more
    7 - less 8 - BLUE 9 - more
    0 - Rotate
    * - Change screen size
    # - Show / hide RGB values
    Arrow keys - Change step size (1-10)
    Clear key - WHITE
    Requirements:
    · Python for S60 (PyS60)
    What's New in This Release:
    · Keep screensaver off with focus callback
    · Non-editable About dialog
    · RGB value setting with Listbox
    · Tested with N82 and PyS60 1.4.3
  8. tichau
    tichau Guest
    pyAlert Me v3.0 s60v3
    hi there
    u know latest version of the alertme was 2.0 and decided to make a new version that nobody will need to use any of that modifications of alertme.
    in this version u can change.so i added lots of features to let u personalise alertme.lets see new features
    New Features:
    Background is able to change.
    Alerting sound is able to change.
    You can set the volume of the sound alert.
    Alerting with an sms
    You can set the delay time to alerting for writing password.
    Icon added.
    You can choose sms alert or sound alert(or both of them.) from on/off menu.
    You can activate or deactivate password protection from on/off menu too.
    You dont have re-write all setting in every running of app.
    Faq:
    How to change the background of the app?
    You need a 240*240 sized and *.jpg formatted picture on mass memory( e:\ ).afterwards you can change the background easily by writing the name of picture without ".jpg"
    example: if u have a picture called as "name.jpg" u should write "name" to the background setting input in alertme.
    How to change the sound of alert?
    You need a file that is formatted as ".wav" on mass memory( e:\ )
    then u can change the sound of alerting by writing the name of that sound file without ".wav" like how we did it while changing background pic.
    What the heck is that On/Off menu?
    The on/off menu is where that u prefer activate or deactivate smt. like sound alerting,sms alerting ,password protection.
    Warnings:
    Modifications arent allowed in this version.
    Because i joined some programming contest with this app.
    so i have licenced application.so modifications will be illegal.
    Please Do Not Use Those Hacked AlertMe Apps.i have spent my days for improve this app.
    And developers please do not modificate my app. u know how much hard is developing an app.
    hoang_camap and awp1323 like this.
  9. nhuhienltd
    nhuhienltd Thành viên
    Python Right Pack - v.1.1.3 update
    Update
    - Added appuifw2 and documentation on it.
    The file must sign! If the smart broken - no problem =)
    hoangloc11 thích bài này.
  10. tichau
    tichau Guest
    py addWebCuts v1.0.0 S60v3
    A shortcut to the 3 most famous community site (Friendster, MySpace, Facebook & etc), Python v1.4.4 required! Enjoy
    Credits to addanial
    awp1323 thích bài này.
