Cập nhật phần mềm chạy trên nền Python
Thảo luận trong 'ỨNG DỤNG CHẠY TRÊN NỀN PYTHON' bắt đầu bởi ChiêuTrúc, 24 Tháng ba 2006.
  1. tichau
    tichau Guest
    PyNetMony v1.21 {WarWalking, BlueWalking and 2G/3G Netmonitor}update 15/12/08
    New Version: 1.21.0 (2008-12-13)
    Key Features of PyNetMony:
    * GSM / UMTS Netmonitor with clf
    * WarWalking Scanner
    * BlueWalking Scanner
    * Internal, External and A-GPS
    * Voice notifier
    * Log files
    * maps download
    * custumizable
    * KML Export
    PyNetMony is written from using the language Python. You will need Python for S60 1.4.4 or higher to run PyNetMony.
    2. Installation
    Normally you should find all Files except Python in this zip file. Before installing all the files on your phone, you have to sign all the sis files except the Python S60 Runtime. The most easiest way (not the quickest) is to sign the files online. For that, please go to Simbiansigned online and sign all the folowing files, except PyS60 with all 13 caps. After that, install them in the following order:
    PyNetMony is a freeware GSM, UMTS, WLAN and Bluetooth Monitor and scanner tool with support of the internal, external or assisted GPS of all new Nokia E and N Series mobile phones.
    It shows and logs GSM and UMTS network information like Cell ID, Location Area Code, Mobile Network Code , RX level and so on in the NetMon tab. It supports Nobbis clf v3.0 format, but only decimal at this time, please read the readme.txt for details. It has a voice notifier for cell changes. The white headline shows always the current cell id, how many WLAN and Bluetooth devices are in range, how many GPS satellites are fixed and the current time.
    If you use a clf V3.0 with cell coordinates, the radar shows the cell position from your GPS position. The radar can also be used for geocaching. The Map feature downloads a map centered with the current cell or your own GPS position in 12 different zoom levels.
    Color and font size are changeable. There is an option to let the background light always on or if the current cell changes or a new bluetooth comes in range
    All found WLAN and Bluetooth devices in range are logged into a file. If you press the OK button you can toggle between SSID and MAC address. It has a WLAN and Cell Positioning System, that allowa to log WLANs with coordinates without GPS reception, e.g. in buidlings.
    You can also start a GSM/3G measurment log file, and a WLAN measurement log file, that logs the RX Lev and coordinates. You can export the WLAN database to KML, to view them in Google earth, or Kismet
    Hoang An, Handuong and truongluutinh like this.
  2. tichau
    tichau Guest
    pyFont Test v1.10 [UpdatE 15 Dec'08]
    Font Test v1.10
    Font Test
    While researching something else, I happened to experiment with appuifw.Text(), here's the results. It contains undocumented features (compared to PyS60 1.4.4 manual).
    [​IMG][​IMG]
    * There is undocumented font label 'digital'. It doesn't seem to contains anything else but numbers with nice "digital watch" style.
    * You can define the font in three ways:
    1. Using font alias string, for example 'normal'
    2. Using unicode font name, for example u"LatinPlain12"
    3. This is the undocumented feature: using tuple of two or three items, where first item is font name, second item is font height (in twips) and third optional item is style flags. Those are same which you can use with style() method.
    Version History
    Version 1.10
    * Vertical and horizontal text justification
    * Using both Canvas and Text in same application
    Pháp Sư, Handuong and truongluutinh like this.
  3. tichau
    tichau Guest
    S60 Resource CleanUp v0.2 [delete unneeded RSC files]
    Description:
    S60ResourceCleanup is a Python script to clean-up drives from unneeded application resource and help files on Series 60 platform. It is developed/tested on my Nokia N95-1 (S60 3rdEd FP1) but should work on most S60 3rd devices.
    Several Symbian applications (especially Nokia's) install resource and help files for quite many languages even though you never going to use them. This script lets you select the languages that you want to keep and deletes the resource and help files of all the other languages (from C:\Resource and/or E:\Resource and their sub-directories). As a result a lot of free space (several MB depending on your apps) can be freed from the disk drives. The script can take a backup of the removed files, on memory card (E:\ResourceBackup). You can also restore the files from the backup. Or you can transfer them in your pc and free space from the memory card.
    Use it wisely, backup is recommended at least the first time. Note that several applications use only English (UK) (code 01) resources, so it is strongly recommended to keep that language.
    Requirements:
    - An S60 phone with patches to disable capabilities.
    - Python for S60 installed on the phone.
    - Python script shell installed on the phone
    Usage:
    - Download rescleanup.py and copy it to c:\python (or e:\python).
    - Disable capabilities on the phone.
    - Open Python shell and from menu select "Run script" and select the script.
    - Follow the menu to perform cleanup/restore.
    - You can navigate with all the arrows.
    - It takes time to run, so have patience.
    - You can cancel the active job by selecting "exit" or with the left arrow.
    - Remember that no file will be lost if you have enabled backup.
    - The language refers only to the user interface language, not the writing language.
    - The backup location is fixed to E:\ResourceBackup,
    so in order to keep backup you need a writeable E: drive (memory card)
    [​IMG][​IMG][​IMG][​IMG]
  4. tichau
    tichau Guest
    xyzMusic Control - Control your music player using accelerometer
    Here is...
    What you need?
    -Python 1.45
    -Python Script Shell 1.45
    both can be found on
     [URL="http://www.anonym.to/?http://sourceforge.net/projects/pys60"]http://sourceforge.net/projects/pys60[/URL]
    -Keypress 1.06 -> Signed *I think selfsigned, or the one in megapypack wont work, coz cap's issue
    -Axyz Module -> Signed *I think selfsigned wont work
    both can be found in rar i uploaded
    -Megapy pack 1.51
    How to install:
    1. Uinstall megapyPack on your phone
    2. Install Signed Keypress 1.06
    3. Install Signed Axyz Module
    4. Install megapy 1.51 -> unthick keypress and axyz
    5. Install xyzMusic Control
    anhvancodon thích bài này.
  5. manbk401
    manbk401 Thành viên
    Send SMS v1.86 python
    new:
    1-fix square in settings
    2-fix waitting when send msg
    app this like app pysms can u send msg with new symbol
    need megamodulepack v1.5.2
  6. tichau
    tichau Guest
    ShakeCube v1.0 S60v3
    App is developed by Shynet!
    nghiemsam and vohong like this.
  7. tichau
    tichau Guest
    PythonRightPack v1.1.4 [UpdatE 20 Dec'08]
    New version of a compendium of modules for Python.
    Update
    - New clipboard.py of chamil.85, which works equally well on E61, N73, N71 and (as before) to other phones
    - Ftplib.py from Python 2.2 to Python for the company
    - Urlparse of Python 2.2 with the company
    - Same with veterans prodb
    - Updated laa.pyd
    ATTENTION!
    Compilation contains RDAccelerometr.dll! Because of this error can occur liby update. Delete the file from C: / sys / bin / or delete the program associated with the accelerometer. And also if you have separately set wif - and remove it! In other words, remove anything that might interfere with the installation - other programs in the python, for example. Especially if they are using accelerometer
    The file must sign!
    Pháp Sư thích bài này.
  8. manbk401
    manbk401 Thành viên
    Reminder v1.00 for S60v3 with voice annotation
    What does it do?
    * It is an absolutly straight forward, “middle button” click application. It lets you define date, time and subject of an alarming calendar entry with voice annotation
    * If the defined date/time has come, the phone reminds you as usual and you are able to listen to your voice annotation recorded earlier.
    The script comes in German and English (automatically). No signing required at all. Phyton is requierd.
    Download it from here►
    max-ant thích bài này.
  9. tichau
    tichau Guest
    pySmartGET v3.00 Final [EN]- translated by cupinthemud
    SmartGET 3.00 - Manager download files from the Internet for smartphones in the Symbian OS 9.x
    Finally here is the best download manager of symbian Os 9.x
    Tranlated By me CUPINTHEMUD
    I have seached all over the forum but all version are in russian language. so i thought to translate it..... and here it is....
    I have also changed the Icon. and new screenshots added........
    I have taken help from google translate so there may be some mistakes......
    if you find any then plz inform........
    Features:
    Features:
    Features:
    -- Download of up to 5 files simultaneously;
    -- Displaying detailed information on injection;
    -- Dokachka files after the cliffs and reboots;
    -- Establish a list of links and its editing;
    -- Cataloguing downloaded files date or expansion;
    -- Tracking links in the buffer exchange;
    -- Download timer at the right time;
    -- Many settings;
    -- Window of all windows;
    -- Graphical interface;
    -- Support for skins;
    -- Hot keys.
    Improvements in the latest version:
    -- An updated graphical interface;
    -- Include window of all windows, which displays a list of all active downloads and the level of Races;
    -- Change the coordinates of its provisions on the screen;
    -- Amend its width, length of the shadows, smoothed angle;
    -- Amend its background color, text and progress-bar;
    -- Added to Settings-Interface Opportunity:
    -- Select skin programme;
    -- Select a size line downloads (hotkey
    -- Choose the size of window (hotkey [#]);
    -- Select the orientation of the screen (hotkey [0]);
    -- Remove the cover states and remove panel amounts;
    -- Choose what information to display the left of file name (anything number
    Order, the percentage of injection);
    -- Make a string unallocated uploads transparent;
    -- Added to Settings-Intercepting to include cataloguing by date (files
    fetched in a folder type god_mesyats_den - 2008_09_10);
    -- Added to Settings-General opportunity to choose the type of exit
    Programme: ordinary, or special (for those whose usual exit leads to hang
    program);
    -- Added to the list of functions - Export command to file uploads
    export.txt in the folder for downloaded files (each on a new injection
    line, each line address and name separated by commas);
    -- Added to the list of functions - Import command from the file uploads
    import.txt from a folder for the downloaded files (each injection should be
    on a new line, each line should be addressed, then comma, then the file name to save to English);
    -- Added to the list of functions - The timer for the team and its inclusion
    shutdown (and accordingly removed from Settings-timer);
    -- Calling on key [G] screenshot saved in congested files, and in the name indicates exact time of establishment;
    -- Added to the process of pumping checking files to the possibility dokachki file server support in the case of his inability pops up question: Does perekachat file first (as it is not possible his finish) or cancel injection;
    -- With a module in the windows uitricks Amendment and Addendum, O program on the right soft key Back displayed a placard;
    -- Removed with a simple restart due to incorrect work with a module iapconnect;
    -- The jump in the message, and error interception is written the name of the file;
    -- All settings when reinstalling programme remain.
    How do their skins:
    -- Go in and System_Apps_SmartGET_Skins create a copy of the appropriate Default.skn name in English, for example MyNew.skn;
    -- Go to Settings-Interface and Skin in paragraph select from the list Your MyNew;
    -- Go to Settings-Colors and set the desired colors for all interface elements;
    Keyboard Shortcuts:
    -- Use joystick left-right to select toolbar icons
    -- Use joystick up-down to select downloads in queue.
    Requires Python 1.4.4 and megaPyModulePack 1.5.2
    I hope you like it
    Enjoy
    Attached Images[​IMG] [​IMG] [​IMG]
    Pháp Sư and ph4nthuth402612 like this.
  10. tichau
    tichau Guest
    pyhack v0.2 - Gsm Bluetooth Hacking
    hack v0.2
    hack is an example script for sending AT Commands over Bluetooth. It's written in Python and run on most of s60 phones; the purpose of the program is the remote control of the attacked device and the retrieving of it's informations. The applications runs with pairing connection and controls are given by user key pressing: key '5', string input, key '7', last command string repeat, key '0', configuration reset, key '*', preconfigured actions list
