Cập nhật phần mềm Multimedia
Thảo luận trong 'ỨNG DỤNG MULTIMEDIA' bắt đầu bởi ChiêuTrúc, 24 Tháng ba 2006.
  1. tanthien
    tanthien Thành viên
    TTPod player v3.1.0 S60v3 symbian9.X "update"[Chinese version]
    [​IMG][​IMG]
    Google Translation
    TTPod music player v3.1.0with more features:
    1. Adding new MP3 decoder to enhance sound quality
    2. Spectrum visual effects to support full-screen mode
    3. To increase repeat function, digital keyboard, "3" to choose start and end at the repetition, "9" for the abolition of the Trade Union
    4. Optimize the layout of the menu, and adjust the content of the lyrics page menu more
    5. To increase the page background light switch option set
    6. To enhance the network disconnect function, support for the custom of time off
    7. Page one-way increase the lyrics show that the skin command syntax for reference package is installed inside own skin
    8. Vertical display adjust the volume, individual volume of the old vertical skin may need to amend the details
    9. Refine mini player and the transparency of the background lyrics show the location classification
    10. Recommendation to increase functionality friend
    Support:Nokia 3250/5500/6110/5700/6110/6120/6120c/6121/6290
    N71/N73/N75/N76/N77/N78/N80/N81/N82
    N91/N92/N93/N93i/N95/N96
    E50/E51/E60/E61/E61i/E62/E65/E70
    phamlinh003 thích bài này.
  2. minhtue
    ALON Software MP3 Dictaphone v2.88.4 S60v3 SymbianOS9.x incl K*yg*n - HSpda
    ALON MP3 Dictaphone for S60 3rd Edition
    OVERVIEW
    ALON MP3 Dictaphone for S60 3rd Edition is the first high-quality MP3 dictaphone which also supports AMR and WAV audio formats for recording, phone calls recorder and MP3, OGG, AAC/MP4/M4A, AMR, WAV audio player which supports Internet radio, has 3-Band Parametric Equalizer , hot buttons and M3U playlists. ​
    Now you receive three applications instead of one: voice dictaphone, phone calls recorder and music player!
    You may easily turn your smartphone into advanced digital dictaphone and start to record lectures, conversations, interviews and phone calls. On the other hand you need not to spend money to music player - with ALON MP3 Dictaphone you can listen to your favourite music in MP3, OGG, AAC/MP4/M4A, AMR and WAV - the most popular audio formats.​
    Pháp Sư and tanthien like this.
  3. minhtue
    ALON MP3 Dictaphone for S60 3rd Edition v2.89 with k*yg*n
    OVERVIEW
    WHAT IS NEW
    The bugs fixed for some phones.
    Auto archive of recorded phone calls.
    Expanded support of sample rates for recording (from 8kHz to 48kHz depending on phone model).
    Now you may record phone calls without beeps!
    Append option for recorded files.
    An opportunity of record phone calls in MP3 format.
    Bookmarks. Now you may add/edit/delete bookmarks.
    Expanded opportunity of loading M3U playlists.
    Sleeping time option for playback.
    Improved option of choosing play folder.
    Full support of Nokia E90.
    Free Internet Radio! You may use Internet Radio for free even after ending of trial period!
    AUDIO RECORDER
    Two types of gain control besides automatic: during the recording you may adjust the recording level manually by using Joystick as well as you change the volume during listening to music, also you may choose one of four positions of microphone gain before recording.
    Dictaphone allows you to save lots of memory space by keeping you recordings in MP3 - the most popular audio format.
    You may record to any location of your phone including memory card and create new folder.
    You can move, rename, delete and send your recordings.
    PHONE CALLS RECORDER
    MP3, AMR and WAV audio formats are supported.
    Two types of phone calls recording: automatic and manual.
    You may record both to memory card and internal menory.
    AUDIO PLAYER
    Pause and resume playback during/after incoming calls. You can keep listening to music.
    You may choose any folder and all subfolders from any location on your phone for playback.
    Dictaphone gives opportunity to organize your own music library by creating the folders with your favourite tracks.
    You may choose the different ways of playing the list.
    You may choose the way of positioning the tracks at the list: showing the beginning or the end.
    M3U PLAYLISTS
    Dictaphone supports M3U playlists. You may both use Winamp playlists on your smartphone and use playlists created on your smartphone at Winamp.
    HOT BUTTONS
    You may sign all actions such as play, stop, pause, forward rewind, back rewind, on/off equalizers, switching between playlist and equalizer to hardware buttons.
    3-BAND PARAMETRIC EQUALIZER
    3-Band Parametric Equalizer for all supported audio formats gives opportunity to adjust playback as you like.
    Dictaphone saves your presettings for equalizer. You may adjust playback as you want and don't use equalizer at the next time.
    keke05, Pháp Sư and tanthien like this.
  4. pk6630
    pk6630 Thành viên
    Handy Music v1.0 S60v3 SelfSigned Freeware
    [​IMG] Reduced: 89% of original size [ 718 x 639 ] - Click to view full image
    This music player works something like Winamp, possibility to add/remove files to/from a playlist,
    does not have libraries support,player has two tabs.
    Hoang An, dpc, Pháp Sư and 2 others like this.
  5. tichau
    tichau Guest
    TTPOD v3.1.0 English Repacked Sis Unsigned by PROTOCHIP
    Dear Friends,
    Ttpod is now in english by the translation of _fann95_ of symbian-freak... All thanks go to him...
    To make it more easier to install, i have repacked the sis file with translation of _fann95_ of symbian-freak...
    Just install and have fun...
    TESTED WITH N95 8GB V30.0.18 HACKED...
    ScreenShots:
    [​IMG] [​IMG][​IMG]
    Hoang An, tanthien, quangsuzu1 người khác thích bài này.
  6. tichau
    tichau Guest
    PowerMP3 for Series 60 3-rd edition beta
    Mobifactor is proud to offer a beta version of PowerMP3 for Series 60 3-rd edition!
    [​IMG] [​IMG] [​IMG]
  7. tichau
    tichau Guest
    TTPod English 3.1 for unhacked phones!!! by Snake
    Since the other version is only installable on hacked phones,
    i created a new one for unhacked phones!!
    Have fun!
    Screenshots:
    [​IMG][​IMG] [​IMG][​IMG]
  8. tichau
    tichau Guest
    YouTube for Mobile v1.4.5 J2ME
    [​IMG] [​IMG]
    Access millions of YouTube videos at any time right from your mobile phone. This downloadable application puts YouTube in your pocket.
    Which videos are hot?
    Access the latest, the best and the most viewed videos.
    Search...
    ...and watch any YouTube video.
    Stay tuned
    Watch your subscriptions, playlists and favorite videos any time.
    Upload
    Upload videos directly from your mobile phone.
    tantaimk and tanthien like this.
  9. manbk401
    manbk401 Thành viên
    Picasa photo browser v.1.1.0 update 4-12-08
    The Moblica Picasa photo browser enables you to view multiple public and private Picasa Web Albums and search for photos from your Internet enabled mobile device.
    New Features!
    - View your private albums. Chose Login option to sign in your Google account and view your private albums
    - Search photos by keywords. Chose Photo Search from the main menu to run keyword search on Picasa and view photos.
    - Public Albums. Chose Public Albums from the main menu to view Picasa public albums.
    After installing and running the application, the Moblica logo should appear with a "connecting" status, which should change after a short while to "Logging in".
    If that does not happen, please check your APN settings to ensure you have and APN which allows you to access the Internet from your device configured. In some phones, additional settings may be required in regards to Java applications. If you are experiencing problems, please contact us at
    MaiDinh and tanthien like this.
  10. tichau
    tichau Guest
    Moblica Picasa Photo Browser Icon Edited
    nhangoc and awp1323 like this.
