Cập nhật phần mềm Multimedia
Thảo luận trong 'ỨNG DỤNG MULTIMEDIA' bắt đầu bởi ChiêuTrúc, 24 Tháng ba 2006.
  1. nhuhienltd
    nhuhienltd Thành viên
    SmartCam v1.4 S60v3 SymbianOS9.x Signed -Smartphone Webcam-(27.01.09)
    P.S : Screenshots belong to me,it works without problem at N71...
    [​IMG][​IMG]
    SmartCam - Smart Phone Web Camera - Turns a Symbian Series 60 phone with bluetooth and camera into a handy webcam ready to use with your PC .
    Tested on N81.
    Change log :
    1. Installation/compilation on PC
    Almost all the files needed are in the 'release' folder.
    SmartCam for linux is made of the usual phone files, a user mode application (smartcam)
    and a driver to emulate a webcam (smartcam.ko). The bad news is that drivers can not be
    released in binary form anymore, unless your system happens to run the kernel version
    used to compile the driver. smartcam.ko was compiled using kernel version 2.6.24-18-generic
    If you are not running this version of the kernel you will have to compile the driver yourself.
    Just open a shell in the src/driver path and type:
    make -C /lib/modules/2.6.24-18-generic/build M=`pwd` modules
    In the above command replace /lib/modules/2.6.24-18-generic/build to the path corresponding to
    your system. After successfully compiling the driver you should have the file smartcam.ko in the
    src/driver folder.
    If you want to compile the application as well go to src/app and type:
    gcc `pkg-config --cflags --libs gtk+-2.0 gthread-2.0` -lbluetooth smartcam.c -o smartcam
    2 Installation on phone
    Just transfer any of the files SmartCamS603rdEd.SIS, SmartCamS602ndEd.SIS that
    match your phone on your mobile and follow the installation instructions.
    3. Running
    Before running smartcam, the driver must be loaded in the kernel; if not the PC application will
    complain at start time and exit. To load the driver, open a shell as root in src/driver path and type:
    /sbin/modprobe videodev
    /sbin/insmod smartcam.ko
    After this start the application on the PC, start the phone application and connect it to your PC.
    You should now see video images on the PC application window.
    4. 3rd party applications
    SmartCam was tested on Ubuntu 8.04, kernel version 2.6.24-18-generic, bluez-utils 3.30-3.
    Note: some earlier bluez-utils versions don't work with SmartCam.
    SmartCam works with Kopete, Ekiga, aMsn and gstreamer (launch gstreamer-properties, go to the video
    tab, Default Input, and press Test to see if it is supported by gstreamer). Unfortunately it doesn't
    work with skype, nor with gstfakevideo for skype.
    Handuong and nhu*hieu like this.
  2. nhuhienltd
    mezee music player
    Muzee is a music player for S60 3rd Edition phones.
    * files: mp3, ogg, aac, mp4, m4a audio files
    * ID3 tags: artist, album, title, genre,...
    * next info: volume, played time
    * streams: mp3, ogg, aac, aac+ streams broadcasted by SHOUTcast and Icecast2 media servers are now supported, so it brings you almost all internet radios to your ears... (di.fm, soma fm, Virgin Radio, Club 977, HBR1 and many many more ...)
    * organize your streams into groups
    * displayed info: name, title, comment, played time
    * .m3u, .pls stream playlists supported now too
    * general: you can set color and alpha for fonts and panes, background images (.jpg, .png)
    * smooth anti-aliased fonts.
    Hoang An and nhu*hieu like this.
  3. nhuhienltd
    TTPOD for symbian S60 3rd V3.2.1 English (UPDATE)
    [​IMG] [​IMG]
    Software Version: for symbian S60 3rd V3.2.1
    Published: 2009.02.13
    Platforms:
    - NOKIA: 3250/5500/5320/5700/6110/6120/6120c/6121/6290
    N71/N73/N75/N76/N77/N78/N80/N81/N82
    N91/N92/N93/N93i/N95/N96
    E50/E51/E60/E61/E61i/E62/E65/E70
    - SAMSUNG: SGH-i400/SGH-i450/SGH-i520/SGH-i550
    SGH-i560/SGH-G810
    - LG: KS10/KT610
    Software License: Free
    Software language: Simplified Chinese
    Change log:
    Function Optimization:
    1. Support system decoder EQ adjustment (S60v3)
    2. Improve the list of the first alphabetical order
    3. To increase album background <zoom> display mode
    Fix the problem:
    1. N78/N79/N85 repair some models WMA scanning exit problem (S60v3)
    2.turn key to repair some of the pages using the volume adjustment in response to the problem of non-(S60v3)
    3. Other details
  4. minhtue
    Sản phẩm biên dịch từ Hoa ngữ sang Anh ngữ bởi người Việt
    TTPod V3.2.1 ENGLISH Translation By DEATHMETAL (Hot Update!!!)
    Platforms:
    SGH-i560/SGH-G810
    - LG: KS10/KT610
    Software language: English
    Fix the problem:
    3. Other details
    Translation Change Log:
    - Delete Functions: (File from memory) is working now!
    - Screen Background layout <Zoom> function changed to : Screen fit
    - ID3 Tag editor: Fully in ENGLISH
    ledungctd, narus, misun83 and 3 others like this.
  5. tichau
    tichau Guest
    Nokia Beta labs Magnifier v0.86 S60v3 os9.1
    Released:
    18 Feb 2009
    Nokia Magnifier application utilizes the existing camera functionality on your Nokia S60 phone. It can be used to improve readability in every-day life situations such as reading "fine print". Anyone who has difficulty seeing "fine print" or small objects can benefit from using this application readily available on their S60 phone. Nokia Magnifier has a built in stabilizer to reduce the effects of a shaky hand and negative filter enabling users to switch from light to dark backgrounds improving readability. By using the existing camera technology, users can also snap a picture of the enhanced image for later reference.
    [​IMG][​IMG] [​IMG]
    Usage instructions:
    • Position the the phone in front of the text you want to read (or whatever you want to magnify)
    • Click OK button (phone's center key) to start focusing.
    • If the application can't get a good focus, move the phone a little bit away from the object, and press OK again.
    • Use the '#' (hash) key to turn stabilization mode on/off.
    • Use the '0' (zero) key to turn contrast mode on/off.
    • Use the '*' (asterisk) key to turn negative mode on/off. (the negative mode applies stabilization)
    • Use the up/down keys to change the zoom factor.
    • There are also menu options for these features.
    Watch Video -
    [youtube]XcLvL6FhwL4[/youtube]
    Compatibility and system requirements
    This application has been tested to work on the following devices:
    • N95, E90, N82.
    • Should work for any S60 3rd Edition with auto-focus camera support
    Users have reported that it doesn't work on the following devices:
    E71, N85, N96
  6. tichau
    tichau Guest
    ALON.Software.MP3.Dictaphone.v2.90.S60v3.S60v5.Sym bianOS9.x.Cr@cked-illusion
    ALON MP3 Dictaphone for S60
    OVERVIEW
    ALON MP3 Dictaphone supports S60 3rd and 5th Edition phones and consists of four components:
    # Audio player supports MP3, OGG, AAC/MP4/M4A, WMA, AMR, WAV music formats, 3-Band Parametric Equalizer, hot buttons, M3U playlists, bookmarks, sleep timer and many other.
    # Voice dictaphone - the first high-quality MP3 dictaphone which supports AMR and WAV audio formats also. You may easily turn your smartphone into advanced digital dictaphone and start to record lectures, conversations, interviews and then send the records to your PC.
    # Phone calls recorder records phone calls without beeps in MP3, AMR and WAV formats. You'll to save lots of memory space by keeping your records in MP3 - the most popular audio format.
    # Internet radio is free even after expiration of trial period.​
    MP3 Dictaphone, phone for S60 3rd Edition
    Version: 2.90
    Price: $29.95
    License: shareware,
    14-days trial period
    User manual​
    WHAT IS NEW
    # 5800 XPressMusic support.
    # Fixed call recording bugs.
    # Auto archive of recorded phone calls.
    # Expanded support of sample rates for recording (from 8kHz to 48kHz depending on phone model).
    # Now you may record phone calls without beeps!
    # Append option for recorded files.
    # An opportunity of recording phone calls in MP3 format.
    # Bookmarks. Now you may add/edit/delete bookmarks.
    # Sleeping time option for playback.
    # Free Internet Radio! You may use Internet Radio for free even after expiration of trial period! ​
  7. tichau
    tichau Guest
    ALON Software MP3 Dictaphone v2.90 S60v3 S60v5 SymbianOS9x Signed incl Kygen-HSPDA
    [​IMG] [​IMG]
    OVERVIEW
    WHAT IS NEW
  8. tichau
    tichau Guest
    ALON Software MP3 Dictaphone v2.90 S60v3 S60v5 SymbianOS9.x Cr@cked-DiL
    [​IMG] [​IMG]
    OVERVIEW
    WHAT IS NEW
  9. DOAN DUNG
    DOAN DUNG Ex-Mod
    Zensis PhotoRite SP v6.13 Modified By D3adly
    Zensis.PhotoRite.SP.v6.13 Modified By D3adly
    Capture and enhance photos to have much better appearance! Add creative photo frames and funny magic mirror and much more amazing effects as you take photos or on saved photos! The PhotoRite SP for Symbian Series 60 is a Camera, Editor, Viewer all-in-one imaging application for your camera phone. Main features includes:
    Take amazing photos with PhotoRite SP!
    * Fully compatible with on-phone camera
    * Real-time preview of effects and photo frames
    * save as different resolutions as supported by the handset
    * 8x digital zoom:
    Our unique US patent pending technology ensures the best quality picture is taken every time! Now you can simply turn on the &quot;Auto-fix&quot; function or re-touch the photos with the &quot;Auto-fix&quot; function to get the enhanced photo right on your mobile phone!
    * US patent pending technology
    * Correct backlighting, uneven/under exposure, color, low contrast, haze problems.
    * All with one click
    * Full screen viewing : Auto-rotate to use max. display area
    * Send MMS, Email, Bluetooth, InfraRed directly!*
    * Unlimited Undo/Redo in edit mode!
    * Photo Rotation, resizing
    * Easy to use User Interface
    Put file in X; Resource/Apps
    HTML:
    http://www.mediafire.com/?yxtzyxmzetd
  10. nhuhienltd
    Snaptu v1.1.4-Facebook,Twitter,Picasa,Livescore,RSS Reader,Google Calendar-(24.02.09)
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Facebook, Twitter, Picasa, Live score, Movie reviews, Pub reviews, RSS reader, Google Calendar, Dictionary, Journey planner... all accessible now through one tiny free application!
    snaptu application browser boosts your phone with iPhone like user experience. Install snaptu on your phone to get free access to the web's best online services.
    The Picasa photo browser enables you to view multiple public and private Picasa Web Albums and search for photos from your mobile device. With the RSS reader you can read your favorite feeds and blogs from the mobile phone, anytime, anywhere for free.
    Now featuring new applications
    * Facebook application to stay updated with your social life while on the go. Never lose touch with your friends again - get live news and status updates, browse through your friend's profiles, read and write messages and update your status.
    * Live football coverage, showing real-time game results, news, commentary, favorite tournaments and teams by Score24Live.
    * Dictionary, Find the meaning of words with this English to English dictionary.
    * Transport for London - Tube line status and Journey Planner
    * Fancyapint UK pub reviews
    * Cricinfo cricket news updates and live sores
    * Twitter - See your friends time line, write new twits, reply to twits, write and read direct messages
    ...and more!
    Visit us at
    [CENTER][URL="http://www.snaptu.com/"]http://www.snaptu.com[/URL][/CENTER]
    [URL="http://www.snaptu.com"]
    [/URL]
    for help and support
    Hoang An, Desperando and nhu*hieu like this.
