Capree iON BatteryTimer - ứng dụng kiểm tra time sử dụng pin
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi Liemlovevn, 15 Tháng mười một 2009.
  1. Liemlovevn Ex-Mod
  2. quocgia_n70
    quocgia_n70 Thành viên
    Xài thằng này e thấy nó khá là hao pin
    E test từ mấy bản trước rùi, được cái màn hình chờ hiển thị pin, rất pro
    blackcatx13 and hogokaka like this.
  3. minhtue
    Capree iON BatteryTimer v1.04 S60v3/S60v5 SymbianOS9.x N CA Style Unsigned Cr*cked-FoXPDA
    The remaining battery time and more...
    Have you ever been concerned if your battery survives the whole day when far from the battery charger or have you experienced unexpected battery drain over a single day? If so, using iON BatteryTimer for S60 3rd will appreciably improve your day-to-day smartphone experience.
    It can be installed on any S60 3rd device with 320x240 and 640x360 pixels screen resolution while offering the control of operating time remaining to complete discharge, providing the estimated future date&time of the battery being completely discharged and presenting how long the battery holds its charge on average. The iON presents data in three ways: main application, standby plug-in, power saver.
    Features:
    Provides information about:
    Operating time remaining to complete discharge,
    Estimated future date&time of the battery being completely discharged,
    How long the battery holds its charge on average.
    Fast and handy access to remaining time at home/standby screen.
    Power saver with additional ‘big’ battery level percentage indicator, built-in system notifications (e.g. missed calls, messages, unread emails, current profile, keypad lock).
    Precautions
    During the installation process you will be prompted to accept copying data to your device internal memory - not an extra memory card. It will use only small amount of memory, about 150kb and is required for proper operation of the program. There is also a need to run background ?Core’''''''''' process which must start automatically each time device is booted. However, it utilizes negligible amount of CPU time (less than 1% once per minute).
    You have 9 days to test fully functional trial version and to activate the application afterwards. You can register your license key with one device (IMEI) for a lifetime and it cannot be transferred to any other device. It can be reinstalled and activated at the same device as many times as needed.
    The most accurate readings will be after 3-5 full charge/discharge cycles. So be patient, please.
    Quick start
    Follow these four quick steps to start using iON in the most effective way. Before proceeding make sure you have installed iON using appropriate .sis file and have accepted Precautions.
    Step 1 -Start the main applications
    After installation you should be able to find iON BatteryTimer icon among installed applications (e.g. path for Nokia N95 is MAIN MENU > APPLICATIONS > ION BATTERYTIMER). After starting the application you will see Trial mode and Welcome dialog.
    Step 2- Enable Standby plug-in
    Choose OPTIONS menu and STANDBY PLUG-IN > ON. It will activate Standby plug-in on home screen of your device, showing small battery icon and operating time remaining to discharge. If plug-in is enabled it will start automatically each time your phone is started.
    Step 3- Enable power saver
    If you prefer to test or use dedicated power saver choose iON Power saver from your device power savers menu (path for Nokia N95 is TOOLS > SETTINGS > GENERAL > PERSONALIZATION > THEMES >POWER SAVER).
    After 3-5 charge-discharge cycles iON will be the most accurate. Should some inexact estimation happens you are advised to fully charge battery and use RESET option from main OPTIONS menu.
    Step 4 – Enable Active Standby iON shortcut (optional)
    If you prefer fast access to all data provided by iON main application you can enable Active standby application shortcut at Standby mode settings (e.g. path forNokia N95 is MAIN MANU > TOOLS > SETTINGS > GENERAL > PERSONALIZATION > STANDBY MODE > ACTIVE STANDBY APPS. ). Choose Shortcut (e.g. SHORTCUT 3) and then find iON BatteryTimer radio button among all applications. Now you should see iON icon on the home screen.
    Whats New In Version 1.04 :
    Lack of icons on FP0 devices - fixed
    Standby plug-in startup error on FP0 devices - fixed
    Plugin procentage indication is back at the portrait mode
    Better overall estimation performance
    viet1812, vanmaidoicho and rockmeout like this.
  4. manbk401
    manbk401 Thành viên
    Capree iON BatteryTimer v1.04 S60v3 SymbianOS9.x Pinstripe Shilca Style Unsigned Cr@cked-FoXPDA
    It can be installed on any S60 3rd device with 320x240 and 240x320 pixels screen resolution while offering the control of operating time remaining to complete discharge, providing the estimated future date&time of the battery being completely discharged and presenting how long the battery holds its charge on average. The iON presents data in three ways: main application, standby plug-in, power saver.
    Features:
    • Provides information about:
      • Operating time remaining to complete discharge,
      • Estimated future date&time of the battery being completely discharged,
      • How long the battery holds its charge on average.
    • Fast and handy access to remaining time at home/standby screen.
    • Power saver with additional ‘big’ battery level percentage indicator, built-in system notifications (e.g. missed calls, messages, unread emails, current profile, keypad lock).
    Precautions
    Quick start
    If you prefer to test or use dedicated power saver choose iON Power saver from your device power savers menu (path for Nokia N95 is TOOLS > SETTINGS > GENERAL > PERSONALIZATION > THEMES > POWER SAVER).
    If you prefer fast access to all data provided by iON main application you can enable Active standby application shortcut at Standby mode settings (e.g. path for Nokia N95 is MAIN MANU > TOOLS > SETTINGS > GENERAL > PERSONALIZATION > STANDBY MODE > ACTIVE STANDBY APPS. ). Choose Shortcut (e.g. SHORTCUT 3) and then find iON BatteryTimer radio button among all applications. Now you should see iON icon on the home screen.
    • Lack of icons on FP0 devices - fixed
    • Standby plug-in startup error on FP0 devices - fixed
    • Plugin procentage indication is back at the portrait mode
    • Better overall estimation performance
    nguxudu1989 thích bài này.
  5. minhtue
    Capree Ltd iON Battery Timer v1.04 S60v3 SymbianOS9.1 Unsigned Cr*cked-ErESPDA
    Did you ever concern if your battery survive the whole day while far from the battery charger or did you experience unexpected battery drain down over a day? If so, using iON BatteryTimer for S60 3rd will appreciable improve your day-to-day smartphone experience.
    iON can be installed on any S60 3rd device with 320x240 and 240x320 pixels screen resolutions while offering the control of operating time remaining to complete discharge, providing the estimated future date and time of the battery being completely discharged and presenting how long the battery holds its charge on average. The iON provides data in three ways - the main application, the standby plug-in and dedicated power saver.​
    Compatible devices
    Nokia:
    E-series: e50, e51, e52, e55, e61, e61i, e62, e63, e65, e66, e71, e71-2, e71-3, e71x, e72, e75, e90,
    N-series: n71, n73, n75, n76, n77, n78, n79, n81, n81 8GB, n82, n85, n86 8MP, n92, n93, n93i, n95, n95 8GB, n96,
    Other models: 5320 XpressMusic, 5630 XpressMusic, 5700 (XpressMusic), 5710 XpressMusic, 5730 XpressMusic, 6110 Navigator, 6120 Classic, 6121 Classic, 6124 Classic, 6210 Navigator, 6220 Classic, 6290, 6650, 6710 Navigator, 6720 classic, 6730 classic, 6760 slide, 6790.​
    NothingCtrl and nguxudu1989 like this.
  6. Khỉ Con
    Capree iON BatteryTimer v1.05 S60v3/v5 SymbianOS9.x Unsigned *******-FOxPDA + E-Mod by c1cl0n@FoxPDA
    Did you ever concern if your battery survive the whole day while far from the A or did you experience unexpected battery drain down over a day? If so, using iON BatteryTimer for S60 will appreciable improve your day-to-day smartphone experience.
    Features
    * Provides information about:
    o Operating time remaining to complete discharge,
    o Estimated future date and time of the battery being completely discharged,
    o How long the battery holds its charge on average,
    * Fast and handy access to remaining operating time at the home/standby screen.
    * Power saver with additional the ‘big’ battery levels percentages indicator, built-in system notifications (e.g. missed calls, messages, unread emails, current profile, keypad lock).
    Precautions :
    During the installation you will be prompted for accepting required installation on your device memory not an additional card (uses small amount of memory, about 150kb). It also needs background ‘Core’ process which must starts automatically each boot time and utilizes device CPU in less than 1% once per minute.
    Whats New :
    * The latest iON version 1.05 with S60 5th support and 3rd edition improvements.
    met3ora and nguxudu1989 like this.
