CFW Firmware N97 v22.0.110 Hacked v5 by Pirates_Killer
Thảo luận trong 'S60 5th: FIRMWARE - SIGN - HACKPHONE' bắt đầu bởi Còm., 6 Tháng bảy 2010.
  1. Còm. Giả Vờ Hết
    These are custom firmwares. Only use J.A.F. to flash your phone, using any other flasher like Phoenix will make your phone to be dead. Use this cfw at your own risk, it may brick your phone.
    If you want Noob-friendly hacking, go HERE
    ScreenShots
    [​IMG][​IMG]
    [​IMG][​IMG]
    ALL LANGUAGES SUPPORTED
    NOW PRESENT:
    PIRATED v5 FINAL FOR N97 RM-505 v21.0.045, v21.0.102 and v22.01.110
    WARNING!!!!!
    1) Hard reset very needed to avoid conflict of homescreen and apps installed
    2) Never restore your backup just setting backup..don't restore setting...
    3) Format MMC is recommended or just delete E:\private E:\sys E:\system E:\resource E:\patches and F:\private F:\sys F:\system F:\resource F:\patches
    CHANGELOGS FOR NOKIA N97 PIRATED VERSION 5
    APPLICATION AND SETTINGS:-
    THEMES
    - Nseries 5 ( n97 mini -Gold original theme) by DhanuSaud
    - Kayu 2.0 by IND190
    - Horizon Black Lite by DhanuSaud
    APPLICATIONS
    - Rompatcher+ v2.3
    InstallserverRP+ auto on
    Open4allRP+ auto on
    OpenCRoot auto on
    - Autoinstaller v1.2
    - Bestscreensnap v2 installed in C:
    Image type: Jpeg - High Quality set automatically
    Base file name: Pirate set automatically
    Storage: Memory card set automatically
    - Killme v1.36 installed in C:
    - Xplore 1.45 with vista icons installed in C:
    Using Vista icons mod
    Show hidden files automatically
    Show RAM Drives automatically
    Show system files/folders automatically
    Sort by: Extension automatically
    Use system font automatically
    - Vivaz Conversation edited icon
    - Ramblow in Z:
    Memory boost set to auto
    30min idle it will cleanup
    Follow theme background
    - Bright Light Touch
    - Nokia File Browser v4.5.2
    - Pocket Sensor
    - Timer Lite v1.1
    FEATURED:-
    - Remote Lock still enabled
    - Voice Command still enabled
    - Nokia OVI Welcome (My Nokia) Disabled
    MODS
    SYSTEM CACHING AND PERFORMANCE:-
    - Running application will cache in E: for better performance
    - RAM totally Optimise at startup
    - Some Apps totally disabled on startup
    - Increases system memory heap size
    - Decreases application delay and close time taken by apps
    - UI Acceleration (reduce lags in apps)
    AUTO MAKE/COPY FOLDERS:-
    - E:\thinkchange\c
    - E:\thinkchange\e
    - E:\Music
    - E:\patches (auto copy patch)
    PATCHES:-
    - 2themes
    Change for HS folder in 10207254 from Z: to C:
    - Bluetooth Locker
    Bluetooth cannot be enabled
    - Deny New Installation
    Cannot Install Any Apps
    - Disable Default enhancement note
    Delete enhancement note when connected
    - DisableLogs
    Log will be disabled
    - DisableUSSDNotes
    USSD note disabled
    - Install Server RP+
    Enable install all unsigned, all caps apps
    - LCD Light ON
    LCD light always ON
    - LCD OFF Charge Complete
    When charging completed, LCD turn off
    - Long Multi Tap
    Increase delay time for all keys (a little bug)
    - NoBlankPassword
    No more ***** shows
    - Open4All RP+
    Open dir of sys, private
    - ReadCRoot
    Make nokia file manager to view all files in C:roots
    - Remove red LED
    Red LED removed in camera
    - Settings Deactivate
    Unable to open settings in menu
    - Short Multi Tap
    Decrease delay time for all keys (a little bug)
    - Switch Shutdown to Reboot
    Power button will responsible for rebooting phone
    - USB Data Disable
    Disable USB connectivity
    - 12 Month Call log
    Call log will stay for 12months
    - c2z4bin THUMB
    mapping bin to C:
    - Disable Profile switchNote
    No more profile switch note
    - Activate Bass Effects
    Give BASS effect to musics ( dont know works or not )
    PERSONALISATION:-
    - Using S60 Busy Cirle Menu
    - Shutdownscreen : S60
    - Splashscreen : S60
    - Bootscreen: S60 blinking by pirates_killer
    - Shutdown image removed for faster shutdown
    - Alarm snooze interval is set to 7min by default
    - Light Intensity set to 50% light by default
    - Theme Effects: Android Theme Effects In v5 by a1exyar, edited by grk007
    INSTALLATION:-
    - SwiPolicy changed which enable to install almost apps without installserver patch
    - Remove annoying widget security during installation of sis, sisx
    - Secure Widget Preinstall will not run on first startup, feel faster and ovi store will not work!!!
    - Java permission is default to be more secure
    SECURITY:-
    - Automatic lock phone in 30 seconds by default
    - Display light timeout set to 30 seconds by default
    - Maximum automatic lock phone can be set up to 10 minutes
    - Reenable remote locking after mistake in PiRaTeD v2
    MENU AND SENSORS:-
    - Tapping Mode added: shake to get phone silent/snooze alarm (off it at tapping control)
    CONNECTIVITY AND BROWSER:-
    - Nokia Default Internet Browser can go landscape with turning control OFF
    - Download manager will be started on browser start-up to resume
    - Nokia default file browser can send sisx, sis, jar and any protected items via bluetooth, mms and uploads
    - Nokia default file browser will open private, sys, C: root folder
    - FOTA reserved spaces in C: deleted: gain 5MB
    - Bookmark edited
    MESSAGING, CONTACTS AND HIDDEN APPS:-
    - Message to My Nokia will not send on startup
    - Delivery reports set to on by default
    - No. of message sent saved increase from 20 to 999 by default
    - Ovi Contacts totally disabled
    CAMERA:-
    - Camera sound is disabled only and only if Warning Tone is OFF
    - Camera will not leave in background after close it (SAVE RAM)
    VOICE RECORDING AND VOLUME:-
    - All automatically set to the highest quality
    - Now you can record up to 12 Hours!!!!
    - Internal speaker automatically set to maximum when calling
    - Loudspeaker automatically set to normal 5/10
    - Bootscreen volume slowed: Normal volume
    - Voice recording during call fixed
    MUSIC PLAYER AND GALLERY
    - Put all songs file in E:\Music and F:\Music
    - Music player only read E:\Music and F:\Music location
    - Faster to refresh
    - Gallery Improved to find files
    SPECIAL LITTLE MODD By Varfolomey
    With this mod N97 users can wake up device from stanby mode(activate display light) by touching the touch screen like in 5800,before that
    you had to press any button,menu button for example to turn the display light on.so no need to press button anymore.
    100% working
    Bonus Ringtones
    - Ovi Sound
    - Ovi Nokia
    - Tiger's roar
    you can find them in profile settings
    OVERVIEWS FOR NOKIA N97
    - RAM after reboot: 60mb
    - RAM after clean up: 57.52mb
    - C: drive space after reboot: 59.2mb (the screenshots above show 54mb because i have installed ovi store in C)
    - RAM experinces may different due to language in rofs2
    MUST!!!!! READ THIS NOTICES BEFORE DOWNLOAD!!! IGNORING THIS, YOU GET NOTHING!!!!
    1) Do hard reset before and after flashing
    2) Remove E:\sys E:\system E:\resource E:\private E:\patches or FORMAT MMC before flashing
    3) Please let your phone for 3 minutes until it ask you to reboot
    DOWNLOAD
    used :download file "RM-505_22.0.110_C01_prd.rofs3.fpsx" , chép đè file này vào C:\Program Files\Nokia\Phoenix\Products\RM-505 sau đó dùng JAF Flash FW như bình thường! các bạn có thể tham khảo thêm về cách JAF bên NÀY
    nguồn:symbiantalk
    nguyen bao, hson, TomRyan8891 and 2 others like this.
  2. nguyen bao
    nguyen bao Thành viên
    làm cái này thì có cần format lại máy và ổ 32g ko bộ nhớ máy mình chỉ còn trống có 73.0/7,7mb thôi máy mình FW22 rùi và đã hack từ FW21 sau đó dùng dt up lên lun ko mất hack giờ làm theo cái này thì fai làm sao mong dc giúp đỡ
  3. hoangcung1939
    hoangcung1939 Ex-Mod
    Như dòng cảnh báo ở trên
    Tốt hơn hết là e nên Format lại sạch sẽ hết những bộ nhớ ( phone memory, bộ nhớ tích hợp và cả thẻ nhớ luôn ), sau đó mới Flash cái này vô máy để máy hoạt động ổn định hơn ha. Vì đây là Cook FW nên đã được tích hợp sẵn chương trình H@ck ( Rompatcher ) luôn rùi nên không cần phải ngại H@ck phone lại. Have fun
    junying, nguyen bao and TomRyan8891 like this.
  4. nguyen bao
    thanks anh nhiều để thử cái đã hehe
  5. junying
    junying Thành viên
    em không biết link chỗ nào để dowload hết mong sớm thấy
    TomRyan8891 thích bài này.
  6. Be Yeu
    Chỗ có chữ DOWNLOAD và chữ NÀY khác màu trên bài viết đó !
    DOWNLOAD
    junying thích bài này.
  7. junying
    junying Thành viên
    cho em hỏi một chút, em dùng navifirm dowload fw 22.0.110 về để chạy phoenix chép đè RM-505_22.0.110_C01_prd.rofs3.fpsx vào file dowload về từ Navifirm, khi chạy phoenix báo lỗi không Flash được mong chỉ cho em cách làm với
  8. nguyen bao
    ko nên dùng phoenix để hack FW này chỉ dùng JAF thoi nha bạn
  9. nguyen bao
    sao khi đến select phone model ko thấy n97 đâu hết zậy giúp e với
  10. Be Yeu
    Bạn dùng thêm thằng jaf_nok4models giải nén ra rồi chép đè ( over write ) vào C:\Program Files\ODEON\JAF nhé !
    nguyen bao thích bài này.
