KEmulator Lite v0.9.8 Play Nokia/SE - Java 3D games on your PC !!! Special thanks to jbpseudo for providing this beautiful emulator KEmulator is a mobile java game emulator aimed at the game developers. KEmulator provides kinds of utilities making our developers more effectively, and it supports most of the popular mobile platforms. Whats more is that with this application you can even open java apps like opera mini, ucweb, etc. as such as you open it from your phone (including net facilities) PS : Lite version is free and i it has all the features necessary, like jsr75, proxy input, screen size adjustment, keypad mapping etc It's written in java, and the UI is based on SWT© win32.Now, the follow APIs are implemented: MIDP 2.0(JSR118) NokiaUI 1.1 Samsung 1.0 Sprint pcs M3G 1.1(JSR184) OpenGL ES(JSR239) WMA1.0(JSR120) Bluetooth(JSR82) PDA PIM(JSR75) System Requirement : Windows 2000 or later JDK1.4.2 or later Usage Run KEmulator.exe 1.Menu: Midlet->Load Jar/Load with console. 2.Drag a *.jar into the shell, as the Drag & Drop of Windows Useful Tips of KEmulator Menu->Tool 1. Zoom in/out, default 200% 2. Ticks, design for GD(Game Designer) as a timer. 3. Capture/Record, save to "/capture" folder. 4. Speed up/Down, speed up the game rate. 5. Record keys/Enable Autoplay, refer to the Autoplay. Menu->View->Options... 1. Custom settings: 2. Key Map: 3. System settings: Download: KEmulator Lite Version {0.9.8} (2.6MB, need to install JRE/JDK) Mã: http://mges.googlecode.com/files/KEmulator_lite_win32_release_098_200812042313.zip http://rapidshare.com/files/182495003/KEmulator_lite_win32_release_098_200812042313.zip KEmulator Lite Version with JRE inside {0.9.8} (16.4MB, do not need to install JRE/JDK) Mã: http://mges.googlecode.com/files/KEmulator_lite_win32_release_098_jre_200812042313.zip http://rapidshare.com/files/182494337/KEmulator_lite_win32_release_098_jre_200812042313.zip
Cái này hay nhưng chơi trên PC chắc hỏng mắt quá.Thui cứ chơi trên Di động là được rồi.Của cái nào thì xài cái đó.
đúng rồi đó bác.Ngage cũng có cái phần mềm này để test game java.Mà bác cho em hỏi có mấy cái link down.Phải down đủ cả KEmulator Lite Version {0.9.8} (2.6MB, need to install JRE/JDK) và KEmulator Lite Version with JRE inside {0.9.8} (16.4MB, do not need to install JRE/JDK) mới chạy được hay chỉ cần down 1 cái thôi
