[BCOLOR=rgb(252, 252, 255)]APPLE:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK Air MD231[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i5 Ivy Bridge 3427U 1.8ghz L3 4MB Cache[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 4GB DDR-3 (1600 MHz) upto 8GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]13.3-inch LED HD 1440x900 CineCrystal LED-backlit[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]SSD 128 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 2.1[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Multi-Gesture Touchpad allows you to pinch.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]WCam, Mic, USB 3.0, Multi-in-1 Digital Media Card Reader...[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 10 hours of battery life[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng còn Bảo hành APPLE CARE 12 tháng.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá 19,2tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK AIR 13″ Mid 2011[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CPUCore i5 1.7 SANDY – 2557M[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ram4GB (2x4GB SO-DIMMs) of 1333MHz DDR3[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display13.3-inch LED, 1440×900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GraphicsIntel HD3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]SSD128 Gb[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]WebcamCamera FaceTime HD 720p camera[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]NetworkSD card slot – Wireless – Bluetooth[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]OSMac OS X Mountion Lion[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]BatteryBuilt-in 10-hour battery, 60W MagSafe Power Adapter with cable[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ 15tr800[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK PRO 13″ Mid 2012[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CPUIntel Core i5 2.5GHz quad-core (6Mb Cache) 3210QM[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ram4GB(2x2GB SO-DIMMs) of 1600MHz DDR3 SDRAM, up max 16 Gb[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display15.4-inch (diagonal) LED-backlit glossy widescreen display, 1440×900 resolution[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GraphicsIntel HD4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 750 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]ODD8X Super Drive Double Layer (DVD±RW Double Layer)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]WebcamCamera FaceTime HD 720p camera[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]NetworkSD card slot – Wireless – Bluetooth[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]OSMac OS X Mountion Lion[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]BatteryBuilt-in 10-hour battery, 60W MagSafe Power Adapter with cable[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]BH Apple5/7/2014[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ 18tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK PRO 13″ Late 2011[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CPUCore i5 2.4ghz SANDY – 2435M[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ram4GB (2x2GB SO-DIMMs) of 1333MHz DDR3 SDRAM, up max 16 Gb[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display13.3-inch LED, 1440×900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GraphicsIntel HD3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500 Gb[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]ODD8X Super Drive Double Layer (DVD±RW Double Layer)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]WebcamCamera FaceTime HD 720p camera[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]NetworkSD card slot – Wireless – Bluetooth[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]OSMac OS X Mountion Lion[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]BatteryBuilt-in 10-hour battery, 60W MagSafe Power Adapter with cable[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ 16tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK 15":[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK PRO MC723 15" late 2011[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 Sandy Bridge 2720QM 2,2Ghz 6MB Cache[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 4GB DDR-3 (2x2GB 1333 MHz) upto 16GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]15.4-inch (diagonal) LED-backlit glossy widescreen display, 1440x900 resolution[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]750GB HDD 5400rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Graphic:AMD Radeon HD 6750M graphics processor with 1 Gb +Intel HD3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 2.1[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Multi-Gesture Touchpad allows you to pinch.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]WCam, Mic, USB 3.0, Multi-in-1 Digital Media Card Reader...[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Built-in 10-hour battery, 85W MagSafe Power Adapter with cable[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MAC OS X[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá 23tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK PRO 15″ 2011 BTO[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 2.2GHz quad-core (6MB Cache)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ram 8GB (2x4GB SO-DIMMs) of 1333MHz DDR3 SDRAM, up max 16 Gb[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display15.4-inch (diagonal) LED-backlit glossy widescreen display,1680×1050 resolution[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Graphics: AMD Radeon HD 6750M graphics processor with 512 MB + Intel HD3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD750 GB 5400 rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]ODD8X Super Drive Double Layer (DVD±RW Double Layer)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]WebcamCamera FaceTime HD 720p camera[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]NetworkSD card slot – Wireless – Bluetooth[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]OSMac OS X Mountion Lion[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]BatteryBuilt-in 10-hour battery, 85W MagSafe Power Adapter with cable[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ 22tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK PRO 15″ 2011 BTO (Built to Oder)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CPUIntel Core i7 2.3GHz quad-core (6Mb Cache) – 2820QM[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ram8GB(2x4GB SO-DIMMs) of 1333MHz DDR3 SDRAM, up max 16 Gb[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display15.4-inch (diagonal) LED-backlit glossy widescreen display,1680×1050 resolution[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Graphics: AMD Radeon HD 6750M graphics processor with 1 Gb + Intel HD3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD750 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]ODD8X Super Drive Double Layer (DVD±RW Double Layer)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]WebcamCamera FaceTime HD 720p camera[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]NetworkSD card slot – Wireless – Bluetooth[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]OSMac OS X Mountion Lion[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]BatteryBuilt-in 10-hour battery, 85W MagSafe Power Adapter with cable[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]BH Apple5/3/2014[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ 23tr500[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK PRO 15″ MID 2012[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CPUIntel Core i7 2.3GHz quad-core (6Mb Cache) 3615QM[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ram8GB(2x4GB SO-DIMMs) of 1600MHz DDR3 SDRAM, up max 16 Gb[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display15.4-inch (diagonal) LED-backlit glossy widescreen display, 1440×900 resolution[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Graphics: GeForce GT 650M + Intel HD4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]ODD8X Super Drive Double Layer (DVD±RW Double Layer)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]WebcamCamera FaceTime HD 720p camera[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]NetworkSD card slot – Wireless – Bluetooth[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]OSMac OS X Mountion Lion[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]BatteryBuilt-in 10-hour battery, 85W MagSafe Power Adapter with cable[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]BH Apple 2014, 2015, 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ 26tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK PRO ME664 , 15” Retina 2013[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA New 99,99999% mới mua bên Mỹ[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Dòng Macbook Retina mới nhất 2013, Siêu mỏng gọn, Cấu hình rất mạnh chuyên ĐỒ HỌA[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 3630QM (8x 2.4hz, Turbo bost 3.4ghz, 6MB cache) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 inch Retina (2880×1800) – True Colors[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: 2 VGA :nVIDIA GT 650M (1 GB) VGA MẠNH CHUYÊN NGHIỆP + Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- SSD 256 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đèn bàn phím sáng…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 10h NEW 99,9999% NHƯ MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gía:40tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]MACBOOK PRO 17":[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Macbook Pro 17 MD311[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Macbook Pro MD311, 2012, xách tay USA, 17.3 Full HD, Hàng VIP cho dân Gamer, đồ họa và làm phim ảnh.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 2760QM (8 x2.4Ghz, Turbo Bost 3.5ghz) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 8 GB DDR3 (1333 MHz), up Max 32GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display 17-inch full HD, 1920×1200 resolution – TRUE COLOR[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 750 GB, 7200 rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]2 VGA: ATi 6770M + Intel Graphics Media Accelerator HD3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, WCam, Mic, Keyboard ledlight, Multi-in-1 Digital Media Card Reader...Full Options[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 6 hours of battery life, 85W Magsafe Power Adapter with cable[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng bảo hành 06 tháng[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gía Apple Store New 2.499 USD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIá:28tr500[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL Precision M4700[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Dòng máy Trạm cực mạnh, siêu bền cho dân Design, Gamer chuyên nghiệp, cấu hình cực mạnh.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 3740 QM ( 8x 2.7Ghz Turbo Bost 3.7ghz, 8Mb cache) Ivy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 16 GB DDR3 (1600 MHz), 4 Slot[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]15.6-inch Anti Glare Ultrasharp 1920x1080p[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]SSD 256 GB SATA 3[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]nVIDIA Quadro K2000M 2GB + Intel Graphics Media Accelerator HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, Finger Print, WCam, Keyboard led, Multi-in-1 Digital Media Card Reader...Full options.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 4 hours of battery life (9-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng còn bảo hành toàn cầu 03 Năm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:34tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL Precision M4600[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Dòng máy Trạm cực mạnh, siêu bền cho dân Design, Gamer chuyên nghiệp, cấu hình cực mạnh.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 99,9%- Mobile WorkStations Bảo Hành toàn cầu 5 năm 2018.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 2860QM (8x 2.5hz, Turbo bost 3.5ghz, 8MB cache) SANDY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 inch DELL UltraSharp- Anti Glare – 1920x1080p FULL HD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: Quadro 2000M (2GB – 128bit) VGA MẠNH CHUYÊN NGHIỆP+Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm zin theo máy[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, USB 3.0…. FINGER PRINT, BACKLIT[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 9 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,9 RẤT ĐẸP[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- ADAPTOR 180W[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:23,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL PRECISION M4400[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]– Mobile WorkStations / chơi game thì khỏi chê[/BCOLOR] [BCOLOR=rgb(252, 252, 255)](hỗ trợ nâng cấp với giáKM SSD Lite-on 120GB sata 3 tháo máy DELL giá 1,8tr)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 1:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core2 extreme X9100 3Ghz cache 6MB cực mạnh[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR2[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.4 inch – Full HD 1920x1080p – Sieu sang[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: - Quadro FX1700M VGA MẠNH CHUYÊN NGHIỆP- dòng option cao nhất ( mạnh hơn mấy con FX770 nhiều)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 250 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đèn chiếu phím sáng, USB 3.0, FINGER…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 9 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99% RẤT MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:10tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 2:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core2 T9550 3Ghz cache 6MB cực mạnh[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR2[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.4 inch – Full HD 1920x1080p – Siêu sáng[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: - Quadro FX1700M VGA MẠNH CHUYÊN NGHIỆP- dòng option cao nhất ( mạnh hơn mấy con FX770 nhiều)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 250 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đèn chiếu phím sáng, USB 3.0, FINGER…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 9 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99% RẤT MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:9,3tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL Latitude E6530[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 1:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 3720M 3Ghz IVY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 inch – Anti Glare – 1920x1080p Full HD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: nVIDIA Quadro NVS 5200M (1GB) VGA MẠNH + Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đèn bàn phím, USB 3.0,…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 99,999%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH DELL 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:18,8tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 2:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 3320M 2.6ghz IVY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 inch – Anti Glare – 1600×900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: 2 VGA up to 6GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- nVIDIA Quadro NVS 5200M (1GB) VGA MẠNH + Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 320 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đèn bàn phím, USB 3.0,…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,99% NHƯ MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 99,999%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH DELL 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:16tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL LATITUDE E6430[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 1:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 99,999%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH DELL 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 3720QM 2.6ghz tubor bost 3.6GHz IVY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch – Anti Glare – 1600×900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Nvidia Quadro NVS 5200M + Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đènphím sáng, USB 3,…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,99% NHƯ MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Giá:18,2tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 2:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 99,999%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH DELL 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 3320M 2.6ghz IVY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch – Anti Glare – 1600×900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 320 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đènphím sáng, USB 3,…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,99% NHƯ MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Giá:15tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL LATITUDE E6420[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 1:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 2720M 2.2ghz tubor bost 3.3 Ghz 6 MB cache SANDY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch – AntiGlare – FHD+ 1600×900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- 2 VGA up to 4GB -Quadro NVS 4200M + Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, WCam HD, Đèn bàn phím sáng, USB 3.0…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 9 cell ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 98%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành toàn cầu[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:13,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 2:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 2640M 2.8 Ghz tubor bost 3.5Ghz 4Mb cache SANDY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch – AntiGlare – FHD+ 1600×900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- 2 VGA up to 4GB -Quadro NVS 4200M + Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, WCam HD, Đèn bàn phím sáng, USB 3.0…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 9 cell ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 98%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành toàn cầu[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:12,8tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 3:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 99%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành DELL 2015.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 2520M ( 2.5ghz turbo boot 3.2Ghz , 3MB Cache) Sandy[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch Anti Glare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up 1696 MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 320 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, WCAM…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- GIá:10,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL Latitude E6330[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 99,999%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH DELL 2016- Core i7 3520M 2.9ghz IVY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 13.3 inch – Anti Glare HD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up to 1.7GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đènphím sáng, USB 3,…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,99% NHƯ MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:16,8tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL Latitude E6320 , LCD 13.3 inch ( 2 máy )[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 99%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành DELL 2015.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 2520M 2.5ghz, Sandy[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 13.3 inch Anti Glare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up 1696MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 320 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, WCAM…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Giá:10,4tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL Latitude E4310[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i5 520M (2.5Ghz, 4Mb cache)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 4 GB DDR3 (1333 MHz), 2x2GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 250 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]13.3-inch Anti Glare.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Graphics Media Accelerator up 1.7GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, Finger Print, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader...Full options.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 5 hours of battery life (6-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:7,5 tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL Latitude E5420 , Core i5[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 99%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành DELL 2015.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 2550M ( 2.5ghz turbo boot 3.2Ghz ) 3MB Cache, Sandy[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch Anti Glare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up 1696 MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 320 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, WCAM…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Giá: 10,5 tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL Latitude E6410 , LCD 14 inch ( CÓ SỐ LƯỢNG ĐỂ CHỌN )[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 98%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành DELL 2014.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 520M 2.4ghz,[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch Anti Glare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up 1696MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD i5[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 250 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, WCAM…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 3h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá: 7,9 tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL Latitude E4310 , LCD 13.3 inch ( CÓ SỐ LƯỢNG ĐỂ CHỌN )[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 98%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành DELL 2014.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 520M 2.4ghz,[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 13.3 inch Anti Glare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up 1696MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD i5[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 160 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, WCAM…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 3h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:7,9tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL inspiron 15Z , 15.6inch mỏng nhẹ, 2013[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA like New[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH DELL 1 năm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 3317U ( 1.7ghz turbo boot 2.6Ghz ) IVY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 6 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 inch – Anti Glare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up to 1.7GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- SSD 24 + HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đènphím sáng, USB 3,…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 5h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Like New[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:13tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL XPS L421X, 2013 NHÔM UNIBODY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 99,99[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Mới mua BH DELL Lâu[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 3317U 1,7ghz tubor bost 2,6GHZ IVY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14inch – 1600x900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: GT 630M 2GB 128bit[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, USB 3.0..DVD…Đèn phím sáng[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,99[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ: 16tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DELL XPS 15 NHÔM UNIBODY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 99,99[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Mới mua BH DELL Lâu[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 2720QM IVY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6inch FULL HD 1920x1080p[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: GX 540M 2GB 128bit[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 750GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, USB 3.0..DVD…Đèn phím sáng[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,99[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ: 16,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LEVOVO YOGA 13[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ultrabook, Màn hình xoay gấp, Cảm ứng như IPAD, Dòng VIP, siêu mỏng nhẹ, Hàng USA, Brand New FULL BOX, Màu đen xám[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i5 3337U (1.8Ghz, Turbo Bost 2.7ghz) IVY Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 4 GB DDR3 (1600ghz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]13.3-inch Cảm ứng đa điểm cực nhạy, (1600x900)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]SSD 128 GB. WIN 8 license[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel HD 4000 up 1696 MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader...Full Options[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 8 hours of battery life[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng bảo hành toàn cầu 1 năm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:19tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LENOVO P400 touch siêu mỏng[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH toàn cầu Lâu[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 3632 QM (8x 2.2hz, Turbo bost 3.3ghz, 6MB cache) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14.0 1600x900p FULL HD + Cảm ứng cực nhạy[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 1TB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCAM HD, DVD RW, USB 3.0, Đèn phím sáng BACKLIT, FINGER PRINT…. FULL OPTION[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WIN 8 License[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:15,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LENOVO Y410P[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Máy khủng cho gamer, đồ họa[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Core i7 HASWELL Quadcore 4700QM ( 8×2.4ghz Turbo bost 3.4ghz, 6MB CACHE)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch – FULL HD 1920×1080[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- 2 VGA: up to 10 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- nVIDIA GT 750M 2GB, CỰC KHỦNG + Intel HD 4600[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 1 TB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đèn phím sáng, USB 3.0…FULL OP[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6CELL[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá: 21tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LENOVO THINKPAD W701[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Mới xách tay về em IBM W701 hàng trâu bò của IBM , máy còn đẹp keng , zin 100% , mới 99% . siêu bền .Hàng USA NEW 99% – Mobile WorkStations[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Core i7 720QM @ (8x 1.6hz, Turbo bost 2.8ghz, 6MB cache)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 17.3 inch – FULL HD 1920×1080[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up to 6GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Nvidia Quadro FX2800 (1 GB) VGA MẠNH CHUYÊN NGHIỆP + Intel HD3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đèn chiếu phím sáng, USB 3.0… bàn di chuột lớn, bút staylus[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 9 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99% RẤT MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá : 22.500.000 VNĐ[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LENOVO Thinkpad W530 workstation[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 1:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng USA NEW 99,9% – Mobile WorkStations[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành toàn cầu 3/ 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 384QM @ (8x 2.8hz, Turbo bost 3.8ghz, 8MB cache) SANDY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 32GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 inch – FULL HD 1920×1080- IPS- AntiGlare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Quadro K2000M (2 GB) MẠNH CHUYÊN NGHIỆP + Intel Graphic HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- SSD 256GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đèn chiếu phím sáng, USB 3.0…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,9% RẤT MỚI no BOX[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gía:34tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 2:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng USA NEW 99,9% – Mobile WorkStations[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành toàn cầu 3/ 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 3720QM @ (8x 2.6hz, Turbo bost 3.6ghz, 6MB cache) SANDY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 inch – FULL HD 1920×1080- IPS- AntiGlare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up to 6GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Quadro K1000M (2 GB) VGA MẠNH CHUYÊN NGHIỆP + Intel Graphic HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- SSD 180 GB Intel[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, Đèn chiếu phím sáng, USB 3.0…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 9 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,9% RẤT MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gía:29,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Lenovo Thinkpad W520 workstation[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 2760QM (8x2.4Ghz, 6Mb cache) Sandy BridgeRAM 8 GB DDR3 (1333 MHz) 2x4GB of 4 slot[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]15.6-inch FHD Anti Glare 1920x1080p.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]nVIDIA Quadro NVS 1000M (2 GB) up to 9GB vs Ram + Intel Graphic HD3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, Finger print, USB 3.0, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader...Full options.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 6 hours of battery life (9-cel)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng còn bảo hành toàn cầu 3 năm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:22tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LENOVO THINKPAD T430s[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 3520M (2.9Ghz Turbo Bost 3.6ghz, 4Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 8 GB DDR3 (1333 MHz)up to 16 GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]14.0-inch Anti Glare 1600x900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Nvidia Quadro NVS 5400M + Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, Finger Print, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader...Full options.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 5 hours of battery life (6-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng bảo hành toàn cầu 2015.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:18,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LENOVO THINKPAD T430[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 1:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 3520M (2.5Ghz Turbo Bost 3.2ghz, 4Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 4 GB DDR3 (1333 MHz), 1x4GB. up to 16 GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]14.0-inch Anti Glare.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Graphics Media Accelerator HD3000 up to 1696MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, Finger Print, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader...Full options.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 5 hours of battery life (6-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng bảo hành toàn cầu 2015.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:16tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 3520M (2.9Ghz Turbo Bost 3.6ghz, 4Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 8 GB DDR3 (1333 MHz), 1x4GB. up to 16 GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]14.0-inch Anti Glare 1600x900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Nvidia Quadro NVS 5400M + Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, Finger Print, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader...Full options.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 5 hours of battery life (6-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng bảo hành toàn cầu 2015.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:18tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LENOVO THINKPAD T420[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 2620M (2.5Ghz Turbo Bost 3.2ghz, 4Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 4 GB DDR3 (1333 MHz), 1x4GB. up to 16 GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]14.0-inch Anti Glare 1600x900[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Graphics Media Accelerator HD3000 up to 1696MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, Finger Print, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader...Full options.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 5 hours of battery life (6-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng bảo hành toàn cầu 2015[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:11tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LENOVO THINKPAD T520 , 2012[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA NEW 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành toàn cầu 3 năm 2015[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 2520M 2.5ghz, SANDY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 Anti Glare HD+[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA:Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 320 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, WCam HD, Đèn chiếu bàn phím sáng, USB 3.0…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 9 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ: 10tr700[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]LENOVO Thinkpad X1 Carbon[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 1:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DÒNG ULTRA VIP cho tín đồ Thinkpad[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 3420U @ (1.8ghz Turbo Bost 2.4ghz) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch – IPS 1600×900-[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up to 1804 MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- SSD 128 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD,FINGER, USB 3.0…FULL OP[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 8h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW full BOX[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng US new 100% BH còn rất lâu[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:19,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 2:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DÒNG ULTRA VIP cho tín đồ Thinkpad[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 3667U (2.0ghz Turbo Bost 3.2ghz) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch – IPS 1600×900-[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up to 1804 MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 4000 up to 1,7GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- SSD 256 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD,bluetooth, HDMI, FINGER, USB 3.0…FULL OP[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 8h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW no BOX[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng US new fullbox 100%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH còn rất lâu[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:24,8tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Lenovo Thinkpad X230[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành toàn cầu 03 năm 2016.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 3520M (2.9ghz, 4MB cache) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 12.5 inch IPS – AntiGlare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: up to 1745 MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 320 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, USB 3.0…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 6h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,99% NHƯ MỚI[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:16,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Lenovo Thinkpad X220[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i5 2520M (2.5Ghz, turbo bost 3.2ghz, 4Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 4 GB DDR3 (1333 MHz). 1x4GB up 32GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]12.5-inch Anti Glare. (1366x768)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 320 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Graphics Media Accelerator HD 3000 up to 1.7GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Finger Print, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader...Full options.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 5 hours of battery life (6-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng còn bảo hành toàn cầu 2015.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:12,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP 8760W Mobile Workstation[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 1:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Mobile WorkStations Bảo Hành toàn cầu tới 2016.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 2860QM (8x 2.5hz, Turbo bost 3.6ghz, 8MB cache) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM:8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 17.3 inch- Anti Glare – 1920x1080p FULL HD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: ATI M5950M 2GB MẠNH CHUYÊN NGHIỆP+Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, USB 3.0….[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:24tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 2:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Mobile WorkStations Bảo Hành toàn cầu tới 2016.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 2860QM (8x 2.5hz, Turbo bost 3.6ghz, 8MB cache) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM:8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 17.3 inch- Anti Glare – 1920x1080p FULL HD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: nVidia Quadro 3000M 2GB cực mạnh + Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, USB 3.0….[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:24,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Cấu hình 3:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Mobile WorkStations Bảo Hành toàn cầu 3 năm 2016.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 2760M (8x 2.4hz, Turbo bost 3.5ghz, 6MB cache) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM:8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 17.3 inch- Anti Glare – 1920x1080p FULL HD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA:nVidia Quadro 3000M 2GB cực mạnh + Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, USB 3.0….[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:23tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP 8570W Mobile Workstation[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Mobile WorkStations Bảo Hành toàn cầu 3 năm 2016.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 3740QM (8x 2.7hz, Turbo bost 3.7ghz, 6MB cache) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 16 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 inch- Anti Glare – 1920x1080p FULL HD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: 2 VGA[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Quadro K1000M (2 GB) VGA MẠNH CHUYÊN NGHIỆP+Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 750 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, USB 3.0….[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 9 cell ~ 4h- NEW 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:27,7tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP 8470w Mobile WorkStations[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 3630QM ( 8x 2.4Ghz Turbo Bost 3.5ghz, 6Mb cache) Ivy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 8 GB DDR3 (1600 MHz), 2x4GB up to 32 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]14.0-inch Anti Glare.( 1600x900)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]ATi FirePro M2000 + Intel Graphics Media Accelerator HD 4000 up to 5GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, Finger Print, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader...[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 6 hours of battery life (9-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng còn bảo hành toàn cầu 03 Năm tới 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gía:21 tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP 8560w – Mobile WorkStations[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 2620M (2.7Ghz, 4Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 8 GB DDR3 (1600ghz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]15.6-inch Anti Glare FHD 1920x1080p[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]VGA Quadro 1000M 2GB + Intel HD 3000 up 6GB vs Ram, ĐỒ HỌA CHUYÊN NGHIỆP[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, WCam 2.0, Keyboard led, Finger Print, Multi-in-1 Digital Media Card Reader...Full Options[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 4 hours of battery life (6-cell)Hàng chính hãng bảo hành toàn cầu 2 năm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:19tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP Elitebook 8470p[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 3340M 2.7ghz IVY BRIDGE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14inch – IPS- AntiGlare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA:Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCam HD, đèn chiếu phím sáng, USB 3.0, FINGER Print…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 6h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:15tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP Elitebook 8460p[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 2620M (2.7Ghz, 4Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 4 GB DDR3 (1333 MHz), 2x4GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]14.0-inch Anti Glare (1600x900).[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 500 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ati Radeon HD 6470M 1GB up to 4GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, WCam 2.0, Keyboard led, Finger Print, Multi-in-1 Digital Media Card Reader...Full Options[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 4 hours of battery life (6-cell)Hàng chính hãng còn bảo hành toàn cầu 02 năm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:12,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP Probook 4430s[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP Probook 4430s, Vỏ kim loại mát lạnh, Model rất đẹp và cứng cáp..[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i3 2330M (4x 2.3Ghz, 3Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 2GB DDR3 (1333MHz) up MAX 16GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 640 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]14-inch LED HD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]VGA Intel Graphics HD 3000 Media Accelerator up 1696 MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, USB 3.0, WCam 2.0, Keyboard Ledlight, Multi-in-1 Digital Media Card Reader...Full options.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 4 hours of battery life (6-cell)Hàng chính hãng còn bảo hành 03 tháng[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:7,4tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP Probook 6460b[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i5 2520M @ 2.5ghz SANDY BRIGDE[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4 GB DDR3 (1333 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 14 inch – AntiGlare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA:up to 1696 MB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Intel HD 3000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 320 GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, USB 3.0…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,999% LIKE NEW[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Còn BH toàn cầu HP 2015[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:8,7tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP Elitebook 2560p[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i5 2520M (2.5Ghz tubor bost 3,2GHZ, 4Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 4 GB DDR3 (1333 MHz), 2x4GB.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]12.5-inch Anti Glare (1366x768).[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 320 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, WCam 2.0, Keyboard led, Multi-in-1 Digital Media Card Reader.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 4 hours of battery life (6-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:10,2tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP Elitebook 2560P[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng new 99,9 %[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH tới 2015[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CPU : core i5 2520M (4x2.5Ghz , Turbo boot 3.2 Ghz , cache 3Mb ) Sandy Brigde[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM : 4G DDR3 ( 1333mhz )[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display : 12.5 inch , AntiGlare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD : 320GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]VGA : Intel HD Graphics 3000 up to 1.7G[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Option : blacklist , multi-in-1 Digital Media Reader .....[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Pin : 6 cell up to 4 hours of battery life[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá : 9tr800[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP Elitebook 2570P[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng new 99,9 %[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH tới 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CPU : core i5 3320M (4x2.6Ghz , Turbo boot 3.3 Ghz , cache 3Mb ) Ivy Brigde[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM : 4G DDR3 ( 1600mhz )[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display : 12.5 inch , AntiGlare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD : 320GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]VGA : Intel HD Graphics 4000 up to 1.7G[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Option : Webcam, blacklist , multi-in-1 Digital Media Reader .....[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Pin : 6 cell up to 4 hours of battery life[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá : 13tr500[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HP Elitebook 2170P[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng new 99,9 %[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH tới 2016[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CPU : core i5 3427U (4x1.8Ghz , Turbo boot 2.8 Ghz , cache 3Mb ) Ivy Brigde[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM : 4G DDR3 ( 1600mhz )[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Display : 12.5 inch , AntiGlare[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]SSD : 180GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]VGA : Intel HD Graphics 4000 up to 1.7G[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Option : Webcam, blacklist , multi-in-1 Digital Media Reader .....[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Pin : 6 cell up to 4 hours of battery life[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá : 15tr300[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Asus G53S[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá :20tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CPU : core i7 2670QM (8×2.2Ghz , Turbo bost 3.1Ghz , Cache 6Mb ) Sandy Brigde[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ram : 8G DDR3 ( 1600Mhz )[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD : 500GB 7200rpm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Dislay : 15.6 inch Full HD 1920×1080 - Anti glade[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]VGA : Nvidia Geforce GTX 560M 2GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD-RW, USB3.0...[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Pin~3h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]No box[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]ASUS G75VW Gaming Laptop - dòng VIP like new[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 3630QM (8x2.4Ghz tubor bost 3,6Ghz) Ivy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 8 GB DDR3 (1600Mhz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]17.3 inch Full HD (1920x1080p).[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 1TB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]NVIDIA GTX 660M 2GB DDR5[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000),[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Bluetooth 3.0DVD DL RW[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Window 8 Like new, còn BH[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá 25,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]ASUS Q500A hợp Kim nhôm, 15.6 Full HD 1920x1080p CẢM ỨNG[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Hàng USA 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- BH toàn cầu Lâu[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 Quad core 3632 QM (8x 2.2hz, Turbo bost 3.3ghz, 6MB cache) IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 8 GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15.6 inch – 1920x1080p FULL HD, Cảm ứng cực nhạy[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA:- Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 1000 GB 1TB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WCAM HD, DVD RW, USB 3.0, Đèn phím sáng BACKLIT, FINGER PRINT…. FULL[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW 99,9%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- WIN 8 License[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ:15,5tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]ASUS N53S[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Intel Core i7 2670 QM (8x2.4Ghz, 6Mb cache) Sandy Bridge[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]RAM 10 GB DDR3 (1600ghz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]15.6-inch Anti Glare Full HD (1920x1080p).[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]HDD 750 GB 7200rpm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]nVIDIA GT 630M 2GB + Intel Graphic HD 3000 up 9GB vs Ram[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Wireless-N Wi-Fi (802.11b/g/n) for connectivity.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Gigabit Ethernet (10/100/1000), Bluetooth 3.0[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DVD RW, WCam 2.0, Keyboard led, Finger Print, Multi-in-1 Digital Media Card Reader...Full Options[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Up to 4 hours of battery life (6-cell)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Hàng chính hãng còn bảo hành toàn cầu 1 năm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Giá:17,3tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]SONY VAIO FIT SVF15, NEW 100% BH 12 thang- NEW 100%[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Bảo Hành 12 thang SONY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Core i7 3537U 2.0ghz turbo bost 3.1ghz , IVY[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- RAM: 4GB DDR3 (1600 MHz)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- LCD: 15”6 LED HD[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- VGA: 2 VGA up to 4GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- nVIDIA GT 740M VGA MẠNH CHUYÊN NGHIỆP + Intel HD 4000[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- HDD 500 GB[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- DVD RW, WCam HD, USB 3.0…[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- Battery 6 cell ~ 4h[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]- NEW NO BOX[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]GIÁ: 19tr[/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)][/BCOLOR] [BCOLOR=rgb(252, 252, 255)]M!: 090 8118 929[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Yahoo! & Skype: augustini2507[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Add: 205 CMT8 P4 Q3 ( cách ngã 4 Điện Biên Phủ - CMT8 100m)[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Ngoài ra còn cung cấp thêmCaddy bay gắn thêm HDD vào khe DVD laptop[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]http://www.gsm.vn/threads/caddy-bay-ultrabay-gan-them-hdd-cho-laptop-mouse-logitech-m905-v470-mouse-ocz-behemoth.1817432/[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CHÍNH SÁCH BẢO HÀNH:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]1. SẢN PHẨM[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Sản phẩm chính hãng, zin nguyên bản, chất lượng hoàn hảo và được bảo hành chính hãng.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Sản phẩm chủ yếu là những dòng máy cao cấp, dòng VIP, dòng Business, dòng máy trạm WorkStations, được bảo hành theo tiêu chuẩn của hãng 03 năm đối với máy mới.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]2. GIÁ CẢBảo đảm được cho khách hàng mức giá tốt nhất đi đôi với sản phẩm chất lượng, phù hợp nhu cầu sử dụng cũng như vừa túi tiền.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Sẽ là một sự lựa chọn thông minh nếu bạn biết cách chọn cho mình một sản phẩm ưng ý mà bạn không phải bỏ quá nhiều tiền để mua một sản phẩm tương đương chỉ mang tên “hàng mới”, chỉ sau một vài tháng bạn sử dụng thì độ mới của nó cũng như nhau.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]3. LỢI ÍCH KHI MUA HÀNG[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]CHO ĐỔI:Sản phẩm bạn đã mua, trong vòng 07 ngày đầu tiên sử dụng, nếu cảm thấy không phù hợp hoặc một lý do nào đó bạn muốn thay đổi sang cái khác theo sở thích, bạn có quyền lợi đổi một sản phẩm bất kỳ có tại cty và bạn được tính giá trị như cũ (không bị lỗ).[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]DỊCH VỤ PHẦN MỀM MIỄN PHÍ:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Những lỗi xuất hiện thông thường khi sử dụng máy tính chính là “phần mềm” ( OS, Drivers, Softwares…) và điều này bạn sẽ được hỗ trợ hướng dẫn tận tình cũng như được cài đặt miễn phí bởi các NV Kỹ thuật của cty suốt vòng đời sản phẩm bạn đã mua.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]4. DỊCH VỤ BẢO HÀNHPhần lớn những dòng sản phẩm cao cấp đều có tiêu chuẩn bảo hành chính hãng 03 năm, hoặc 05 năm, thộng tin bảo hành từng sản phẩm có thể kiểm tra (Check seri No/ Check Sevice Tag…) trên Website từng hãng.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Sản phẩm bán ra được Bảo hành chu đáo đúng theo quy chuẩn chính hãng, thời gian Bảo hành ngắn hay dài tùy thuộc vào các điều khoản sau:[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]a, Bảo hành 03 tháng đối với tất cả sản phẩm bán ra[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]b, Bảo hành 06 tháng sẽ tính thêm phí 300.000VNĐ/ 01 sản phẩm[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]c, Gói bảo hành 12 tháng thêm 500.000 VNĐ/ 01 sản phẩm.[/BCOLOR] [BCOLOR=rgb(252, 252, 255)]Trân trọng cảm ơn![/BCOLOR]
