ColorNote Notepad Notes mang đến cho bạn 2 cách tạo ghi chú: ghi chú thường và danh sách làm việc. Với thiết kế đơn giản kết hợp với khả năng tạo ghi chú nhiều màu sắc, ColorNote xứng đáng là một trong những phần mềm ghi chú tốt nhất cho Android. Color Note is a notepad app which give you a better note editing experience. Color Note is a simple notepad app. It give you a quick and simple notepad editing experience when you write notes, email, message, shopping lists and todo lists. Color Note makes taking a note easier than any other notepad apps. ***Notice*** If you cannot find widget, please read below FAQ. It is not a bug. ***Features*** -Organize notes by color -Sticky Note Widget -Checklist for ToDo & Shopping list -Organize your schedule in calendar -Protect your notes by passcode Password Lock/Unlock note -Secured backup notes to sd storage -Supports online back up and sync. You can sync notes between phone and tablet. -Reminder on status bar -List/Grid View -Search notes -Notepad supports ColorDict Add-On -Powerful Reminder : Time Alarm, All day, Repetition.(lunar calendar) -Quick memo / notes -Wiki link : [[Title]] -Share notes via SMS, email, twitter -Use color to categorize notes. *** Online backup and sync cloud service *** -Notes will be encrypted before uploading using the AES standard, which is the same encryption standard used by banks to secure customer data. -It does not send any of your notes to server without your signing up. *** About Permissions *** -Internet Access : For online backup & sync -Modify/delete SD card contents : For backup to sdcard -Prevent phone from sleeping, control vibrator, automatically start at boot : For reminder ***FAQ*** Q : How do you put sticky notes on the home screen? A : Goto home screen and long press empty space and choose widget, Color Note will be there for sticking on page. Q : How come the widget and the alarm and remider functions don't work? A : If the app is installed on the SD card, your widget, reminder and etc. will not work properly because Android doesn't support them! If you have already moved app to SD card, but you want those features, you have to move it back to device and reboot you phone. Settings - Applications - Manage Applications - ColorNote - Move to Device Q : Where is backed up notes data at sdcard? A : /data/colornote on sdcard Q : I had to reinstall color notes notepad and there is an automatic backed up notes data that was stored but it requires a password and I hadn't set one up in the past. How do I retrieve that information? A : Try default password '0000' (numbers) Q: I forgot my master password, how can I change it? A: Menu -> Settings -> Master Password -> Menu Button-> Clear Password. You will lose current locked notes when you clear password! *** Product Description *** Color Note notepad features two basic note taking formats, a lined-paper styled text option and a traditional checklist option. Add as many as you want to your master list, which appears on the app's home screen each time the program opens. This list may be viewed in traditional ascending order, in a grid format, or by the color of the note. - Taking a Note - Serving as a simple word processing program, the text option allows for as many characters as you're willing to type with your device's virtual or physical keyboard. Once saved, you can edit, share, set a reminder, check off or delete the note through your device's menu button. When checking off a text note, the app places a slash through the list's title, a mark that shows on the main menu. - Making a To-Do List - In the checklist mode, you can add as many items as you'd like and move their order around with the up and down buttons activated in the edit mode. After the list is finished and saved, you may check, and uncheck, each line on your list (from grocery store items to household chores) with a quick tap that generates a line slash. If all items have been checked, the list's title is slashed as well. When you're finished using the notepad, an automatic save command preserves your individual note before returning you to Color Note's homescreen. Xem thêm: Mã: https://market.android.com/details?id=com.socialnmobile.dictapps.notepad.color.note&feature=search_result Tải về: http://appstore.vn/a/index.php/home/app/1534
What's in this version: * If you cannot find widgets, you have to move the app back to device in application settings and reboot you phone! ** 3.6.4 Dark Theme Send checklist by email.[Send as attachment] Browse & restore a note from sdcard backup Browse sdcard backup when signed in.
