Diet Assistant Pro giúp bạn tạo chế độ ăn kiêng để giảm cân, đồng thời theo dõi cân nặng qua từng ngày. Tính năng chính: • Healthy choices of diet food with the right combination • Diet plans to suit your needs • Shopping / Grocery list (Press Menu -> Shopping List on "My Diet") • Ability to add custom items to the shopping list • Works as your personal dietitian/nutritionist • Nutrition facts • Weight-loss manager & tracker (kilograms, pounds or stones) • Built-in BMI (Body Mass Index) calculator • Intuitive and sleek UI • Weight Chart / Graph • Diet and weight loss tips • Health pyramids • Data backup/restore • Homescreen Widget • And much more! Đánh giá của người dùng: • "The new update is awesome. Love the new widget!" • "Absolutely amazing!! This app is so well done. I have been looking for an app that wasn't just about weight loss but about getting healthy. Found it!!" • "Great application! Keeping on top of my diet & weight with it." • "Awesome app! It has everything you would need while on a diet. The app is also very easy to use." • "The shopping list is so useful! Liked the improvements" • "Love this app! Has kept me motivated to keep going" • "Great app. Gives you a daily menu. If you're willing to give up the foods you love to shed that belly then this app is for you!" • "Cool app! Weight tracking is really good” Accessing the app's settings: - Press "Menu" from its main screen - Select "Preferences" How to use the widget: - Press the "Home" key on your android device - Press "Menu" then "Add" and select "Widget" from the list - Browse through the alphabetical list and choose "Diet Assistant" - That's it Deleting items from the shopping/grocery list: - Long press on a chosen item - Select "Delete item" Xem thêm: Mã: https://market.android.com/details?id=com.aportela.diets.pro.view&feature=search_result Tải về: http://appstore.vn/a/index.php/home/app/2286
