Dorland’s Medical Dictionary 3.0.80 - từ điển y học
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 16 Tháng chín 2011.
  1. Khỉ Con interista
    [​IMG][​IMG][​IMG]
    Dorland's Medical dictionary with 40,000 entries and 350 illustrations.
    Dorland’s Medical Dictionary contains approximately 40,000 entries and 350 illustrations and provides authoritative, concise definitions for a wide range of terms used in the health sciences, including anatomy, physiology, diseases, drugs, tests and procedures and much more.
    *** We are very sorry for the inconvenience; the "cannot connect to server" errors which you may see in the program are due to technical issues with our online servers. We are working on fixing the problem and it should be fixed shortly. We appreciate your patience and understanding.***
    The dictionary is based on the contents of Dorland’s Illustrated Medical Dictionary, which has set the standard for medical dictionaries for over 110 years.
    * 40,000 entries and definitions from all areas of medicine
    * 350 illustrations
    * Audio pronunciations
    * Helpful hints, including information on pronunciation
    * Clear, accessible color layout
    The MSDict Dictionary Format
    The Dorland’s Medical Dictionary is here presented in MSDict electronic format. MSDict offers best experience in mobile reference and is available for any handheld platform.
    * Quick dynamic search of words while you type
    * Transcriptions facilitating pronunciation
    * Hyperlinks between different related words
    * History to see the last 50 words you have looked up
    * Support for memory cards
    * Filters to help you locate the word you are searching for:
    o Fuzzy filter- used when you are not sure of the correct spelling of a word
    o Keyword-used to locate the instances of a key word within other compound words
    o Wild card - "?" and "*" replace a letter and group of letters in words
    * Fast article scrolling
    * Ability to have dictionary Word of the day as a widget on the phone home screen
    * Ability to search words in the installed dictionaries through the standard phone search feature
    Xem thêm:
    https://market.android.com/details?id=com.mobisystems.msdict.embedded.wireless.elsevier.dorlandsmedical.full&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/2327
