Dr.Web Anti-virus v6.01.2
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 2 Tháng tám 2011.
  1. Khỉ Con interista
    Dr.Web Anti-virus​
    Thông tin:
    Protect your mobile device from viruses and spam with a popular anti-virus from leading Russian anti-virus vendor Doctor Web, whose acclaimed products first appeared on the market in 1992.Dr.Web anti-virus provides you and your mobile device with the constant anti-virus protection, the intelligent SMS and calls filtering and the tools to find your device in case it is lost or to defeat thieves in case it is stolen.
    The application does not affect the operating system performance, and — more important — does not reduce the battery life. You can use simple and handy desktop widgets to access the application.
    Dr.Web anti-virus uses the unique algorithm to detect malware – Origins Tracing™ for Android – which allows detecting the new virus families using the knowledge database on previous threats. A unique record is created for each malicious program and describes the behavior algorithm of this sample. This provides the efficiency of detecting new modifications of the whole virus family and significantly reduces the size of virus databases.
    Dr.Web anti-virus key features
    – Constant anti-virus protection and threats neutralization. The anti-virus check of the file system is carried out by file monitor SpIDer Guard, which scans in the real-time mode all the files being saved in the device memory.
    – On demand scanning is carried out by a specific component – scanner. Dr.Web anti-virus allows to perform quick and full scan of the file system or scan only critical files and folders.
    – Quarantine. The detected threats can be deleted or moved to quarantine, where you can review the detailed information on the potential malware.
    – SD-card protection from contamination by autorun files and Exploit.Cpllnk, which represent a threat to Windows.
    – The small size of updates for virus databases allows to save the traffic and your money if you are using the limited mobile tariffs.
    – Detailed statistics on the anti-virus operation.
    – Two handy widgets to choose from to manage the anti-virus protection (sizes 1х1 and 4х1).
    Anti-spam
    – Selection of calls and SMS filtering modes.
    – Creation of your own filtering profiles.
    – Black list editing. You can add the contacts, from which you would like to block all incoming calls and SMS, into the black list.
    – Viewing blocked calls and SMS.
    Anti-theft
    Anti-theft helps to find the mobile device in case it is lost or stolen as well as remotely delete all personal information from it. Anti-theft can be managed by sending special SMS to the device.
    Anti-theft allows:
    – to enable the device blocking function on its restart
    – to block the device and require entering the password to unlock it;
    – to limit the number of errors on entering the password to unlock the device;
    – to unlock the device by sending an SMS-command;
    – to get the GPS-coordinates of the device as a link to Google Maps;
    – to remotely delete the information stored on the SD-card;
    – to activate a sound alert on the device and to block the screen;
    – to enter your own text which will be displayed on the blocked screen;
    – to create a list of friends, who will receive notifications on changing the SIM-card on your device. You will be able to manage Anti-theft and to unlock the device from their numbers in case you forgot your password.
    Tải về:
    http://appstore.vn/a/index.php/home/app/1272
  2. Khỉ Con
    6.01.2
    What's in this version:
    1. Anti-theft;
    2. Greek language;
    3. Renewal Samsung Galaxy Tab 10.1 capability;
    4. Bug fixes.
