DrJukka Theme Scheduler - Tự động chuyển đổi themes theo thời gian.
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi tichau, 19 Tháng mười 2009.
  1. tichau Guest
    DrJukka Theme Scheduler v1.10 S60v3 v5 SymbianOS9.x Unsigned
    Theme Scheduler is a free theme scheduler application that allows automated theme scheduling with timer.
    This freeware application is designed for S60 OS 9.1 Symbian smart phones, and tested only with Nokia S60 devices. It should work with All S60 3rd & 5th edition devices, including Nokia 5800 and N97.
    change log :
    updated with Slovenian language ​
  2. Be Yeu
    DrJukka Theme Scheduler v1.10.2 S60v3 v5 SymbianOS9.x Unsigned
    With this application you can easily have your business theme on while at the office and automatically get it to more relaxed one when your work day ends, or simply use the random themes to get your phone appearance to surprise you..
    updated with Slovak and Czech languages.
    lysamtanhaccs4 thích bài này.
  3. tichau
    tichau Guest
    DrJukka Theme Scheduler v1.10.4 S60v3 v5 SymbianOS9.x Unsigned Freeware
    This freeware application is designed for S60 OS 9.1 Symbian, and tested only with Nokia S60 devices. It should work with All S60 3rd & 5th edition devices, including Nokia 5800 and N97
    change log :
    Azerbaijan added and Farsi updates
  4. minhtue
    DrJukka Theme Scheduler v1.10.9 S60v3/S60v5 SymbianOS9.x Unsigned Freeware
    Last update: 01/4/2010
    It also has option on scheduling themes with profile changes, and if you wan your profiles to be automatically scheduled as well, then do remember to download Profile Scheduler available at this site as well.
    Change-log
    Korean language added to Theme Scheduler
  5. minhtue
    duc2012 thích bài này.
  6. volamaster
    volamaster Thành viên
    Có ai biết cách sử dụng phần mềm này ko vậy ? (Tìm hoài ko ra !:12:)
    Thanks !
  7. duc2012
    duc2012 Thành viên
    sử dụng là như thế nào là hả bác?có gì đâu.đơn giản như tên gọi mà??mới vào thì nó sẽ yêu cầu bác cài đặt thời gian để hiển thị cái thémes hoặc wallpaper mà bác muốn hiện ở thời gian đó.vd như bác để 7h sáng hiện ảnh hoặc themes của bác sau đó tầm 9h bác đặt để hiện thị ảnh hoặc themes khác.tức là nôm na là bác cài đặt thời gian để máy hiển thị ảnh hoặc themes bác đã đặt.cso thể thay đổi theo ngày nữa đó.bác cứ tìm hiểu thử xem.nhưng cũng khá tốn pin đó nếu cứ cách 1h lại thay đổi.em để 2 tiếng đổi 1 lần.nhìn cũng phê.hehe
    PS: bản 110.9 có gì mới không bác ơi??để em cài thử phát
  8. volamaster
    Thì chính là các bước để đặt thời gian tự động thay đổi Theme đó ! Phần mềm này ko được " thông minh " lắm !( Hay tại mình gà mờ !:25:)
    Bạn có thể chỉ chi tiết từng bước được ko ? :013:
    peter 1 thích bài này.
  9. peter 1
    peter 1 Thành viên
    Vào option =>new=>timed change
    * Theme/wallpaper: thì chọn cái theme bạn cần cài đặt.
    * Active on: thì chọn every day
    * Set on time: thì chọn thời gian cần thay đổi.
    Cuối cùng Save lại.
    Hoàn tất rồi đó,thưởng thức thôi bạn :048:.
  10. volamaster
    Hơ hơ, cuối cùng thì cũng thấy nó tự động thay đổi Theme ... nhưng mà là ... hôm sau !!!:001:
    Cái này hình như ko có chức năng thay đổi theo 10, 20.. phút gì đó chẳng hạn ! (Tìm hoài ko thấy ):032:
