Yêu cầu phiên bản Android từ: 2.1 Tổng quan: Một ứng dụng rất pro, không thua gì Go Contacts, giúp bạn quản lý danh bạ, tin nhắn, quay số ... Hình ảnh: Thông tin chi tiết: dialer phone contacts groups sms mms email organization ringtone call filterDW Contacts & Phone 2.0.6 Is a powerful (MUST HAVE) replacement for your stock dialer, contacts and phone management application KEY FEATURES ------------ + multi-language support + most functions are accessible by using the *LONG PRESS* (tap and hold) on any item or use *MENU* key + very flexible to configure the design of every view (sort order, fonts size, color, transparency) + quick-jump function, show a window, where you can click the first letter of your contact and quickly jump/scroll to it + configurable contact view, how it should show the list (*show contacts as* / *sort order* for last name, first name, nick name, ...) + support for all account types (local, Google, ms exchange, ...) + tab bars: hide & sortable, include gesture switching to different views (phone, history, favorites, contacts, search, groups, organization, titles, events, toolbox) + full management for your contacts (create, add, change, delete, copy contacts, copy to another account, groups, organization, titles in single- and multi select mode) + batch mode for mass delivery with SMS, MMS, emails on single- and multi selection (contacts, groups, organizations, titles) + search contacts by any attribute (name, nick name, phone number, organization, notes, address, email, relationships, websites, birthday, ...) + voice search + support for layered groups, sub-groups (sub-group via Business.VIP = Business -> VIP) + set ringtones on single- and multi select (contacts, groups, organizations, titles) + contact event notification and contact event management (birthday, anniversary) + support for lunar calendar format + easy sending event greetings to your contacts + create shortcut to home on any contact item or on any tab via toolbox (phone, dialer, contacts, favorites, groups, organizations, titles, ...) + extended incoming call view (background service: show organization, group, notes, group picture) + share contacts (text,vcard) via SMS, email, ... + call filter (blocking incoming calls on free definable date- and time zones) + display call history with summary for single- or multi-select contacts, groups, organization, titles, ... + dialer(phone) with T9-search - has many options to make it exactly to your wishes -> dialer and dialpad scalable and adjustable in size, background, color, font size can be changed -> full T9-search on all contacts fields and configurable -> icons for contact picture, dial, SMS, email -> quick dial manager (long press 0-9) -> quick dial last number -> display call history on dialer -> edit number before dialing -> voice dialer Please honor our work and buy the PRO version, which is very favorable in the light of functionality! Hints: We can not contact you in the Google market, if you post your questions or thoughts. If you have any suggestion for improvements -> please write on forum: http://forum.dw-p.netor use the *Feedback via email* function in settings menu. If you upgrade to a newer version and it fails to start (if download or install is not possible), please try to uninstall previous version before. Google account group limitation: If you want to use new groups for google account, you need to create at first the group, then sync your Google account. Afterwards you can use it for contacts. More tips & tricks see on forum http://forum.dw-p.net/viewforum.php?f=9 Xem thêm trên Android Market: Mã: [URL]https://market.android.com/details?id=com.dw.contacts&feature=search_result[/URL] Tải về: Mã: [URL]http://appstore.vn/a/index.php/home/app/1253[/URL]
Không hiểu sao máy mình sử dụng cái này bị treo máy suốt, dò tìm danh bạ thì nó không tự dò ( nó đánh dấu x ngay sau ô tìm kiếm thay vì hình kính lúp ; mặc dù danh bạ có tên cần tìm ) Mình dùng D2G
Cập nhật 2.2.4 2.2.4 Customize the default contact icon Remove the display call records New speed dial - enter "1" and then hold down the "8", you can dial 18th numbers Backup and recovery theme settings New themes Contact details view supports custom fields Dial a number directly from Remark More desktop widget configuration options Add Search option in the search bar
