Xin giúp E72 bi dead phone khi flash bằng phonenix
Thảo luận trong 'S60 3rd: FIRMWARE - SIGN - HACKPHONE & HACK APP' bắt đầu bởi jacobphan2610, 11 Tháng bảy 2011.
  1. jacobphan2610 Thành viên
    Tình hình là em có flash lại cho e72 bằng phonenix thì bị dead phone, từ hum qua tới giờ cũng đã search đủ kiểu cứu phone bẳng phonenix ở chế độ dead phone nhưng không được và cứ báo lỗi:
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 15168 bytes
    Secondary boot loaded
    BB Asic Index is: 00
    Asic ID is: 000000030000022600010007600C192102011104
    EM Asic ID is: 00001040
    EM Asic ID is: 00001030
    Public ID is: 09100119DC6C0344333A2125573E3F3ACBB24981
    Asic Mode ID: 00
    Hash: 25B977A055BE9B5DEC0C38A2A279C695
    ROM ID: 3E273BF637BE26FA
    Device type is: 05
    Device Index is: 00
    Manufacturer code: 0000
    Device ID: 0000
    Extended device ID: 0000
    Revision ID: 0000
    Device type is: 04
    Device Index is: 00
    Manufacturer code: FFFF
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 00
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 01
    Device ID: 0001
    Revision ID: 0000
    Device type is: 03
    Device Index is: 00
    Manufacturer code: 00EC
    Device ID: 0058
    Revision ID: 0121
    Loading update server code: 812840 bytes
    Update server loaded
    Asic CMT: Start programming 190441 KB...
    Asic CMT: Programming data sent: 0%
    Asic CMT: Programming data sent: 10%
    Asic CMT: Programming data sent: 20%
    Asic CMT: Programming data sent: 30%
    Asic CMT: Programming data sent: 40%
    Asic CMT: Programming data sent: 50%
    Asic CMT: Programming data sent: 60%
    Asic CMT: Programming data sent: 70%
    Asic CMT: Programming data sent: 80%
    Asic CMT: Programming data sent: 90%
    Asic CMT: Programming data sent: 100%
    Programming complete
    Asic CMT: Verifying communication to device...
    Waiting for communication response: 25
    Waiting for communication response: 24
    Waiting for communication response: 23
    Waiting for communication response: 22
    Waiting for communication response: 21
    Waiting for communication response: 20
    Waiting for communication response: 19
    Waiting for communication response: 18
    Waiting for communication response: 17
    Waiting for communication response: 16
    Waiting for communication response: 15
    Waiting for communication response: 14
    Waiting for communication response: 13
    Waiting for communication response: 12
    Waiting for communication response: 11
    Waiting for communication response: 10
    Waiting for communication response: 9
    Waiting for communication response: 8
    Waiting for communication response: 7
    Waiting for communication response: 6
    Waiting for communication response: 5
    Waiting for communication response: 4
    Waiting for communication response: 3
    Error 0x8401F121 communicating to phone. Unable to verify comm.
    Warning: Unable to communicate to product after flashing
    Starting to recover the phone
    Recovering phone
    Initializing
    Phone recovery completed. Waiting for phone to boot up
    Bootup successful
    Verifying communication to product (before flash finalizing)
    Failed to verfy communication to product
    All operations completed
    Firmware updating failed.
    HRESULT 0x8421001c (-2078212068)
    Firmware: Cannot verify communication to phone after flashing. Make sure that phone booted up correctly and retry.
    Các bác cho em hỏi máy em giờ nên xử trí ntn, sinh viên nghèo ko có tiền đem ra nokia care chạy lại phần mềm,có bác nào bik chổ nào chạy lại bằng box chuyên dụng mà giá rẻ chỉ em với.Thanks các bác nhiêu ............!
  2. tung253
    tung253 Thành viên
    Giống hệt trường hợp của mình, may mà còn hạn bảo hành nên mang ra care rồi, mang ra mấy hàng ngoài ko có box chuyên dụng ngta bó tay hết :D
  3. manhtu
  4. vnmsc
    vnmsc Thành viên
    Thiếu file trong bộ fw, Không dead mới lạ . Tải lại đủ fw rồi flash lại = Px chế độ deadphone bạn nhé
