EasyBand Studio v1.0.4
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 6 Tháng mười 2011.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.2
    Ảnh chụp màn hình:
    Thông tin chi tiết:
    Update: the crash problem that occurred on some phones is now resolved. Give it arty and let us know if you still have problems running the application.EasyBand is an auto accompaniment tool for musicians.
    Use for creating playbacks, practicing solos and sketching your ideas on the go.
    Just drop chords into the timeline, select style and tempo and click play.
    EasyBand supports up to 8 distinct parts. Build your song one part at a time and then use the song editor to compile the complete song from the various parts.
    Each EasyBand style has 2 variants, 2 fills, an intro and an ending pattern. Each variation can be applied to individual chords or to an entire part.
    You can mute individual instrument to hear only the instruments you need. For example, if you are a drummer, you can mute the drums instrument while practicing.
    New!!! Community web site (Beta) allows you to share and download songs and chords from EasyBand Community website. Register and h
    You can export your project as both Wav files and Midi files.
    If you own FourTracks Pro app, you can export EasyBand's project as wav files specifically suitable for importing them into FourTracks and mix them down with audio recording.
    Xem thêm trên Android Market:
    [URL]https://market.android.com/details?id=com.nw.easybandpro&feature=search_result[/URL]
    Tải về:
    [URL]http://appstore.vn/a/index.php/home/app/2729[/URL]
