Entity (launcher theme) v1.8
Thảo luận trong 'Android: Giao Diện, Trang Trí' bắt đầu bởi Khỉ Con, 5 Tháng mười 2012.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.1
    Ảnh chụp màn hình:
    [​IMG][​IMG]
    [​IMG] [​IMG]
    Icons from another planet! Let Tha Entity overtake you!
    This is a launcher theme (for Apex, Nova, ADWEX, ADW.Launcher, LP, GO & more!) and will not alter the look of your status bar, notifications or anything else. It WILL change the graphics and icons for many popular launcher replacements! ☺
    Features ꜜ
    ▪New graphics for dock bar (ADW & Go)!
    ▪Over 1500+ custom icons!
    ▪Custom docks!
    ▪Wallpaper gallery included!
    ▪Apex theme support
    ▪ADW Theme support
    ▪Go Launcher EX theme support
    ▪Support for Desktop Visualizer
    ▪Support for Folder Organizer
    Notes
    ★More icons are due to be added over time. Do you see missing icons in your app drawer? Please email us with requests. We want you to be satisfied with your purchase and will work to add new icons for whatever we have missed.
    ★Regarding 'MovetoSD' availability: If the app is moved to SD Card, you risk the custom icons not loading properly because of how the system loads the SD card OR the theme not being active after a device restart.
    ★Launcher Pro users may need to wipe data if they are having 'Force Close' issues. Phone Settings > Applications > Manage Applications, choose Launcher Pro, select 'Clear Data' and then try to load the icons again.
    ★Icons may also work with Crazy Home Lite, dxTop Lite, Open Home paid, Open Home free, VTL Launcher, Circle Launcher Paid, FTL Launcher, Launcher Pro and more!
    ★If you are having trouble - EMAIL US! Seriously, send us an email and help us to help you. If you want to request icons to be created, send an email for that as well. ☺
    DESIGNED FOR HDPI. YOUR RESULTS MAY VARY WITH OTHER SCREEN RESOLUTIONS
    Xem thêm trên Play Store:
    [url]https://play.google.com/store/apps/details?id=kov.adwtheme.thaentity [/url]
    Tải về:
    [url]http://appstore.vn/a/index.php/home/app/10384 [/url]
