[Extremely HOT] Update N70 to 5.0737.3.0.1
Thảo luận trong 'S60/S80/S90: KIẾN THỨC & KINH NGHIỆM' bắt đầu bởi toan_cntn, 11 Tháng chín 2008.
  1. toan_cntn Thành viên
    Có bác nào đã thử cái này chưa? Mình thấy hay muốn làm nhưng chỉ down được V5.0737.3.0.1 Firmware EURO còn của ASIA up lên Rapid Share mình không down được. Đang máu lắm rồi, định đổi Code sang EURO để up đây. Liệu thế có được k nhỉ?
    This is the easiest way to update your Nokia N70 to V5.0737.3.0.1. (Tested on V5.0705.3.0.1)
    This method should work for all Nokia Symbian Phones.
    Note: You should BACKUP your phone memory before update (your phone will be format)
    Requirements:
    1. Nokia PC Suite (Download)
    2. Nokia Software Updater (Download)
    3. V5.0737.3.0.1 Firmware EURO(Part1 , Part2 , Forgotten UDA) ASIA(Download) [If not sure check the ASIA & Euro txt files I attached)
    4. Nokia USB Cable
    5. Internet Connection
    6. Fully Charge Battery
    How To Update:
    1. Install Nokia PC Suite & Nokia Software Updater and restart your PC
    2. Connect your Phone with USB Cable and wait Until "found new hardware" Finish and Nokia PC Suite recognise your phone.
    3. Now open Nokia Software Updater-This windows should appear (the pictures is at greek but don't worry about this). Then Click Start.
    4. Now Nokia Software Updater will inform you that you must enter "General" Profile and that you Battery muse be FULLY CHARGED. Then click continue.
    5. Wait until it recognise your phone and check for updates (5.0705.3.0.1 as the latest one). Then tick the box. And Click Update.
    6. NOW DISCONNECT THE USB CABLE FROM YOUR PC (normally the download proccess should continue without any disconnection notification).
    7.After download finish an error should appear
    " Unable to find the connected phone. Reconnect the USB Cable"
    DO NOT CONNECT IT NOW-HERE IS THE TRICK
    8. Open this folder (what Nokia Software Updater has download)
    FOR XP
    "C:\Documents and Settings\All Users\Application Data\Nokia\Nokia Service Layer\A\nsl_service_module_00001\vpls\www.dsut.online.nokia.com.oti.caresuite\Products\r m-84"
    FOR VISTA
    "C:\ProgramData\Nokia\Nokia Service Layer\A\nsl_service_module_00001\vpls\www.dsut.onl ine.nokia.com.oti.caresuite\Products\rm-84"
    You should see 6 files
    RM84_0539233_5.0705.3.0.1_003.dcp
    RM84_0539233_5.0705.3.0.1_003.vpl
    RM84_0539233_5.0705.3.0.1_003_signature
    rm84_50705301.c0
    RM84_50705301.UDA
    RM84_50705301.V27 (#27 depents on your region-27 is greece/cyprus)
    Extract V5.0737.3.0.1 Firmware I upload and find this 3 files
    RM84_50737301.C0
    RM84_50737301.UDA
    RM84_50737301.V27 (or what depents on your region-check what Nokia Software Updater has download)
    Now rename this 3 files and overwrite what Nokia Software Updater has download
    RM84_50737301.C0 ---->rm84_50705301.c0
    RM84_50737301.UDA---->RM84_50705301.UDA
    RM84_50737301.V27---->RM84_50705301.V27
    9. Now reconnect you USB cable, wait 10 seconds and click "Repeat".
    The installation Process should start.
    10. After some minutes your phone should restart and a messege " Your phone has succesfully updated" will show you thats all ok and click "Close"
    IF you want to check if its updated to 5.0737.3.0.1 enter *#0000#
    NOTE FOR ASIA(APAC) Versions: After you download the attach files from rapidshare, install it (default location-C:\Program Files\Nokia\Phoenix\Products) and check here for your files.
  2. Nin
    Nin Ex-Mod
    Không cần phải làm rùm ra nhưng thế đâu, cái này pheonix chạy phát 1 là xong, wa Box OS 9.1 mà xem nhé, cái này up 5, 6 con N70 lên bản 5.0737.3.0.1 rồi, bảo đảm ok. ko có ji khó đâu.:> nhưng up len cũng chả co ji thay đổi hết:|
    toan_cntn thích bài này.
  3. toan_cntn
    Hix,up lên không có j khác ah?nhưng em vẫn tò mò quá,he! Mà máy em không có phoneix, down mấy lần không được, hix! bác cho em cái link down phoneix được không?:hug::hug:
  4. Nin
    Nin Ex-Mod
    Vào topic pheonix lục lại hay hỏi xin trong đó nhé, hay có thể tìm bài Up bằng JAF cũng trong Box OS 9.1, có thể pm cho Zopo hỏi xin.
  5. toan_cntn
    Em down được Phoenix rồi nhưng vẫn thử làm theo cách kia, thành công 100% sướng quá.:hug::hug::hug:công nhận cách đó cũng đơn giản, nhanh mà hay thật. Mỗi tội FW mới chả thấy j khác,hix!
  6. baotrung1973
    baotrung1973 Ex-Mod
    Đã giải quyết xong ! Topic close nha ! Thân !
