FExplorer Pro
Thảo luận trong 'ỨNG DỤNG HỆ THỐNG' bắt đầu bởi dung1291985, 23 Tháng năm 2009.
  1. dung1291985 Ex-Mod
    FExplorer.Pro.v1.0.Beta1.S60v3.SymbianOS9.x.Signed
    FExplorer Pro Overview
    FExplorer Pro is a utility suite for S60 phones. The main feature is of course the astonishing file browser alongside various tools and options that you can use to better manage your phone in general.
    File Browser
    The file browser is very very extensive and is what made FExplorer so popular to begin with!
    It includes everything you will ever need from a file browser similar to Windows File Explorer or Total Commander (for Desktop).
    Features include (but are not limited to):
    • Searching for files on your phone.
    • Creation/Renaming/Deletion of files and folders.
    • Enter folders that can't be seen on the Nokia phone browser.
    • Three types of file editors (Hex, Binary and Text)
    • Attributes changes on files.
    • Zip(!)
    • Image viewer
    Tools
    With these tools, you can have a lot of your favorite tools all in one place, and it replaces the need to use other 3rd party applications for each of the functions (for instance Screenshot)
    a short overview of what each of these tools does:
    Screenshot - Similar to the Antony Pranata's Screenshot for S60, this tool allows you to create screenshots of your phone from anywhere on the phone with various options to handle file saving etc...
    Backlight - This will turn your e-mail notification light on/off similar to Best Torch for S60. Very handy as it can turn your phone into a flashlight when you most need it smile.gif
    Bluetooth manager - This is VERY handy also. It will turn your Bluetooth on/off with a click of a button.
    Compress memory - de-fragments memory. You receive the memory available before and after the call to the function too.
    Installed applications - more for developers - it generates a file (C:\INSTAPP.TXT) which contains all of the installed applications (by the application manager), their UID and their path.
    Dump file list - generates a file (C:\FILESLST.TXT) containing the list of the files and the directory starting at the current possition (current directory)
    Phone
    More options that you have for your phone in FExplorer Pro are shown above.
    Here is a short overview of what each function does:
    Phone info - this will give you all of the details that can be obtained about your phone like firmware version, IMEI etc...
    Restart - restarts the phone.
    Network info - gives you all available information that can be obtained about your network like area id, cell id, network name etc...
    Media info - gives you full stats on the installed memory card.
  2. tichau
    tichau Guest
    Thêm cái unsigned luôn nha mod :D.
  3. ATACK
    ATACK Thành viên
    sau chuong trinh nay minh cai ko dc
    toan bao chuong trinh bi loi lien he nha cung cap
    minh xai n73
  4. dccmltao
    dccmltao Thành viên
    bản unsign đòi key. (mình cài đè bản sign vào hết đòi)
    :D
  5. tichau
    tichau Guest
    Lạ nhỉ.E71 của mình cài bản signed thì nó báo Unable to install. Constrained by the certificate.
    :D
  6. dccmltao
    dccmltao Thành viên
    sặc-TiChau đùa nhau à
  7. tichau
    tichau Guest
    [-X
    Không có cách nào cài được trên E71 cả :-".
    [​IMG] [​IMG] [​IMG]
  8. zeroone01
    zeroone01 Thành viên
    Pác này giống em, cài trên E90(hacked):-/
  9. Codoner
    Codoner Thành viên
    mình cũng bị giống như vậy, có bác nào bít hok, chia sẻ anh em với ^^!
  10. cofer_tqc
    cofer_tqc Thành viên
    Có thể là không trùng imei mà OPDA đã sign chăng ?:D. Hôm trước sign nhầm cer cũng bị thông báo như thế :(
